lee hawkins 1 | 08/09/2017 06:12:16 |
111 forum posts | Hello I decided to fit some new bearings to my mini lathe headstock . so I went for these, 7206 B 2RS Angular Contact Ball Bearing 30x62x16 These bearings fitted great. I have not given them any sort of preload for the reason being that I have not even fitted the locking nuts and On turning the spindlle there seems to be a slight binding as though there is too much preload. When I turn the spindle, it turns kinda smooth but you can sort of feel the spindle click around with the rollers in the bearings I have never had much to do with angular contact bearings, maybe these bearings fit differently appreciate any advice Thanks lee |
Mick B1 | 08/09/2017 07:12:18 |
2444 forum posts 139 photos | You gotta suspect misalignment. IME the most usual cause is a particle at the bottom of the outer race seating bore, causing a thou or so tilt in said race. Of course that's only a guess. |
Hopper | 08/09/2017 09:05:07 |
![]() 7881 forum posts 397 photos | Good brand name bearings or Chinese no-name cheapies? Not all are created equal. Some of the cheapies are OK, others not so. |
lee hawkins 1 | 08/09/2017 14:57:15 |
111 forum posts | Mick, Hopper Yep! I used block of wood to press out old bearings, a piece/splinter of wood managed to stick it's self to the bearing seat, cleaned it out, now perfect!
Thanks lee |
oldvelo | 09/09/2017 02:41:44 |
297 forum posts 56 photos | Hi Lee The outer bearing needs to be a sliding fit on the spindle not a press fit. The spindle under the bearing needs to be reduced with emery cloth until the bearing will slide on with finger pressure only. They need a light preload with the back nuts are essential holding the inner races taking up the free play. Eric |
not done it yet | 09/09/2017 07:35:25 |
7517 forum posts 20 photos | The outer bearing needs to be a sliding fit on the spindle not a press fit. That is surprising! So the inner race could turn on the spindle? Would that not possibly lead to wear on the spindle?
Michael Gilligan | 09/09/2017 08:28:42 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 09/09/2017 07:35:25:
The outer bearing needs to be a sliding fit on the spindle not a press fit. That is surprising! So the inner race could turn on the spindle? . ... but it should not Unless the bearings themseves are very stiff [i.e. not fit for purpose]. The combined friction of the 'sliding fit' and the end-load will far exceed the rotational drag of the bearings. MichaelG. |
Mick B1 | 09/09/2017 09:38:07 |
2444 forum posts 139 photos | I'd guess the main purpose of making it a sliding fit is to provide 'feel' for the preload, without the additional drag of forcing the inner race along the spindle? |
