sean logie | 14/09/2017 20:12:21 |
![]() 608 forum posts 7 photos | My wife Amanda was in Lidl today and she thought I might have use for a wee sand blaster . Well I tried it out tonight on a old cast iron spindle of a water valve (I also got a big chunk of bronze off the same valve ) and it works a treat to my absolute surprise . So if anyone fancies getting one they are on sale now (obviously lol)
?12.99 . Sean Edited By sean logie on 14/09/2017 20:31:28 |
Brian Sweeting | 14/09/2017 20:22:07 |
453 forum posts 1 photos | Slight problem for me on that one, no air compressor - damn. |
Mike E. | 14/09/2017 21:16:27 |
![]() 217 forum posts 24 photos | I bought one when they were available several years ago, and I can't fault it. I removed the small canister and put a siphon hose on the stem leading to a bucket full of sand; it works a treat. |
sean logie | 15/09/2017 06:01:46 |
![]() 608 forum posts 7 photos | Lucky for me ,I was gifted a 200 litre compressor a couple of wks ago . It was supposed to have an intermittent problem ,only problem i could find was the pressure shut off switch was adjusted to the max ,all I did was turn it down to about 90psi never missed a beat since. Sean |
not done it yet | 15/09/2017 07:08:19 |
7517 forum posts 20 photos | Sean, Most home-use compressors are either 8 or 10 bar machines - the rationale being that most (decent) air power tools require 6 bar, to operate at full capacity. Some only require 5.5 bar, but that still does not leave much of a ceiling for outlet pressure regulation, even if you have a 200l receiver. I think the grit blaster (don't use silica sand) will require 6 bar. |
clogs | 15/09/2017 07:57:45 |
630 forum posts 12 photos | as a heads up........ out of interest my local Lidal (Bordeaux) has a small wet / oil air compressor.....€109 euro's.........about 5cu/ft, 24lt tank.......1.8kw motor and has a built in hose reel with a 10m hose on it..... also there's a selection of hose fittings........have used these fitting everyday and they do last ....mines over 2 years old....... so I guess it'll be in a store near U quite soon..... I bought a dry compressor from Aldi over 14 years ago and still works a treat although very noisy, it's just as a mobile tyre inflator.......at these prices u can't go wrong..... as for the sand blaster and this compressor, it's not a RACE..... have fun........clogs
sean logie | 15/09/2017 17:45:01 |
![]() 608 forum posts 7 photos | Yes the bar pressure is important ,it'c the cfm that makes the difference . Mine delivers 9 cfm so more than happy, and it also keeps up with any air tool i use blaster included ..
Sean |
Clive Foster | 15/09/2017 18:50:04 |
3630 forum posts 128 photos | Mike E That syphon hose conversion to use a bucket of sand idea is good. Somehow I ended up with two of that sort of gun, one Lidl and one of another brand so maybe will give it a try. Presumably you can still use the collector bag? I have a stand alone syphon from a bucket one but thats just too messy unless desperate. Fortunately I found a proper Guyson cabinet for affordable money some years back which holds pretty much everything I have to deal with. Clive. |
