Brass for cylinders
Phil H113/11/2016 20:25:17
467 forum posts
60 photos
Does anybody have any experience with the use of drawn brass bar for the fabrication of 3 1/2" gauge locomotive cylinders? I can understand the need to exclude brass from a boiler but is it any use for cylinders (with the correct piston material and the use of 'o' rings etc)?.
Phil H
Another JohnS13/11/2016 20:46:33
842 forum posts
56 photos
Phil;
Kozo Hiraoka's "Building the New Shay" specifies brass, with "O" rings on pistons. His previous books specified copper-tin bronze, with graphite packing.
The Gauge 1 builders (e.g. "Project" design) use brass for the cylinder(s).
I've no direct experience, but others design this way - I'd assume it would be ok.
John.
julian atkins13/11/2016 23:34:10
1285 forum posts
353 photos
The problem with fabrication if silver soldering the parts together is that the brass will be soft. It can be age hardened. I dont know of a quicker process. I remember LBSC stating even phos bronze/gunmetal should not be silver soldered for cylinder and valve parts as it significantly affects the wearing properties. Whether this is correct or not I dont know myself.
Generally one should avoid brass in cylinder parts as it wears badly anyway compared to gunmetal castings or bronze.
If you are building a 3.5"g loco it would be a shame to spoil it by not using the correct materials for the job.
Cheers,
Julian
mick H14/11/2016 05:36:59
795 forum posts
34 photos
I am a Gauge 1 type and invariably use brass for cylinders, but, at this small scale "O" rings are usually used as piston rings so that there is little or no wear in the cylinder walls. Whether this is possible in larger scales I have no idea but I would tend to take the advice given by Julian if I were investing the time, effort and expense in building a 31/2" loco.
Mick
MW14/11/2016 06:24:28
2052 forum posts
56 photos
Posted by julian atkins on 13/11/2016 23:34:10:
Cheers,
Julian
Agreed, it's disappointing to be told to need to change things; it's better to try again for the sake of a better outcome and at least one now knows more than one did the first time around.
Michael W
Edited By Michael Walters on 14/11/2016 06:25:30
Ian S C14/11/2016 10:25:10
7468 forum posts
230 photos
If the cylinders were to have liners, softening by heating would not be a problem, although you might want to put something harder on the valve face, but I can't see a difficulty there.
Ian S C
Phil H114/11/2016 13:58:00
467 forum posts
60 photos
Thanks for the answers chaps. Perhaps I should have been more specific because my main concern was not the wear. My main concern was how the material behaves in contact with superheated steam followed by wet soggy steam, water and oil etc
One of the reasons for asking is that I notice many of the steam and water valves that you can buy definitely specify a brass body rather than bronze or gunmetal. Again I understand that valves can be replaced but what happens to the brass bodies and seats? Do they basically corrode and fail or start passing within a relatively short service time? Does brass just go orrible but gunmetal remains relatively clean and unharmed?
PhilH
