myford Super 7 Leasdscrew
Myford Super 7 Leadscrew
Piero Franchi14/12/2016 12:25:53
124 forum posts
60 photos
Hi Guys
Looking for some help with the restoration of my Super 7 (see photos in my blog if you fancy it)
Having gone this far with the rebuild, I wish to replace the leadscrew with a new one,
I have a early super 7 with a non powerfeed to the saddle, but I have a screw cutting gearbox.
The leadscrew is not all that bad, but at the same time, its not new, its at the inbetween stage, if it was all togeather, I propabley would not change it to be honest,
bt as its apart I may as well.
That said, I dont want to change it only to buy a cheap rubbish item and latter it,
SO my question is, were is the best place to buy a quality leadscrew for my super 7
we are talking the main leadscrew here
Tony Pratt 114/12/2016 12:42:24
2319 forum posts
13 photos
The original Myford (Nottingham) company is no more but try the below:
Tony
Hopper14/12/2016 12:49:47
7881 forum posts
397 photos
If the expense is too high for your budget, you might be able to use the old dodge of cut the old leadscrew at the point where the thread begins then turn the threaded section around 180 degrees and rejoin it to the unthreaded section. Usually done with a spigot on one part and matching hole on the the other to align concentrically. Then silver solder, tack weld, pin or Loctite together. This puts the worn section of the leadscrew near the tailstock where it is never used, and the unworn part of the thread is now near the carriage where it will now be used.
Piero Franchi14/12/2016 13:23:04
124 forum posts
60 photos
I am having trouble identifying my lead screw!!!!!
I have an early super 7 with the early type clutch, as said, my super 7 is fitted with a screwcutting gearbox.
Only my leadscrew lloks nothing like the ones being sold at myford (new sellers)
ill up load a few photos to my blog
DMR14/12/2016 13:49:16
136 forum posts
14 photos
For a start, is your gearbox as old as the lathe? Does it have an aluminium cover with 3 cogs under it at the right hand end, or are there just the ends of shafts visible at that end? Along the same lines, does your leadscrew only fit into the gearbox by about 50mm and not pass all the way through?
All gearboxes have their serial number stamped at the right hand end. The early gearbox has its serial number under the aluminium cover at the same end. What serial number do you have? It make a big difference to the answers you seek.
Edit:
I have the answers to above from your last picture. You have the early box prior to serial number QC2501. I have sent you a personal message.
Dennis
Edited By DMR on 14/12/2016 13:57:24
Michael Gilligan14/12/2016 13:54:45
23121 forum posts
1360 photos
If it's an 'oddity' then it may be easier/cheaper to get the threaded section re-machined [and half-nuts to suit].
There is nothing sacrosact about the original thread-form ...
JA14/12/2016 14:23:01
1605 forum posts
83 photos
I had a Myford reconditioned Super 7 without a gearbox or cross feed which I rather liked. After a few years I bought a new gearbox from Myford and fitted it without difficulty. However the existing lead screw had to be shortened by a few inches at the headstock end.
Someone may have done a similar modification to your lathe.
Perhaps I should not include this but the lathe serial number was SK9101.
JA
Piero Franchi14/12/2016 16:14:56
124 forum posts
60 photos
Yes DMR mine does have the cover with three cogs and the leadscrew only goes in a short distance into the gearbox
Piero Franchi14/12/2016 16:27:08
124 forum posts
60 photos
Is the ML7 lathes with screwcutting gearboxs the same as the early super 7 Lathes like I have
DMR14/12/2016 17:06:15
136 forum posts
14 photos
You have one of the first 9000+ S7 lathes and one of the first 2500 gearboxes ever made from 1954 onwards. An ML7 is the same as the S7 for leadscrew/gearbox purposes, but the vast majority of gearboxes on the ML7s are not like the one you have. You have my e-mail.
Dennis
Piero Franchi15/12/2016 09:24:21
124 forum posts
60 photos
I am going to my workshop today, as I need to do some more work on the Super7, ill get the serial numbers from the lathe and the gearbox and post them when I get home this evening
Piero Franchi15/12/2016 16:02:46
124 forum posts
60 photos
If anyone is interested, my lathe (super7) is serial NoSK2783 and Gearbox is QC1480
might anyone have a link to the Yahoo Myford group plz
many thanks
Hopper16/12/2016 00:19:58
7881 forum posts
397 photos
The yahoo group is here https://groups.yahoo.com/neo/groups/myfordlathes/info
You can also buy lengths of Acme threaded bar leadscrew from industrial suppliers and cut it to fit your lathe.
Piero Franchi16/12/2016 16:21:24
124 forum posts
60 photos
many thanks Hopper
