john dakin | 14/05/2017 18:31:09 |
44 forum posts 2 photos | I just bought this set of taps and dies and dont know anything about this type of die handle, can anyone help on use of them, and what are they called,and are they any good, thought they were cheap at £15 Edited By john dakin on 14/05/2017 18:32:00 |
vintagengineer | 14/05/2017 20:31:14 |
![]() 469 forum posts 6 photos | They are very good as you can adjust the dies over quite a range. To cut a standard size thread, set them slightly oversize on a standard bolt then cut the thread and try a nut on it, if it is too tight, make an adjustment and take a second cut. |
john dakin | 14/05/2017 20:40:01 |
44 forum posts 2 photos | Great, thanks for the information |
Neil Wyatt | 14/05/2017 20:43:50 |
![]() 19226 forum posts 749 photos 86 articles | The actual cutters are called Coventry Die Heads and come in matched and numbered pairs, make sure they are both of a pair and the right way up. I have a very big one of these and just two mismatched die heads - ho hum (but it only cost me 560p at a boot sale). Neil |
Andrew Johnston | 14/05/2017 21:01:47 |
![]() 7061 forum posts 719 photos | Posted by Neil Wyatt on 14/05/2017 20:43:50:
The actual cutters are called Coventry Die Heads and come in matched and numbered pairs, make sure they are both of a pair and the right way up. Never heard 'em called that before; definitely not what I thought a Coventry Diehead looked like. Here's an interesting quote from a book I have on screw threads: "The old-fashioned stock holding a pair of dies fed together by a screw has been largely supplanted by the more modern types, which have been dealt with, but it is a strong tool adapted to hard working, and variations in fit are easily obtained." The book, written by F. J. Camm, was published in July 1942. Andrew
NJH | 14/05/2017 22:07:34 |
![]() 2314 forum posts 139 photos | Coventry die heads shown here :- **LINK** (In the middle of the page)
Norman Edited By NJH on 14/05/2017 22:09:03 |
Georgineer | 14/05/2017 22:44:54 |
652 forum posts 33 photos | One advantage of the two-part die is that you can slide it part way down the rod and start with a light cut, which reduces the risk of a drunken thread. Geo. |
Sandgrounder | 15/05/2017 07:44:48 |
256 forum posts 6 photos | Posted by Georgineer on 14/05/2017 22:44:54:
One advantage of the two-part die is that you can slide it part way down the rod and start with a light cut, which reduces the risk of a drunken thread. Geo. And if you have a bolt with a damaged thread at the beginning you can slide the dies past it and work backwards. John |
roy entwistle | 15/05/2017 09:01:53 |
1716 forum posts | They are certainly not Coventry die heads. Dies where probably made like that before Coventry die heads where invented. My father had a set and as I recall the taps and dies had a thread of their own ie neither Whit nor BSF possibly pre 1900 Roy
John Haine | 15/05/2017 09:26:40 |
5563 forum posts 322 photos | Must be challenging to manufacture - made in one piece as a pair then separated perhaps? |
Tim Stevens | 15/05/2017 10:31:38 |
![]() 1779 forum posts 1 photos | One advantage of the type of dies shown is when working on proper English motor bicycles or cycles. Any damage to the cycle-thread components needed only one set of dies - 26tpi, unless you were very unlucky. Regards, Tim |
Andrew Johnston | 15/05/2017 10:41:09 |
![]() 7061 forum posts 719 photos | Posted by NJH on 14/05/2017 22:07:34:
Coventry die heads shown here :- **LINK** (In the middle of the page) At last count I had eight Coventry dieheads of assorted sizes. I use the smaller ones mainly on the repetition lathe. Rather than clutter up this thread I'll post a picture of a less common diehead to see who knows what it is for. What puzzles me about the original tap & die set is that the diestocks, dies and box seem nicely made. But the taps seem to be black? Which indicates to me cheap carbon steel. It would be useful to know what thread sizes are covered. Andrew |
SillyOldDuffer | 15/05/2017 10:50:49 |
10668 forum posts 2415 photos | What is the proper name for that type of cutter? My Newnes Engineer's Reference Book calls the usual type Round or Bottom dies. It mentions Spring and Prong dies 'capable of fine adjustment' but doesn't describe them. Could John's picture be of Prong dies or are they something else again? Dave |
ega | 15/05/2017 11:22:19 |
2805 forum posts 219 photos | Tom Senior 1939 catalogue calls them "Angle Pattern Stocks & Dies" but this name doesn't really address their two part construction. They are shown alongside the more usual "Moorite" split circular dies. It seems to me that the two part construction if well done would be superior in use to the split circular. Edited By ega on 15/05/2017 11:22:36 |
Ian S C | 15/05/2017 13:54:10 |
![]() 7468 forum posts 230 photos | In my set The dies and taps are carbon steel. Ian S C |
john dakin | 16/05/2017 08:18:41 |
44 forum posts 2 photos | Thanks to everyone for your input and information, its good to know about this |
