Any recommendations
Alan Wood 4 | 08/02/2017 18:15:34 |
257 forum posts 14 photos | I need to acquire a small hydraulic platform trolley to move my 5" loco around in and out of the car etc. Weight probably around 50kg. The only one I can find to buy new is the Sealey 150kg. Has anyone experience of same or can recommend an alternative or has one lurking gathering dust ? |
clogs | 08/02/2017 19:23:37 |
630 forum posts 12 photos | Hi Alan, look on fleebay........so far I've found that the likes of Sealey operate a badge engineering formuler...... they buy the stuff in from the same people we can more or less but often double the price cos it's got their sticker on it.... No better built and from the same far eastern factory....... I know this as a fact because the very large motorcycle lift I bought was exactley the same at a tad over 1/2 the price and with courier delivery thrown in........ I do have a couple of supplers (for this kinda stuff) I use if you want the address's PM........ As for the job you want to do please buy something a little bigger than u need, not for strength but for stability...it all get's top heavy real quick when things start to go wrong.... good luck Clogs......... |
Martin 100 | 08/02/2017 19:31:31 |
287 forum posts 6 photos | I am looking for something similar myself for lifting engine blocks etc from near the floor to bench height. First thought was the Sealey ones but I also came across this company based in Bradford that possibly makes them in the UK (I'm not 100% sure on that) No connection etc |
John Reese | 08/02/2017 20:00:52 |
![]() 1071 forum posts | I purchased a 1000 lb. scissor lift table on casters several years ago. It is an Asian product and relatively cheap. It lifts high enough to reach the bed of my pickup truck and lowers to 9". When I made my work benches I made sure the stretchers were more than 9" from the floor. I use the table for unloading heavy items from the truck, getting heavy vises, etc., onto the mill, and for moving my workbench and surface plate stand around the shop. When my benches are cluttered I use it for a workbench. It does leak down overnight so I use a small log to prop it up. I would highly recommend getting one. |
Scrumpy | 08/02/2017 21:33:40 |
![]() 152 forum posts | I purchased a Clarke 500kg from Miller tools in Swansea ? On the Internet £100-00 less than MM with two days delivery they also do a 350kg |
Alan Wood 4 | 09/02/2017 09:25:06 |
257 forum posts 14 photos | Thanks guys, very helpful. Alan |
Brian Wood | 09/02/2017 10:08:02 |
2742 forum posts 39 photos | Hello Alan, |
Ian S C | 09/02/2017 11:19:39 |
![]() 7468 forum posts 230 photos | A friend on another forum has found an answer, he has a number of old hospital beds, the type with hydraulic lift and tilt. At the moment he is rebuilding an aeroplane (12" to the foot), and two of these beds are ideal for supporting the wings as they are assembled, mean while another one is serving as an adjustable work bench. Ian S C |
Bazyle | 09/02/2017 13:21:28 |
![]() 6956 forum posts 229 photos | My cheap ex warehouse one off fleebay has a nicely dished top so the oil drips from the loco stay under control. We have a hospital bed at the club which is actually mechanical on the lift pedal though everyone thinks it is hydraulic. The hydraulic bit comes in as a controlled descent mechanism. This might be a necessary precaution in hospitals where a sudden seal failure on the hydraulic lift would be a danger. |
