mick H | 15/04/2017 16:55:03 |
795 forum posts 34 photos | Not for the first time I am having a bit of an issue with allegedly stainless steel balls in a loco safety valve. May be just a bad batch......but has anyone tried out ceramic ball bearings in this sort of application? A quick Google of their properties seems to indicate that they would be just the job. Mick |
richardandtracy | 15/04/2017 18:18:17 |
![]() 943 forum posts 10 photos | In one of LBSC's articles he suggests putting a ball in the safety, then giving it a sharp strike to bed the valve in. Not sure what would happen with a ceramic.. Apart from that, could be a workable idea. Richard
julian atkins | 15/04/2017 22:04:08 |
![]() 1285 forum posts 353 photos | Hi Mick, Yes, excellent results with the ceramic balls on check valves. Am sure they would be just as good in a safety valve apllication.. Cheers, Julian |
Windy | 15/04/2017 22:57:06 |
![]() 910 forum posts 197 photos | I use stainless valve bodies and balls on my flash steamer and apart from a bit of dirt now and then they have been good. The one thing I always check are the stainless balls 316 some of the other stainless balls materials are more magnetic and get a dark gunge colour after a short run in my application.
Hopper | 16/04/2017 00:15:36 |
![]() 7881 forum posts 397 photos | Have you tried stainless balls from a good brand name bearing supplier such as SKF? Not all balls are created equal, specially those cheapies off the net or through intermediate suppliers for "hobby" use which sometimes seems to mean not the absolute top-of-the-line professional quality gear (with matching price of course). |
HOWARDT | 16/04/2017 09:15:31 |
1081 forum posts 39 photos | Years ago used glass balls in place of stainless steel in high pressure check valves, 2500 psi. This was because the material passing through eroded the ball and the glass lasted much longer. |
john carruthers | 16/04/2017 13:14:19 |
![]() 617 forum posts 180 photos | Edmund Scientific do ruby and quartz balls in various diameters, surprisingly cheap considering they are of optical surface quality. |
martin perman | 16/04/2017 13:57:23 |
![]() 2095 forum posts 75 photos | The only issue I have with ceramic balls is that they are prone to pick up any impurities and end up with "crystals" growing on them from what ever is in the water stopping the valve from seating properly. The valves we use at work have to have the balls soaked in a mild acid to remove anything which has grown as a maintenance check. Martin P |
mick H | 16/04/2017 14:00:31 |
795 forum posts 34 photos | Thanks for those comments gents. It sounds as if they are worth a try. Mick |
mick H | 16/04/2017 14:06:12 |
795 forum posts 34 photos | John.....I have just had a look at the edmund scientiic site.....what am I looking for? Are they lenses? Mick |
Keith Long | 16/04/2017 14:42:12 |
883 forum posts 11 photos | Mick - look for "ball & condenser lenses" |
