Mini lathe parts?
Bodger Brian | 16/08/2017 21:27:14 |
![]() 187 forum posts 40 photos | In the box where I keep the change wheels for my mini-lathe, I recently found a handful of square nuts. I think they're imperial sized, 3/8" square x 1/8" thick with a thread size that I have no way of measuring. I'm fairly sure they are related to the lathe in some way but the big question is - what are they for? I think I can feel a 'Doh!" moment coming soon.... Brian |
Nicholas Farr | 16/08/2017 21:37:13 |
![]() 3988 forum posts 1799 photos | Hi Brian, could possibly be 1/4" Whitworth nuts for gutter bolts, or more commonly called roofing bolts nowadays **LINK** Regards Nick. |
Harry Wilkes | 16/08/2017 21:40:35 |
![]() 1613 forum posts 72 photos | Same thought came to me when I read Brian's description of the nuts H
Bodger Brian | 16/08/2017 21:41:57 |
![]() 187 forum posts 40 photos | Nick - potentially, yes. But I'm sure they're related to the lathe in some way, as a) there are no other non-lathe related parts with the other bits & bobs & b) I've never had the need to buy or possess gutter bolts. Brian |
Nicholas Farr | 16/08/2017 21:51:18 |
![]() 3988 forum posts 1799 photos | Hi Brian, it's just the thickness of 1/8" that made me think of gutter bot nuts. Regards Nick. |
Brian G | 16/08/2017 23:17:37 |
912 forum posts 40 photos | Quick check is to try and fit an M6 bolt into them. If it looks like it will go but locks up solid, odds are it is 1/4 BSW. I speak with the voice of bitter experience here, on taking over another company one of our storemen put all their 1/4 Whit hex nuts into the same bins as our M6. Luckily most of our stock (around a million nuts) was in sacks, but it was cheaper to scrap our loose stock than sort them. Another Brian |
Martin W | 17/08/2017 00:37:47 |
940 forum posts 30 photos | Brian Could they be for securing the gear axles/studs to the banjo and fit in a slot at the back of the banjo, square so they don't rotate when the axles/studs are tightened. Just a thought Cheers |
Enough! | 17/08/2017 01:39:28 |
1719 forum posts 1 photos | Is hardware for a mini-lathe likely to be imperial-sized? |
not done it yet | 17/08/2017 07:42:03 |
7517 forum posts 20 photos | If only 1/8" thick, they may well be nuts used in glass house construction where the nuts and bolts were rather smaller than the usual guttering/roofing articles. |
Bodger Brian | 17/08/2017 08:17:21 |
![]() 187 forum posts 40 photos | Posted by Martin W on 17/08/2017 00:37:47:
Could they be for securing the gear axles/studs to the banjo and fit in a slot at the back of the banjo, square so they don't rotate when the axles/studs are tightened. Thanks for the suggestion. I can't check it at the moment as I'm at work but definitely something to investigate later. Brian |
Bodger Brian | 17/08/2017 08:19:09 |
![]() 187 forum posts 40 photos | Posted by Bandersnatch on 17/08/2017 01:39:28:
Is hardware for a mini-lathe likely to be imperial-sized? In my naivety, I assumed it was but now you mention it.... Must check out other fastenings this evening. Brian |
Neil Wyatt | 17/08/2017 16:50:09 |
![]() 19226 forum posts 749 photos 86 articles | Similar nuts are supplied with some small vertical slides instead of t-nuts, they have an M6 thread IIRC. |
