previous article in ME
ian kingdon | 14/02/2017 11:56:52 |
5 forum posts | Ian A previous article in ME December 2000 pages 544-546, Yes that long ago! , I was constructing the electronic control from the circuit design and parts lists . After 2 completely new attempts, ie new components and boards, I could not get the motor to work. After checking(I am not an electrical engineer) I found that I had 14volts after the diodes but no further volts from thereon in. Has anybody used this design and can offer any ideas as to why it does not work, apart from the obvious that that I am at fault in some respect, and offer any suggestions for a possible commercial speed controller for a complete beginner that is easy to wire up any advice welcomed
John Purdy | 14/02/2017 23:23:04 |
![]() 431 forum posts 252 photos | Ian I have not built the circuit but looking at the schematic there appears to be two errors that would prevent it from working. The emitter lead of the 2n3055 transistor is not connected to anything, it should be connected to the minus power supply line at the bottom of the schematic. The diode (D1) at the collector of the 2n3055 appears to connected backwards. As shown it will not pass the plus voltage to the transistor. ( this would explain why you are not reading a voltage here.) John |
Ady1 | 15/02/2017 01:03:06 |
![]() 6137 forum posts 893 photos | ME4134 Edited By Ady1 on 15/02/2017 01:14:20 |
David Jupp | 15/02/2017 07:48:01 |
978 forum posts 26 photos | Posted by John Purdy on 14/02/2017 23:23:04:
Hmm - not sure about that aspect. Looks to me as though the current goes around the diode via the motor then the power transistor to reach negative rail (via the missing connection?). Replacing the diode the 'correct' way round would lead to release of magic smoke I fear. |
John Fielding | 15/02/2017 08:59:54 |
235 forum posts 15 photos | The only error with the schematic is that the emitter of the 3055 should be connected to the negative supply rail, the bottom line under the transistor. The diode connected to the collector of the 3055 is a catch diode which with the parallel capacitor serves to protect the transistor from back EMF transients generated by the switching due to the PWM signal applied to the transistor base. |
Graham Flavell | 15/02/2017 09:07:18 |
16 forum posts 17 photos | I agree with David. The diode D1 is there to protect the circuitry from back emfs generated by switching an inductive load (the motor) in the collector of the transistor. Connecting the emitter of the 2N3055 to the negative rail should do the trick. Presumably since this is a major omission a search of the following editions of ME would turn up a correction. It might be worth a look if you have them just in case there are other problems with the published circuit. Regards Graham |
ian kingdon | 15/02/2017 15:17:45 |
5 forum posts | Ian Gentlemen, thankyou for your immediate help, it is most gratifying to have an answer to my tweet(?) I will amend the circuit as you have all indicated and let you know the results I was not able to receive later editions of the mag. but corrections could have been made. Special thanks to Ady1 for the research to enable the diagram and article to be highlighted Regards to all Ian |
Graham Flavell | 15/02/2017 15:47:41 |
16 forum posts 17 photos | Ian Issue 4138 Page 64 carries the corrections. I don't have immediate access to my copy but someone else on the forum may have a better data retrieval system than mine! Regards Graham
Neil Wyatt | 15/02/2017 17:41:04 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Graham Flavell on 15/02/2017 15:47:41:
Ian Issue 4138 Page 64 carries the corrections. I don't have immediate access to my copy but someone else on the forum may have a better data retrieval system than mine! Regards Graham I was just about to type that there were corrections published... but I won't. Neil |
John Purdy | 15/02/2017 18:47:55 |
![]() 431 forum posts 252 photos | I fully agree with assessment that the diode is correct as published. After I wrote that I had second thoughts about my reasoning, as soon as the transistor was turned on there would be nothing to limit the current except the diode and transistor, and as David said probably accompanied by "magic smoke". Sorry about that. |
Ady1 | 15/02/2017 20:07:11 |
![]() 6137 forum posts 893 photos | |
Michael Gilligan | 15/02/2017 20:29:54 |
![]() 23121 forum posts 1360 photos | Well done, Ady1 MichaelG.
ian kingdon | 15/02/2017 21:22:29 |
5 forum posts | Ian thankyou Ady1, I will keep you all posted when I amend the circuitry and test. Fingers crossed Again, thankyou all Ian |
ian kingdon | 16/02/2017 10:38:37 |
5 forum posts | Ian Anybody who needs a simpler method of powering a cross slide might be interested in a further article I had in my files from way back. This method uses a secondhand car wiper motor or an electric window operator obtained cheaply from car breakers etc.The article was by David Machin in Model Engineer December 1994(yes, I know am going back but there are members, who like me are approaching 80 years and have accumalated lots of articles for when they retired. Iam only now finding the time " to get a round toit" |
Bazyle | 16/02/2017 12:57:58 |
![]() 6956 forum posts 229 photos | I have an MD65 but, until the batteries died, just used my drill with a socket that fitted the handle nut. My replacement drill because I hadn't got round to sorting the batteries has now died too. The problem with the circuit diagram is also that it is drawn cack-handed. The convention is input on the left and flow to the right and make sure your output stage switch doesn't look like it's upside down. It is one of the pitfalls when articles are introduced from another hobby/discipline - bit like seeing an electronics mag showing 'milling ' in a pillar drill. Hopefully our current editors take advice appropriately when straying from their specialisations. |
