Nick_G | 13/03/2017 16:55:02 |
![]() 1808 forum posts 744 photos | . I may 'want' one but the reality is I don't have the room or the money.! Went to my mates today to get some keyways slotted into the hubs of some flywheels. I also asked him could I use one of his lathes that would take a piece of cast iron I have for the cylinder liner up its spindle bore so I could drill it out to something that I could later fit a bar through when it come time to line bore it. He pointed to a Colchester Triumph 2000 half hidden under a mountain of swarf and said that ain't being used at the moment so go ahead. Now this lathe has seen better days. But it was a dream to use. Solid, smooth and drilled a 38mm hole through this 200mm length of cast iron like a hot knife through butter. Not a single kick or flinch and did not make a single noise higher than when it was just turning over. - I suppose the quality of his drill bits, the edge he grinds on them and that cast iron is not the hardest of materials contributes. ............ But still I was impressed.! On departing I said to him that next time I had a free day I was going to come down with a gallon of paraffin and give the thing a damn good cleaning. He replied. "Will you heck Anyway, I guess the saying that 'the heavier a machine is the better' carries some. ............. weight. Nick |
JasonB | 13/03/2017 16:57:33 |
![]() 25215 forum posts 3105 photos 1 articles | Did you not ask him if it had a 4-jaw big enough to take your hopper |
Nick_G | 13/03/2017 17:02:52 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 13/03/2017 16:57:33:
Did you not ask him if it had a 4-jaw big enough to take your hopper . Yeahh, he has. - Why what would your plan be.?
Nick |
JasonB | 13/03/2017 17:18:12 |
![]() 25215 forum posts 3105 photos 1 articles | Well assuming he has a big boring bar to match you could just bore it in the lathe |
Nick_G | 13/03/2017 17:47:48 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 13/03/2017 17:18:12:
Well assuming he has a big boring bar to match you could just bore it in the lathe . He did tell me he had some very big boring bars with some kind of special damping on the heads. ??? But I also liberated him of a couple of meters of steel to make a line boring bar out of. - Never done that so really would like to give it a go. (although I may regret it) Nick |
Allan B | 13/03/2017 19:46:08 |
![]() 133 forum posts 23 photos | I do like the big Colchester lathe's, dream to work on, and as you said heavy enough to not move no matter what you put in it
I have to admit to keep looking at them on ebay, as for space, I would make the space
Allan |
Chris Evans 6 | 13/03/2017 20:15:20 |
![]() 2156 forum posts | I used a Triumph 2000 at work before I retired, I was not a full time turner as it was a jobbing shop most of my time was on a mill or spark erosion machine. The Triumph was a nice machine to use, worn when I started there and completely knackered 15 years later when I left. Typical of a lot of companies they would not spend any money on the machines to keep them in good order. |
Tony Ray | 13/03/2017 22:07:47 |
238 forum posts 47 photos | The Triumph 2000 is a serious bit of kit; my dad used one as a toolmaker 7.5 horsepower if I remember correctly. He was a watchmaker so used to working to tight limits. he said it was his favourite machine in the workshop. |
larry Phelan | 19/03/2017 17:11:03 |
![]() 544 forum posts 17 photos | I also would like a bigger and better lathe,so, why dont I buy one? Simple,I dont think I,d know how to use it ! I have a small 6" Chinese job [ex Chester ] which does all I know how to do,no point in buying something better and maybe wreck it. 7.5 HP is a fair load for a home workshop,not sure your nabours would love you when you switch that on ! |
Nick_G | 19/03/2017 23:59:16 |
![]() 1808 forum posts 744 photos | Posted by larry Phelan on 19/03/2017 17:11:03:
not sure your nabours would love you when you switch that on ! . If they are in good order a big lathe is virtually silent.
Nick |
Nick Hulme | 20/03/2017 01:29:19 |
750 forum posts 37 photos | Bigger lathes are for bigger work, if you upgrade to something too big you will lose top end speed and will find your capability for smaller work degraded, - Nick |
Simon0362 | 20/03/2017 13:18:12 |
279 forum posts 91 photos | Nick, Maybe this one would be suitable for you - Dean, Smith and Grace, one careful owner (and a number of very careless ones). I am sure that the working surfaces are pristine under the coating of what looks like emulsion paint.....
(more photos in my album, sorry one is upside down but I can't see a way to invert it using the site software) Spotted last year in a place that recycles building materials, so somewhat out of place in the sets of railing, shutters and second hand windows. Located on the outskirts of Aix en Provence - goodness knows what n°191 was doing here in the first place, but I suspect I can see its eventual destination. Simon Edited By Simon0362 on 20/03/2017 13:20:36 |
