MEW lathe sander
mick7008/01/2017 11:41:09
524 forum posts
38 photos
like the idea of belt sander in MEW for lathe.
is there any reason i couldn't put a motor on it and use it as free standing sander?
Carl Wilson 408/01/2017 11:54:01
670 forum posts
53 photos
Looking at that unit it is a nice thing, but the big problem for me with a sander and lathe combo is - sand. On the ways, finding it's way in between the saddle and ways etc. I am currently trying to prevent a sand blasting cabinet being sited in the same room as a large lathe for the same reasons.
So putting a motor on it seems a good course of action to me.
Michael Gilligan08/01/2017 12:02:15
23121 forum posts
1360 photos
Posted by Carl Wilson 4 on 08/01/2017 11:54:01:
... the big problem for me with a sander and lathe combo is - sand. < etc. >
+1
mick7008/01/2017 12:05:08
524 forum posts
38 photos
that's why i want to put motor on it.
MW08/01/2017 12:08:46
2052 forum posts
56 photos
Posted by naughtyboy on 08/01/2017 11:41:09:
I suppose a lack of space would be a good reason why you couldn't. I would wager that's why he's done that.
In his defence, I would say with regards to the sand problem it is only 1" wide belts he's put on there and the table doesn't look awfully big either, implying he isn't intending to use it for heavy stock removal and only for finishing small components.
If this was a much wider sanding belt then we could see how dust would accumulate quite quickly.
With regards to sand/soda/powder/shot blasting, I've found in practice that they only seem to contaminate the immediate area around the cabinet, not really spreading dust very far away from it.
Michael W
Edited By Michael-w on 08/01/2017 12:10:24
John Dean 208/01/2017 16:28:49
20 forum posts
5 photos
This is on my list of projects and I have a 1500 rpm motor that I can use but would appreciate guidance on the surface speed of the belt as I can then work out the correct driving pulley size.
Thanks.
Carl Wilson 408/01/2017 16:30:03
670 forum posts
53 photos
naughty boy, I get that's why you want to put a motor on it.
I'm not saying the whole sander lathe thing isn't manageable, just that I wouldn't do it myself.
Jeff Dayman08/01/2017 16:40:01
2356 forum posts
47 photos
The other issue with using a lathe to power a belt sander is speed. Lower speeds as found on lathes will work, but with a separate motor and maybe a belt drive much higher speeds would be possible. Belt sanding works much better and much faster at higher speeds.
There's also the sand and sanding dust - probably better to have that away from your lathe if possible.
If you don't have any other space , OK, you have no choice, use the sander in the lathe. But if you do have room I would go with separate motor and probably a belt drive to allow step up and step down of speeds. JD
PS with any belt sanding - if you are sanding steel making sparks , after sanding some wood - clean all the wood dust out first, and keep an eye out for fire/smoke for a while after sanding. Don't ask me how I know this (it was just some smoldering wood dust, not a serious fire, but still worth some care)
NJH08/01/2017 16:56:10
2314 forum posts
139 photos
I've had a combined 1in belt and 6 in disc sander for years. It is a very "light weight" unit but it gets a lot of use. It also produces a lot of very fine (and abrasive) dust. I really would not want to operate such a unit in my lathe - in fact my sander(s) and grinder are not in the same room as my machines. If you are really stuck for space then I guess there is no option but I would advise a VERY good clean up with a vacuum cleaner after each use.
ps. note the "residue" from the sanding process may not be just bits of metal etc. removed but also bits of abrasive from the belt. Just imagine this stuff finding its way between your lathe's sliding surfaces.
Norman
Edited By NJH on 08/01/2017 17:01:52
Neil Wyatt08/01/2017 19:25:14
19226 forum posts
749 photos
86 articles
I have had a few comments about this, but compared to commercially available toolpost grinding wheels a lathe mounted belt sander is relatively innocuous. They both demand that you cover the lathe bed and clean up carefully.
NJH08/01/2017 20:25:44
2314 forum posts
139 photos
Yes Neil that is true - however using such equipment in a commercial environment where someone else owns the lathe is a bit different to using it on my own carefully cosseted kit which I shelled out for from my own pocket!
Norman
Carl Wilson 408/01/2017 20:35:55
670 forum posts
53 photos
It's not great in a commercial environment either. When you want to get a job done and the equipment is knackered because people don't know/don't care how to look after and use it.
Neil Wyatt08/01/2017 21:38:12
19226 forum posts
749 photos
86 articles
Posted by Carl Wilson 4 on 08/01/2017 20:35:55:
When I said 'commercial' I meant people sell grinders for fitting to lathe toolposts.
Ian S C09/01/2017 09:23:27
7468 forum posts
230 photos
This seems a good place for a 2 pole / 2800rpm motor, qite good sanders are available to fit on a bench grinder (2800rpm), if the motor has ventilation holes, it needs a shroud to keep the dust and grit out of the motor.20 0dd years ago I built a sander for a friend who was making wooden toys, it had a bed about 3ft long, I used a 4 pole motor, and connected it with a belt drive to keep it away from the dust. The bed was made of Melamine covered MDF.
Ian S C
