Boxford model a
Loose pulley
kevin large04/12/2016 17:54:19
143 forum posts
Hi all the belt pulley seems loose on the headstock spindle I've tried tighten the grub screw but no use how much of a job is it to remove the spindle
kevin beevers04/12/2016 18:09:12
69 forum posts
43 photos
take th
e grub scew out they sometimes have another one in aswell
kevin
Steve Pavey04/12/2016 18:33:15
369 forum posts
41 photos
Kevin's right, but just to add, that is two screws one on top of the other, not in two seperate holes.
Brian Oldford04/12/2016 18:36:21
686 forum posts
18 photos
Screwed against each other they act like an "inside-out" version of a nut and locknut arrangement. The adjustment on the Myford Super 7 Mk 1 clutch uses that very same arrangement.
kevin large04/12/2016 18:41:49
143 forum posts
Thanks guys I will check tomorrow
Hacksaw04/12/2016 18:50:59
474 forum posts
202 photos
Off topic ! Brian Oldford , i sent you a pm ages ago , re file ...its unread...?
Ajohnw04/12/2016 18:57:36
3631 forum posts
160 photos
Might give you an idea about removing the spindle.
The bearings are sometime very tight. It would have wiser for me to make another spacer rather than use the vice and to ensure that the all thread ran right down the middle of the spindle.
It's an ME10 but suspect that the A will be similar. One of the grub screws in the belt pulley is for oiling the back gear bearing. Maybe you have some slack in the drive rather than the pulley being loose.
As mentioned the grub screws on the large counter shaft pulley go onto 2 flats on the spindle. If not square to the flats the pulley will rock. They need tightening alternately while rocking the pulley to get both well seated.
Edited By Ajohnw on 04/12/2016 18:58:20
daveb04/12/2016 20:09:27
631 forum posts
14 photos
If you mean that the pulley is turning but the spindle isn't, move the lever on the front of the headstock to lock the pulley to the spindle. If you have the later type with the lever on top, check that the lever is in the correct position. The grub screw is for oil.
kevin large05/12/2016 19:26:06
143 forum posts
Thanks all there was another grub screw underneath all done now
Thanks
