Roderick Jenkins | 03/03/2017 17:04:17 |
![]() 2376 forum posts 800 photos | There is a Murad Bormilathe lurking on ebay at present **LINK** I have no connection whatsoever with the vendor, just a heads up for the lathe buffs (at the risk of upsetting anybody who has spotted it but is keeping a low profile) Rod |
ega | 03/03/2017 21:55:59 |
2805 forum posts 219 photos | I noticed this and thought it looked somewhat molested and incomplete. |
ega | 06/03/2017 16:32:59 |
2805 forum posts 219 photos | Apparently went for £470 so you were right that there would be interest in it. |
Eric Arthrell | 12/03/2017 11:03:24 |
47 forum posts 19 photos | Hello folks I purchased the Lathe delivery on Tuesday hopefully it will service my needs ,looking forward to having it. Regards Eric |
Michael Gilligan | 12/03/2017 15:44:42 |
![]() 23121 forum posts 1360 photos | Posted by Eric Arthrell on 12/03/2017 11:03:24:
Hello folks I purchased the Lathe delivery on Tuesday hopefully it will service my needs ,looking forward to having it. Regards Eric . Well done, Eric An interesting machine ... I look forward to your 'review' of it MichaelG. |
Neil Wyatt | 12/03/2017 17:41:54 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Eric Arthrell on 12/03/2017 11:03:24:
Hello folks I purchased the Lathe delivery on Tuesday hopefully it will service my needs ,looking forward to having it. Regards Eric Hello Eric, It's a fascinating concept, I hope you enjoy it and get good use from it. Neil |
Roderick Jenkins | 12/03/2017 18:23:35 |
![]() 2376 forum posts 800 photos | Yes, please keep in touch and let us know how you get on with this fascinating machine. Cheers, Rod |
Eric Arthrell | 15/03/2017 06:58:59 |
47 forum posts 19 photos | Thank you all for your interest and comments. The lathe arrived on Tuesday, the former owner as had the lathe for the last twenty years and has now moved up to a larger lathe. It was in far better shape than the flea bay photo's implied and came with 4 change gears, 3 of the guards and the lead screw dial. I shall give it a good clean check for wear and mount it on a bench and let you know how I get on and what needs attention. regards Eric
Michael Gilligan | 15/03/2017 07:19:56 |
![]() 23121 forum posts 1360 photos | Posted by Eric Arthrell on 15/03/2017 06:58:59:
... It was in far better shape than the flea bay photo's implied ... . That's a great start MichaelG. |
Eric Arthrell | 21/03/2017 06:33:22 |
Well so far so good. Seems to be in a fair condition ,I have not run it up properly as yet as I need to change the oil in the head stock bearing housing . The change gears that came with the lathe are 16DP whilst the gears on the lathe head are 12DP At the moment I am try to find out the details of the gear change banjo that was used on the lathe. The one thing that I can see being a pain is as both head and tail stock at movable in the vertical axis, is setting headstock to tail stock after any adjustment ,for this reason I have ordered a Dial Co-Axial Centering Alignment Indicator. This little lathe fits perfect in its new location, yes it was a good wedge but it is already keeping me mentally active ,I spent a good number of years as a maintenance fitter and coded welder so looking forward to making swarf in my sanity box. Regards Eric
Eric Arthrell | 27/03/2017 18:11:48 |
Made progress tweeked and cleaned all slides fitted new gib screws . One thing that is puzzling me is .according to literature the largest lead screw driven gear is 100t at 12dp this would give me a gear dia of 8.5 " it will not fit inside the guard case. The gears that came with the machine are 16dp, 100 teeth gear at 16dp =6.375 they will fit. I can only conclude that the spindle stud driver is at 16dp together with the rest of the change gears up to the lead screw and that the spindle gear driven is 12dp. does this seem logical? Regards Eric
Michael Gilligan | 27/03/2017 19:29:41 |
![]() 23121 forum posts 1360 photos | Posted by Eric Arthrell on 27/03/2017 18:11:48:
I can only conclude that the spindle stud driver is at 16dp together with the rest of the change gears up to the lead screw and that the spindle gear driven is 12dp. does this seem logical? . Very I guess you need to find some photos of the original. MichaelG. . Edit: Check out the penultimate photo on this page: http://www.lathes.co.uk/murad/page3.html Edited By Michael Gilligan on 27/03/2017 19:35:04 |
Eric Arthrell | 28/03/2017 07:03:33 |
47 forum posts 19 photos | Thank you for your reply Michael. Looking at the photographs visually, I think I am on the money and it is they way I will proceed . Regards Eric |
Eric Arthrell | 02/05/2017 22:58:11 |
47 forum posts 19 photos | Quick up date Chuck stuck fast, Working on change gears and banjo's to enable me to turn1-7/8"x 8TPI . Managed to source a 1-7/8" x 8tpi face plate, also most the change gears to enable me to turn the required thread form, if I have to turn the back plate off and turn a replacement. It will require a extra banjo due to the ability of the head stock to raise and lower. The compound slide as more slack than you no what so will need sorting. Was it worth it ? you bet first time my mind as been in overdrive for a long time . |
Hopper | 03/05/2017 00:04:16 |
![]() 7881 forum posts 397 photos | "Sanity box" luvvit. So true. Keep us posted on your project, sounds interesting. ISTR the son of chap who made the Bormilathe posted on this forum a few years back. Some interesting discussion of the old chap's colorful background. |
Speedy Builder5 | 03/05/2017 06:56:21 |
2878 forum posts 248 photos | Certainly an interesting lathe, but why were the headstock and tailstock moveable in the vertical plane/ If there were a slotted cross slide, I could see that the headstock travel would be good for milling. But as a lathe, once the headstock height was altered, then the lathe tool height would have to be changed on the saddle cross slide. Perhaps someone could enlighten me as to the usefulness of this lathe. |
Michael Gilligan | 03/05/2017 07:57:15 |
![]() 23121 forum posts 1360 photos | Posted by Speedy Builder5 on 03/05/2017 06:56:21:
Certainly an interesting lathe, but why were the headstock and tailstock moveable in the vertical plane/ If there were a slotted cross slide, I could see that the headstock travel would be good for milling. . Bob, There are some nice pictures of the slotted cross slide on the page that I linked previously. MichaelG. |
Speedy Builder5 | 03/05/2017 08:42:07 |
2878 forum posts 248 photos | MG |
Frances IoM | 03/05/2017 08:44:02 |
1395 forum posts 30 photos | look at name: BORe MIll LATHE explains a lot |
Ady1 | 03/05/2017 09:58:12 |
![]() 6137 forum posts 893 photos | The one thing that I can see being a pain is as both head and tail stock at movable in the vertical axis Once you find a fast solution to fixing this issue then it will become an annoyance of the past The only problem is that so few were made you are unlikely to ever have a Murad Bormilathe community to help you along with issues like this |
