Andrew Tinsley | 15/06/2017 18:08:31 |
1817 forum posts 2 photos | I purchased a beautifully made linisher some 35 years ago! It doesn't have a stand or motor. I have sourced a new 1/3 HP two pole motor and I have a frame from the scrap box, so all I need is a switch, belt, 2 pulleys and a guard. So my query is what should be the optimum speed of a linisher belt? Knowing this, I can source the correct pulley ratio that is needed. Feet per second is the desired quantity or indeed metres per second! Thanks in advance, Andrew. |
Clive Foster | 15/06/2017 19:34:01 |
3630 forum posts 128 photos | 3M reckon around 20 to 25 m/s, say 3,500 to 4,500 ft / min in round numbers, for theirs but they claim much better abrasive performance than other makes. RJH give 6.5 m/s, 1,200 ft / min in round numbers as the belt speed for their Antelope band facers. As I recall matters their simple flat style bench mount linishers used a 1:1 pulley drive with a 1,440 rpm motor. Not sure on roller diameter. Probably 3 1/2" or 4" so 1,300 to 1,500 ft / min. Picador used to recommend a 1:1 pulley driver ratio when using a 1,440 rpm motor on their machines whose roller diameter was around 3" if I recall correctly. Comes out to around 1,130 ft/min. 1:1 drive worked fine for me on my Picador. So somewhere around 1,000 to 1,500 ft/min should work OK. Given the choice I'd go towards the low end. Clive. |
Ian P | 15/06/2017 19:38:59 |
![]() 2747 forum posts 123 photos | I imagine the best belt speed varies with the job material and the type of abrasive. I do have the luxury of my linisher being driven by a variable speed motor and do frequently adjust the speed to suit what I am doing. At low speed with say, a fine belt its possible to get a part to a precise shape or thickness and keep the surface flat and square. You can probably do a quick calculation of what ready built linishers operate at just by seeing the motor speed rating plate and guestimating the pulley diameter. IanP |
Andrew Tinsley | 15/06/2017 20:09:13 |
1817 forum posts 2 photos | Hello Ian, I don't have the luxury of a variable speed motor, so I am stuck with what I have, a 2 pole 2880 rpm motor! Thanks Clive, sounds as if I should go with around 1250 feet per minute. Now to go and find the diameter of the rollers! Thanks all, Andrew. |
Ian S C | 16/06/2017 03:11:17 |
![]() 7468 forum posts 230 photos | not sure of the surface speed, but a belt sander is avialable to attach to a bench grinder(6" or 8" Ian S C |
thaiguzzi | 16/06/2017 06:12:07 |
![]() 704 forum posts 131 photos | Industrial linishers were generally or very close to 1:1, using 3000 (2850) rpm motors. Wheels generally around 10". |
Journeyman | 16/06/2017 09:22:12 |
![]() 1257 forum posts 264 photos | I have a Warco BDS460 belt sander / linisher. The motor runs at 2850rpm and drives a 60mm dia roller at 1:1 I dug out my old calculator and worked out that this is a belt surface speed of about 9m/s or roughly 1800ft/min John |
Andrew Tinsley | 16/06/2017 11:19:28 |
1817 forum posts 2 photos | Thanks everyone, I should have enough info now, great helpful bunch on this forum! Andrew. |
Martin Connelly | 16/06/2017 18:17:27 |
![]() 2549 forum posts 235 photos | Our work linishers have 2 speed 3 phase motors directly driving 200mm drums with a small degree of crowning. I have not looked at the motor speeds. Martin C |
Martin Connelly | 19/06/2017 13:17:52 |
![]() 2549 forum posts 235 photos | I have checked the (Marpol) manual for an industrial linisher and it has speeds of 16.5 and 33 metres per second using a 3.37 kW motor running at 1400 and 2800 rpm. Martin C |
