Jens Eirik Skogstad | 07/04/2017 17:31:08 |
![]() 400 forum posts 22 photos | Hi folks! I created the gas stop valve and gas attenuator. But the problem is teflon/PTFE sheet is noe easy to buy in Norway. Can i use the thin silicone sheet as diaphragm cut from the silicone form for baking who is sold by kitchen shop? The silicone seem soft and strong material and can withstand up to 250 degree Celsius/482 degree Fahrenheit. Or must it be teflon/PTFE sheet as diaphragm?
Edited By Jens Eirik Skogstad on 07/04/2017 17:33:48 |
JohnF | 17/04/2017 00:34:20 |
![]() 1243 forum posts 202 photos | Cant answer your question Jens but this will bump it to the top again ! |
Brian Baker 1 | 17/04/2017 08:31:10 |
![]() 229 forum posts 40 photos | Greetings Jens, I think that PTFE sheet can be purchased on Ebay, and I trust you can access that site. Regards Brian |
John Haine | 17/04/2017 08:54:37 |
5563 forum posts 322 photos | I'd have thought that silicone would be better than ptfe, the latter is not very strong but silicone is very hard wearing. |
Neil Wyatt | 17/04/2017 09:40:04 |
![]() 19226 forum posts 749 photos 86 articles | Not sure of your application, but LPG regulators in cars use thin rubber sheet. They potentially run at 100 degrees (heated by engine coolant) although the LPG evaporating takes the edge off that. Neil |
Ian P | 17/04/2017 10:11:23 |
![]() 2747 forum posts 123 photos | I would have thought that the selection of diaphragm material and thickness would be dictated by the pressures involved and the mechanical design (diaphragm diameter and deflection distance) You have not given any indication of the purpose (is this a gas flow regulator?) so I'm only speculating. If you need PTFE or silicone for their chemical resistance then it possible that you could use a metal diaphragm for its mechanical strength but have a thin plastic membrane clamped on the face that is in contact with the media. Ian P |
Keith Long | 17/04/2017 10:26:37 |
883 forum posts 11 photos | Jens - you don't say what thickness of ptfe you need but Direct Plastics list sheet down to 0.25mm. The smallest piece that they show on their website is 300mm square at £1.70 + vat. I would have thought if that material is suitable getting them to post it to Norway should be possible. I've bought from Direct plastics in the past and found them very easy deal with. Keith |
