Wanner oil gun
Adrian 220/06/2017 17:06:56
104 forum posts
19 photos
I bought my Wanner oil gun from Myfords Nottingham just before they closed their doors for the final time. I bought it on the strength of Harry Paviour's comment in his Connoisseur lathe report in MEW 2003. "Trust me, they are the business and they don't leak"
Have I just been unlucky? With SAE 30 oil it leaks badly, with Nuto H 32 it is unusable. What a mess.
Myford had closed, I was stuck with it. Very disappointing. At about £70 a pop I am loath to invest in another. I would be interested to hear others experiences with it, or alternative guns that are reliable.
Thanks Adrian.
DMB20/06/2017 17:43:19
1585 forum posts
I used to use a red painted pump oilcan which wasted/spilt more oil than wad actually used.
Got a Reilang to dispense expensive Myford oil - no waste. Expensive oilcan but damn good quality and should soon pay for itself in saved oil.
When Myford oil runs out, will look for cheaper good alternative.
Douglas Johnston20/06/2017 18:29:41
814 forum posts
36 photos
After years of the same problem I converted a £12 grease gun by sealing the main chamber and keeping the main chamber vertical (upside down ) so that the oil feeds into the pressure cylinder by gravity. This arrangement is described in detail on the web (Google converting a grease gun for oil ). This arrangement has worked well for me on my Mill.
Doug
David Standing 120/06/2017 19:37:11
1297 forum posts
50 photos
Try a warranty claim with 'new' Myford/RDG devil.
Lambton21/06/2017 07:06:41
694 forum posts
DMB,
"When Myford oil runs out, will look for cheaper good alternative"
There is nothing magical or special about Myford oil. It is simply 32 grade hydraulic oil which is widely available from many suppliers. My local commercial garden machinery dealer has a bulk tank and will supply small quantities at very reasonable price just bring your own one litre container.
DMB21/06/2017 08:12:58
1585 forum posts
Hi Lambton,
Thanks for your advice. Will look around for a local supply.
John.
JohnF21/06/2017 08:48:16
1243 forum posts
202 photos
Adrian, snap for your experience, I did the same thing and the Myford oil gun lubricates the operator rather than the machine!
Recently I bought one from Pressparts see the link and it works much better, not perfect but fantastic by comparison and at £15 I am pleased.
Adrian 221/06/2017 09:17:49
104 forum posts
19 photos
Thanks to everyone for your input, very helpful. I am going to play about with the Wanner first, see if I can cheer it up a bit. If not it can go in the bin! John's Pressparts gun sounds pretty good.
Adrian.
Robbo21/06/2017 09:28:41
1504 forum posts
142 photos
Posted by David Standing 1 on 20/06/2017 19:37:11:
After 6 years? I think not disgust
Stewart Hart21/06/2017 09:53:19
674 forum posts
357 photos
Make your own:- any one with a half decent kit should have no trouble in making it
Its based on the American Eagle 66 can of 1900 vintage it uses 2" ally tube for the body, and you can make the nozzle to suit your application. I've had mine in regular use for 6 months now and it works perfectly with no leaks, far better than the Railing can that I bought and ended up bending the lever.
I've dawn it up and submitted an article to Neil that hopefully he will publish.
Cheers
Stew
Michael Gilligan21/06/2017 10:19:35
23121 forum posts
1360 photos
Looks good, Stew
ega21/06/2017 10:31:33
2805 forum posts
219 photos
Stewart Hart:
I, too, bent the lever on my Reilang but mine had a hydraulic connector. So far as I can see the lever is not available as a spare.
My Wanner with plain nozzle for the Myford oil nipples is just about usable.
I look forward to your article.
Howard Lewis21/06/2017 21:26:40
7227 forum posts
21 photos
My Myford oil gun, (expensive I thought) was very good at oiling everything; except the lathe. Bought an even more costly Reilang, which had the advantage of doing what I wanted it to, and has continued to do so for many years, even when used at strange angles. And, no my lever has never bent!
