Madhatter | 04/09/2017 23:38:39 |
19 forum posts | Another probably bonkers question here, I have the Fobco in pieces and when I removed the quill the depth stop bumper-O ring (quill washer) has a split in it and I have spent quite some time searching for rubber washers- bumpers and the like to no avail, not that I am unable to find any, but nothing which shall suit. perhaps it is my Ocd, but the original is flat and I would prefer to replace it with the same if at all possible. With my vernier the OD is 65.83 mm and ID is 44.76 mm with a thickness of 3.8 mm, there is a slight gap between the rubber and the drill so ideally this could go up to 5 mm thickness. You would not think a rubber washer of the right dimensions so difficult to source so would appreciate any links anybody may have, please do enlighten me.
Edited By Madhatter on 04/09/2017 23:47:09 |
Ian S C | 05/09/2017 04:19:26 |
![]() 7468 forum posts 230 photos | It is probably an Imperal size to start with, and the place I go to here in NZ has metric and imperial sizes of O-rings in both round and suqare section, this place is a specialist hydralics retailer. Ian S C |
Martin Cargill | 05/09/2017 09:10:44 |
203 forum posts | Don't know where you are located but we use a company called Manchester Seals for our hydraulic seals etc. They are good at matching seals, o rings etc. when we can't obtain them from the original manufacturer. Give them a call on 0161 832 7992. Martin
Madhatter | 06/09/2017 16:51:57 |
19 forum posts | Hmmm, I received one quote today £6.50 each plus £4.00 packing + vat. I have tried calling Manchester seals to no avail, I noticed on the G images, someone had refurbished a star up and used what appears to be large cork washers, can't find any of these to suit either. If any one has any other ideas it would be appreciated.
David George 1 | 06/09/2017 17:17:19 |
![]() 2110 forum posts 565 photos | I just got a piece of 3mm flat rubber sheet and using a pair of dividers scribed to circles till cut through and made my own. David
