Maurice | 09/03/2017 16:32:38 |
469 forum posts 50 photos | I am in the process of selling a set of Stuart Turner model centrifugal pump castings on eBay. In case the buyer is interested, I am including copies of the picture shown here. They are so nice I thought I would share them. I really like colour washed drawings. The engine is similar to one that Stuarts produced in, I think, the 1980's. It only had a bore of about half an inch. It was called "The Meteor" I think.I don't think it sold well. |
Peter Krogh | 09/03/2017 18:20:54 |
![]() 228 forum posts 20 photos | I've seen a lot of cent. pumps but never one with an intake arranged like that one!! Great illustration... Pete
JasonB | 09/03/2017 18:42:10 |
![]() 25215 forum posts 3105 photos 1 articles | Thanks for those Maurice, is there also a working drawing for the pump? As Peter says I've not swwn one with that sort of inlet that seems to supply both sides of the impellor.
Just been working on a small centrifugal pump myself but teh usual arrangement of one central inlet. |
JA | 09/03/2017 19:26:36 |
![]() 1605 forum posts 83 photos | The centrifugal pump on the Easton, Amos & Sons drainage machine has a double entry. The pump shaft is vertical and the intakes to the pump are set as low as possible. At low water levels the top intake duct is a syphon. JA Edit: see www.wzlet.org Edited By JA on 09/03/2017 19:29:47 |
Maurice | 09/03/2017 19:40:07 |
469 forum posts 50 photos | There is no section of the pump I'm afraid, just a general view which I have posted here. As you will see from the text, it is an extract from a text book on engineering drawing. |
Reg Rossiter | 09/03/2017 19:40:32 |
![]() 29 forum posts | What many people may not appreciate is that even now you can usually find a steam up and downer stripping pump and steam turbine driven cargo pumps in many petroleum tankers. I'm talking ships here, not trucks. Double inlet pumps are the norm in large sizes. They aid throughput and balance axial forces. As for the use of steam, steam stripping pumps are safe in a potentially hazardous environment where you don't want electricity. Cargo pumps usually have their prime mover outside the pump room, in the engine room. Steam turbines are often used because that puts load on the boilers to produce plenty of inert gas for blanketing the cargo tanks as cargo is discharged. Electric drives can be used but then you may need a separate inert gas generator. Reg |
Peter Krogh | 09/03/2017 20:30:20 |
![]() 228 forum posts 20 photos | Thanks for the cool info, Reg!! It all makes sense of course... Pete |
Nicholas Farr | 09/03/2017 21:27:54 |
![]() 3988 forum posts 1799 photos | Hi, I used to maintain centrifugal pumps with this type of intake back in the early 1970's. They were made by a company called Uniglide, who are still making pumps I believe, they were similar to the ones in the illustration below and were driving by an electric motor, like the one in the middle. I can't remember working on any Gwynnes pumps myself, but the Uniglide ones were all replaced by the beginning of the 80's, mostly by submersible ones as they suited the companies needs and needed less maintenance was required. The Uniglide's did however shift huge amounts of water and had bronze impellors and they were all 6 inch.
Regards Nick. Edited By Nicholas Farr on 09/03/2017 21:40:56 |
Maurice | 09/03/2017 23:15:20 |
469 forum posts 50 photos | Here is another colour washed plate from the drawing text book, a duplex steam feed pump this time. Another fine example of the art I think. |
Peter Krogh | 09/03/2017 23:21:49 |
![]() 228 forum posts 20 photos | OK, now you've gone and confused me even more.... the steam pump. Why are there two steam ports for each end of the engine??? I've never seen that before! Thanks, Pete
JA | 09/03/2017 23:39:54 |
![]() 1605 forum posts 83 photos | I have just read the script of the picture in Maurice's second posting. Should we be having a go at the exam questions?? JA Edited By JA on 09/03/2017 23:40:50 |
Paul Kemp | 10/03/2017 00:26:46 |
798 forum posts 27 photos |
Two steam ports, one inlet, one exhaust. The outer ones are the inlets and inners the exhaust (exhaust goes to cavity under the valve, inlet is exposed by the valve to the steam chest). Paul. |
duncan webster | 10/03/2017 00:57:14 |
5307 forum posts 83 photos | Posted by Peter Krogh on 09/03/2017 23:21:49:
It's to provide cushioning. If we count from the left, ports 1 and 5 are to convey steam to the cylinder, ports 2 and 4 are for exhaust to release from the cylinder to the cavity under the valve, and the one in the middle, port 3 lets the exhaust out from under the valve to the outside world. Thus as the piston approaches the cover, the exhaust is shut off before it hits, and the trapped steam is compressed to cushion the piston. You can't put steam down ports 2 & 4 as they are blocked off by the piston at top/bottom of stroke. Remember there is no con rod/crank assembly to limit the stroke. |
Peter Krogh | 10/03/2017 05:30:31 |
![]() 228 forum posts 20 photos | Thank you Paul and Duncan! As soon as I read "...to cushion the piston." it was one of those 'duh slap the forehead' moments. That feature prevents knocking the heads off with a flying piston! Another learning moment brought to me by this Model Engineer Board. Pete
