Boxford paint colour - but not blue or green!
David Standing 131/10/2016 12:04:38
1297 forum posts
50 photos
Hi all.
I have a newly acquired Boxford 280, in the ivory and yellow livery, as per the first image here:
http://www.lathes.co.uk/boxfordmodern/
I'm trying to find out the paint spec/colour so I can do some tidying up of the paintwork.
Boxford can't tell me the paint code, apart from tell me it was a Trimite air drying acrylic.
Trimite can't identify it, nor can Paragon.
Anyone by chance happen to know what BS/RAL or whatever code the paint is?
Thanks
Edited By David Standing 1 on 31/10/2016 12:08:49
David Standing 131/10/2016 12:14:05
1297 forum posts
50 photos
I should add that Trimite will match it if I take a cabinet door off and send it to them, but that is my last resort approach!
John Rudd31/10/2016 12:22:51
1479 forum posts
Have you tried looking at BS /RAL,colour charts online? Should get you close maybe......
http://www.e-paint.co.uk/BS2660_colour_chart.asp
Nick_G31/10/2016 12:23:51
1808 forum posts
744 photos
Have Trimite not got a sales record of what they supply to Boxford. They may or may not reveal this information though.
Nick
David Standing 131/10/2016 12:27:23
1297 forum posts
50 photos
Posted by John Rudd on 31/10/2016 12:22:51:
Thanks
Trimite sent me a BS/RAL high quality colour chart, trouble is there are about 20 whites that are close!
David Standing 131/10/2016 12:29:03
1297 forum posts
50 photos
Posted by Nick_G on 31/10/2016 12:23:51:
Nick
Nick
Thanks
Trimite have been very helpful, but didn't offer to check their sales records for a 1991 lathe paint!
Boxford still make the 280 and derivatives, but changed to a two tone blue livery a number of years ago.
Bazyle31/10/2016 13:09:52
6956 forum posts
229 photos
I have an old ME10 (kit) that is an exciting beige that will really liven up the workshop laugh Some parts are grey underneath so I recon they had stock and the shop floor must have been thrilled when the marketing guys told them about the change. It predates John Major though.
I also have a Warco item that is not their usual green, supplier error, so I got a discount.
John Rudd31/10/2016 13:11:08
1479 forum posts
You could always go for the 'faded white look'......I'll get me coat...wink
Richard Millington30/05/2021 20:52:27
101 forum posts
9 photos
Hi David,
I also have a white / yellow 280, but have also bough a Centec 2A which I am currently rebuilding. Did you ever find out what colour paint was used or a good match?
Many thanks
Rich
Dave Wootton31/05/2021 06:33:07
505 forum posts
99 photos
Hi
If you can't get a paint code car paint suppliers can match paints to a sample very closely, I got them to match and make up a synthetic enamel and they used a retarder in the mix so it could be brush painted, it lasted very well on a green Colchester ( this was before Paragon was available).
You need one of the older fashioned paint suppliers that are used to matching faded car paints, I believe the minimum is 1 litre. I did try Halfords colour match spray recently when I made a power feed for my mill, the result was laughable, and there are no refunds, despite the green paint being blue!
Edited By Dave Wootton on 31/05/2021 06:36:37
Nicholas Farr31/05/2021 07:24:58
3988 forum posts
1799 photos
Hi, Brewers Paints are very good at colour matching if you can take a part to them if you have one in your area.
Regards Nick.
Alan Donovan31/05/2021 10:56:29
81 forum posts
41 photos
Hi.
I have had to match paints a couple of times and the more specialist paint suppliers now have a hand held device that can 'read' the colour and give you the shade and/or RAL number. It literally only takes a minute or two.
The first occasion I needed this service, I used one of the larger (but local) glazing companies. They often need to colour match paint to paint the reverse side of windows or glass splash backs. So that is another route to what you want.
I have no idea how these devices work, but I assume that you would have to get the painted sample as clean as you can before getting it scanned.
Hope this is useful. Alan.
Martin Kyte31/05/2021 11:40:08
3445 forum posts
62 photos
or you could scan the dirty parts and then you don't have to clean the lathe and then also you don't have to paint everything.
;O)
Martin
Edited By Martin Kyte on 31/05/2021 11:41:01
larry phelan 131/05/2021 12:42:14
1346 forum posts
15 photos
Does it make all that much difference what colour the lathe is ?One time,I think they were all painted black, matching was no problem !
Richard Millington31/05/2021 21:01:55
101 forum posts
9 photos
If I paint the Centec the same colour as the Boxford then I only have to keep one colour for touching up wink
At the moment looks like it's going to be Aldi silver as I have just stripped the old beige off the head and found blue/grey underneath.
Nigel Bennett02/06/2021 10:30:54
500 forum posts
31 photos
I found that Hammerite's Smoothrite was a reasonable enough match; the cream is quite close. The yellow isn't 100% but quite near enough. It's all a question of whether you just want to look at it, or actually use it to make things with... The amount of oil-staining on the chip tray on mine after a couple of years makes colour matching irrelevant. (Unless turning cast iron, I use a lot of lubricating oil on my lathes.)
Richard Millington02/06/2021 12:27:36
101 forum posts
9 photos
Thanks, it was going to be for painting the Centec, but that is now being done in Aldi Silver as I have two cans sitting on the shelf. I will bear in mind for re painting the Boxford cabinet when I have to.
