Andrew Tinsley | 12/11/2016 16:14:35 |
1817 forum posts 2 photos | I have sorted out my Chinese bandsaw thanks to the masses of help that I had from you all. So many thanks! I am currently using Starrett Blades and intend to change to the Lennox blades which someone said were even better! I tend to use the same sort of pitch as on my hacksaw (from memory about 22 teeth per inch. A friend of mine said I should use much coarser blades (12 per inch or there about) . He argued that the clearance of swarf was the limitation and the coarser the better. I am dubious of this advice and can think of quite a few refutations. Is he correct? Andrew. |
Andrew Tinsley | 12/11/2016 16:15:43 |
1817 forum posts 2 photos | I forgot to say that I mostly cut mild steel! Andrew. |
Bazyle | 12/11/2016 17:08:49 |
![]() 6956 forum posts 229 photos | It depends on how thick the material is you are cutting, same as for a hand hacksaw. So minimum two teeth in the work. |
Brian Wood | 12/11/2016 17:15:29 |
2742 forum posts 39 photos | Hello Andrew,
Martin Connelly | 12/11/2016 17:48:21 |
![]() 2549 forum posts 235 photos | Bandsaws that have a controlled bow descent can use quite coarse blades, we use 6/10 vari-pitch at work. Martin |
Phil Stevenson | 12/11/2016 19:22:49 |
90 forum posts 13 photos | Sorry to elbow my way into this thread but as a newbie, can I ask if I can cut metal on a woodworking bandsaw? It's single speed and suppliers sell correct length blades of various kinds and various tpi, some of which are described as suitable for metal but I'm somewhat sceptical. Any thoughts / experience? I'm not thinking of cutting anything beyond thin-ish brass, aluminium, etc not thumping great lumps of steel. |
John Stevenson | 12/11/2016 20:12:03 |
![]() 5068 forum posts 3 photos | If you are going for the Lennox blades, and in my book you can't do better then use the vari-pitch ones, 10/14 or 12/16 will be fine, not sure what choices you have in this range. Edited By John Stevenson on 12/11/2016 20:12:26 |
JasonB | 12/11/2016 20:29:40 |
![]() 25215 forum posts 3105 photos 1 articles | Phil, I use my old Rexon BS to cut non ferrous now that I have a larger one for woodworking, use the same Starret bi metal blades that I did for wood and it copes well if a little noisily. This is a bit of 3" sq aluminium that I cut recently with a very acceptable cut.
fizzy | 12/11/2016 21:09:47 |
![]() 1860 forum posts 121 photos | Phil - I use a vertical woodwork bandsaw for cutting copper sheet, I opt for either 18 or 24 tpi and take it steady without issue so the anser is definately yes. |
Phil Stevenson | 13/11/2016 16:31:36 |
90 forum posts 13 photos | Result, Jason and Fizzy! Thanks - I'll order a fine tooth blade and give it a go. |
Roger Hulett | 14/11/2016 13:37:03 |
131 forum posts 9 photos | I have just completed cutting some 1mm thick mild steel discs on my two wheel domestic bandsaw. I used 24 tpi Starret blades,and found the whole process relatively easy. However I have a problem regarding the discs in that I have to form a 5mm flange on the edge (as if it could be anywhere else). I can do this by marking the disc at 5/6mm distance and bending with pliers, or sticking a piece of curved metal in the vice and tapping with a hammer, Is there a better way ?,both of my ideas seem fairly crude ! |
pgk pgk | 14/11/2016 13:45:04 |
2661 forum posts 294 photos | Posted by Roger Hulett on 14/11/2016 13:37:03:
I have just completed cutting some 1mm thick mild steel discs on my two wheel domestic bandsaw. I used 24 tpi Starret blades,and found the whole process relatively easy. However I have a problem regarding the discs in that I have to form a 5mm flange on the edge (as if it could be anywhere else). I can do this by marking the disc at 5/6mm distance and bending with pliers, or sticking a piece of curved metal in the vice and tapping with a hammer, Is there a better way ?,both of my ideas seem fairly crude ! ..depends how many discs? I've been flanging my copper boiler parts with a hammer and former OK but if lots to do and worth the bother then I guess a pair of dies and press them.. |
Roger Hulett | 14/11/2016 14:22:04 |
131 forum posts 9 photos | I only have 6 to do, so a former and hammer seems the way to go. Would you heat the metal before beating it ? |
pgk pgk | 14/11/2016 15:54:50 |
2661 forum posts 294 photos | Posted by Roger Hulett on 14/11/2016 14:22:04:
I only have 6 to do, so a former and hammer seems the way to go. Would you heat the metal before beating it ? Annealing copper is simply heat and chuck in water. Annealing steel is way slower so I'd try without. |
