Dave T | 23/04/2017 20:44:27 |
69 forum posts 1 photos | Hi Guys, I purchased a couple of meters of this: http://www.ebay.co.uk/itm/Brammer-Type-Link-Belting-Section-13mm-Machine-Drive-Belt-Nut-Link-Style-Belt-/251903563785?hash=item3aa69f5809 for my Warco VMC - Feeling rather stupid, can anyone tell me how to split and reconnect, I've been fiddling around with it for a while now and cannot think of any to split it without using a knife! There must be some trick that I'm missing. Thanks in advance |
Ian Parkin | 23/04/2017 21:05:05 |
![]() 1174 forum posts 303 photos | Don't the link steel bits twist and then you can slip the links off and then after reassembling twist them 90 degrees to lock? |
Ian Parkin | 23/04/2017 21:07:01 |
![]() 1174 forum posts 303 photos | Sorry just looked at the image you just bend the belting hard back on itself and the links separate...its quite hard to do this |
David Standing 1 | 23/04/2017 21:35:06 |
1297 forum posts 50 photos | Posted by Ian Parkin on 23/04/2017 21:05:05:
Ian That's NuTLink type belting |
David Standing 1 | 23/04/2017 21:39:33 |
1297 forum posts 50 photos | Dave You push a link towards the next one (compress the belt) so the pin pushes through the split part into the hole, and twist the stud out of the hole. My Dad showed me how to do this in circa 1966, so apologies if my memory is a bit hazy |
Dave T | 23/04/2017 22:07:48 |
69 forum posts 1 photos | Thanks guys, I shall have a play - the rivets seem to be quite tight, but then it is new belt, so it'll probably be a bit stiff Many thanks for the replies - I shall report back |
Robbo | 23/04/2017 22:42:34 |
1504 forum posts 142 photos | Dave, The other Dave has the principle right, but with a new belt it is stiff and unyielding. Try turning the belt "inside out", so the radius of the curve is on the inside, when the pin will naturally be nearer the slot. You may then be able to poke a blunt instrument into the resulting gap in front of the pin and push it along. You will see that on the joining part of the link there are 3 holes with the belt slit between them. The problem is you need to get 2 pins into each link, as the links overlap by 3. Put on some gloves and give the links a good wiggling about to soften them a bit. You may need to resort to clamping in a vice to give you 2 hands free. Like riding a bike, (or folding a bandsaw blade) once you've done it it's easy! |
Speedy Builder5 | 24/04/2017 06:46:34 |
2878 forum posts 248 photos | For a new belt, I push a small flat screwdriver (2mm dia) through the belt to "Tyrelever" the joint apart. Same for putting it back again. |
Ian S C | 24/04/2017 11:28:05 |
![]() 7468 forum posts 230 photos | As BobH says a small screw driver is handy, once you get the hang of it, it's quite easy. Ian S C |
Dave T | 25/04/2017 21:31:22 |
69 forum posts 1 photos | All done, thanks again guys It's amazing how easy it is when you practice doing it - I feel a bit of a git now though Cheers Dave |
NJH | 25/04/2017 23:08:35 |
![]() 2314 forum posts 139 photos | No need to feel a "git" Dave.... The only git is the man who doesn't know the answer but refuses to ask for help! Norman |
john fletcher 1 | 26/04/2017 08:34:33 |
893 forum posts | If you go to the local museum and borrow a button hook. They are like a screw driver with a bent up three quarters of a circle on the end. You slip the end piece thorough one of the slits and hook the tool end around the stud below the slit, the turn the tool. Easier to actually do than to write about. We had lots of it for generators and compressors we also had Fenner belts as well. I think Brammer is or was made in Bradford and Fenner in Hull. John |
Ian S C | 26/04/2017 12:44:05 |
![]() 7468 forum posts 230 photos | A pair of 6" needle nose pliers can be usefull. The more modern types are a little easier, I use the stuff that has no rivets these days. Ian S C |
Niels Abildgaard | 26/04/2017 17:17:33 |
470 forum posts 177 photos | Are Brammer belts better than Powertwists from Fenner?
Ian S C | 27/04/2017 11:10:19 |
![]() 7468 forum posts 230 photos | I'v used Brammer, NuTLink, and Powertwist in that order, and I think I would rate them in that order, Powertwist at the top. Having said that, the last lot of Powertwist I got was not by Fenner, and it took quite a while to bed in, and for the first few hours it would only transmit about half power, but it only cost about 1/3rd of the real stuff, and it's ok now. Ian S C
