51 x1/2 Bandsaw Tension
BOB BLACKSHAW03/03/2017 06:17:14
501 forum posts
132 photos
I have searched the forum for bandsaw tension but could not find the information needed. I am breaking my 51x1/2 bi metal and carbon steel blades. I have been told that I have not enough tension. I have read on line that you can't tighten the blade by hand enough, the plastic adjustment handle seems to turn on tension I feel is enough for a small blade, but I could get a lot moore. I've also been advised to loosen the blade when not in use. I don't like straining things and have a engineering feel, any advice please.
Thanks Bob
Speedy Builder503/03/2017 08:00:50
2878 forum posts
248 photos
What make and type of bandsaw, what size and type of material? Are you cutting straights or curves? Are you using coolant? What sort of pressure are you putting onto the blade? Perhaps a photo of your setup will help.
BobH
Howard Lewis03/03/2017 16:01:21
7227 forum posts
21 photos
Another, non My Time Media, UK, M E magazine had an article on making a tension meter, a few months back.
It used a DTI to measure the blade extension as it was tensioned. Other than the DTI and the Silver Steel pivot and a few small capscrews, it all came from a bit of square bar (15mm from memory)
I made one and used it to set blade tension on my elderly 4.5" bandsaw. Since then no broken blades, and seemingly improved accuracy. The first trial cut off a bit of 38mm round bar, suggested a variation on thickness of about 0,025mm on a 1.5mm thickness. But I don't expect that degree of accuracy!, purely a one off!
So, in my book it is a very useful, but rarely used, device.
Have you checked that all the guide rollers are correctly set and aligned?
The shorter the blade, the more sharply the blade twists as it enters or leaves the wheels. Before the 4.5" I had a little one, and was lucky to cut one piece of 38mm angle iron before the blade broke, despite being carefully set up. Needless to say that went back!
Neil Wyatt03/03/2017 16:44:30
19226 forum posts
749 photos
86 articles
I was advised by a seller to put on as much tension as I could with the hand knob.
If you put as much tension on it as a guitar's e-string the force would be about 3/4 of a ton ... in other words, you ain't going to snap it.
More important is getting the wheel tacking right and the guides properly adjusted.
vintagengineer03/03/2017 20:04:37
469 forum posts
6 photos
Which way round are you fitting the blade? is the drive pulley pushing or pulling the blade?
Neil Wyatt03/03/2017 20:21:38
19226 forum posts
749 photos
86 articles
This is the 'bible' for setting up hobby bandsaws: John Pitkin Bandsaw Guide
fizzy03/03/2017 20:34:51
1860 forum posts
121 photos
I was told tighten till it will twang like a banjo - works for me
Neil Wyatt03/03/2017 21:09:47
19226 forum posts
749 photos
86 articles
Posted by fizzy on 03/03/2017 20:34:51:
Agreed, that pdf I linked says 'if it rattles it's loose, it should make a musical note'.
N.
BOB BLACKSHAW04/03/2017 08:50:10
501 forum posts
132 photos
Thanks for these replies, I noticed that the break is on the weld. I've read the guide and will check the saw setup
Again Thanks
Bob
fizzy04/03/2017 09:01:47
1860 forum posts
121 photos
I had one break on the weld recently, I enquired with the seller as what I might do to avoid this, he replied that if it breaks on the weld then it is faulty and gave me a new one for free - nice chap.
Muzzer04/03/2017 10:37:57
2904 forum posts
448 photos
The only way to be certain is to set a suitable tension but as you can't directly measure the tension and the hand wheel stiffness will vary with lubrication, contamination etc, plucking the blade as Fizzy suggests is a good way to measure it indirectly. I set mine to give a tone that is probably not far off Middle C although I haven't checked precisely. Certainly, it's close to the limit of what can be achieved with bare hands on my Chinese 4x6 bandsaw using the small handwheel.
Murray
Speedy Builder504/03/2017 12:07:43
2878 forum posts
248 photos
If it breaks on the weld, anneal the weld before use (Like it should have been at the factory). On larger bandsaws where there is an incorporated butt welder, the weld is made and then slowly cooled to allow the joint to anneal. As others have said - It sounds like your blades are a poor quality. You could 'repair" your blades by making a silver soldered spliced joint.
BobH
Speedy Builder504/03/2017 14:09:05
2878 forum posts
248 photos
Ps - look up "Bandsaw blades" on this site.
BobH
Ian S C05/03/2017 09:52:23
7468 forum posts
230 photos
The instructions for my bandsaw say to tighten until the blade makes a musical note when plucked, they don't say which note, there is a B on the saw frame casting, so that will do.
Ian S C
Edited By Ian S C on 05/03/2017 09:53:56
