I c engine ignition
trev | 07/03/2017 19:25:18 |
8 forum posts | can anyone out there suggest what ignition system to use on a model I c engine apart from the buzz coil |
Andy Holdaway | 07/03/2017 19:39:31 |
![]() 167 forum posts 15 photos | These work well, I've used them in model aeroplanes as well as fitting one to a model stationary engine, although it's probably overkill for the stationary engine. A small motorcycle coil and points seems to work just as well, but the one linked to can run off a small battery pack. Andy |
JasonB | 07/03/2017 19:46:51 |
![]() 25215 forum posts 3105 photos 1 articles | What is the engine, some of the ones that they suggest a buzz coil for do not work so well on a single spark, the buzz type proveides a series of sparks over a longer period of time which does suit some of the slower running designs. Watch some of the RC engine ones as they often have auto advance and get confused ifused on teh timing gear of a 4-stroke rather than straight off the crank of a faster reving two stroke. I mostly use the ignitions from S/S in the States but teh small cdi from Minimag here in teh UK is said to be good.
JasonB | 07/03/2017 20:50:10 |
![]() 25215 forum posts 3105 photos 1 articles | I have also got one of these on its way to me, worth having a play as they are only a few quid |
Neil Wyatt | 07/03/2017 20:54:19 |
![]() 19226 forum posts 749 photos 86 articles | > one of these on its way to me Source? |
Nick_G | 07/03/2017 21:10:02 |
![]() 1808 forum posts 744 photos | Posted by trev on 07/03/2017 19:25:18:
can anyone out there suggest what ignition system to use on a model I c engine apart from the buzz coil . What engine is it for.? I did use recently a CDI unit from S/S on a Hogglet that Jason suggested. It worked well, and a good company to deal with.
Nick |
Andy Holdaway | 07/03/2017 21:12:14 |
![]() 167 forum posts 15 photos | The 3 to 6v 'death box' that Jason posted looks like the innards out of a Tazer - nice! |
Nick_G | 07/03/2017 21:51:36 |
![]() 1808 forum posts 744 photos | Posted by Andrew Holdaway on 07/03/2017 21:12:14:
The 3 to 6v 'death box' that Jason posted looks like the innards out of a Tazer - nice! . Excellent.
Nick |
I.M. OUTAHERE | 08/03/2017 05:42:46 |
1468 forum posts 3 photos | Posted by Neil Wyatt on 07/03/2017 20:54:19:
> one of these on its way to me Source? I typed in high voltage coil on ebay , lowest price first and a whole pile of them appered on my screen ! I don't know how long they would last on an engine and getting the dwell angle correct to get the coil to charge fully may be an issue on higher reving motors but for a couple of bucks its worth trying . |
joey | 08/03/2017 05:49:21 |
![]() 31 forum posts | Edited By joey on 08/03/2017 05:54:29 |
joey | 08/03/2017 05:53:03 |
![]() 31 forum posts | Posted by joey on 08/03/2017 05:49:21:
QUOTE Posted by JasonB on 07/03/2017 19:46:51:
QUOTE; Minimag here in teh UK is said to be good.
I use the minimag electronic system on a vintage 3hp 1929 Witte engine. It is excellent.
Edited By joey on 08/03/2017 05:56:13 |
Neil Wyatt | 08/03/2017 07:02:13 |
![]() 19226 forum posts 749 photos 86 articles | Two different types ordered, they would suit a simple spark erosion device. |
JasonB | 08/03/2017 07:37:28 |
![]() 25215 forum posts 3105 photos 1 articles | From E-bay, where else I have also got a couple of the gas lighters that Jan Ridders uses to make small ignitions but not tried them on an engine yet but they are very compact and give a good spark. I should have said that S/S do an electronic version of a buzz coil, it is on the site I linked to. If you want traditional Buzz coils then Engineers Emporium do them and will also supply just the traditional contacts if you want to make your own which works out a lot cheaper. |
trev | 20/03/2017 18:59:47 |
8 forum posts | Thanks for all the replies to my query about ignition systems I will look at some of links ,I have used a cdi ignition unit for rc models and that works quite well |
