Bandsaw will not run.
Ian Usmar | 21/05/2017 22:21:51 |
71 forum posts 10 photos |
Dear All, Me again I have got to the bottom of my issues re back gear etc but today I put it all back together only to find now when I try to start it it pops my fuses. Everything turns by hand but with power them Pop. So what have i done to cause this issue. The only thing I have done that could be an issue is a small oil leak from the gear box which dripped onto the motor this was quickly cleaned up. Any suggestions would be appreciated before I head back to the workshop to strip it all back down. Regards Ian
Frances IoM | 21/05/2017 23:00:33 |
1395 forum posts 30 photos | what 'pops' ? the current trip or the earth leakage ? If you rely on fuses and they blow then possibly you have a miswired motor or even an oil induced leakage across the power lines (tho here I would expect to see smoke) - if earth leakage then possibly your oil leak has caused some leakage path |
roy entwistle | 22/05/2017 08:37:27 |
1716 forum posts | Oil is usually an insulator, used extensively in HV trasformers Roy |
Ian S C | 22/05/2017 12:03:27 |
![]() 7468 forum posts 230 photos | Does the motor run if you remove the belt? Ian S C |
OuBallie | 22/05/2017 13:48:58 |
![]() 1181 forum posts 669 photos | Posted by roy entwistle on 22/05/2017 08:37:27:
Oil is usually an insulator, used extensively in HV trasformers Roy Plus in OCBs (Oil Circuit Breakers) Geoff - Contracts engineer with Reyrolle Parsons SA. |
Ian Usmar | 28/05/2017 21:26:05 |
Many thanks to you all must have been a gremlin. I stripped it down worked ok put back together still working ok. Again many thanks to all
