Arceuro stepper motor
Peter Bell15/02/2017 18:02:27
399 forum posts
167 photos
I need a stepper motor to fit a specific machine and unfortunatly it's been dicontinued by arceurotrade.
Its a model 160-010-00450 from there data sheet and is 75mm square x 85mm (Nema 34?) deep with a 10mm double spindle, 3.5Nm 1.8% step.
I cannot find one the same size anywhere so supect it may have been a special and just wondered if anyone had one laying about they didnt need?
Thanks
Peter
Michael Gilligan15/02/2017 21:12:48
23121 forum posts
1360 photos
Posted by Peter Bell on 15/02/2017 18:02:27:
Peter,
Please forgive me for 'correcting' your dimensions ... but I think it may help:
75mm square is not a standard NEMA frame size; so I had a look at the data-sheet:
http://www.arceurotrade.co.uk/projects/stepper/350Ncm%20Stepper%20Motor%20160-010-00450.pdf
... Try 85mm square x 75mm long and 1.8° step angle.
Iain Downs15/02/2017 21:23:58
976 forum posts
805 photos
Try these people, though I'm not sure they do a double spindle.
Iain
John Haine15/02/2017 22:17:17
5563 forum posts
322 photos
Zapp Automation are a reliable source for steppers and many other bits.
Peter Bell16/02/2017 08:40:04
399 forum posts
167 photos
Thanks everyone. I've looked around again and cannot see a 10mm shaft double ended motor. I rang Zapp and they have confirmed its a none standard motor especially with the shaft size but similar to a nema34.
I planned using a couple of pillar bearing and come out with a 10mm shaft to replace the motor and then just drive the shaft with a standard motor.
Before I do that I just wonderd if someone had bought a arceuro motor which was looking for a new home---you never know unless you ask!
Peter
Douglas Johnston16/02/2017 09:07:43
814 forum posts
36 photos
Hi Peter, I think I may have what you are looking for. I bought a stepper from Arceurotrade a while ago for a project that never came to pass and I think it is the size you are after, but will need to check (won't be able to check until this afternoon ) . It has been wired up and checked out but never used for any purpose so is in perfect condition.
Doug
Peter Bell16/02/2017 09:13:22
399 forum posts
167 photos
Brill, thanks Doug--fingers crossed!
Peter
Douglas Johnston16/02/2017 13:08:02
814 forum posts
36 photos
Hi Peter, I have dug out the motor and it is the size Michael quoted, ie 85mm square by 75mm long with 10mm dia double ended spindle. Is that the size you need? The only modification I made was to shorten the leads and fix the lead ends to a printed circuit board fixed to the end of the motor. If you are interested send me a pm off the forum and we can have a haggle. I can post a photo if that is any help.
Doug
Peter Bell16/02/2017 13:16:27
399 forum posts
167 photos
Hi Doug, That sounds the one! I got the sizes transposed! I'll pm
Peter
JasonB16/02/2017 13:16:44
Just a thought have you contacted Ketan direct? Some other members have been able to obtain items that they no longer list in that way. Possibly new old stock or ex demo.
Peter Bell16/02/2017 13:26:42
399 forum posts
167 photos
Thanks for the thought. Must confess I didnt contact Ketan direct but I did mail arceuro and they confirmed it was didcontinued with no stock so I thought that was it---unless they have something stashed away?
