Advice
Scrumpy | 08/10/2016 18:16:25 |
![]() 152 forum posts | i have been looking for some time to make a generator for a 2 in showman, I have tried various avenues with no luck but on looking at traction talk form a person from America has made the generator using a air craft motor as a generator along with a rectifier and led lights has anyone come across this before or has any information or advice as it looks to work |
JasonB | 08/10/2016 19:46:30 |
![]() 25215 forum posts 3105 photos 1 articles | I've seen that one in the flesh and it works very well and looks right on the small 2" Gold Medal Tractor. |
Andrew Johnston | 08/10/2016 20:33:44 |
![]() 7061 forum posts 719 photos | Clearly the system works well, although I'm not sure why he only used half wave rectification, and there are probably better regulators than the 2940 available. I assume that the LEDs are running in parallel? Andrew |
John Olsen | 08/10/2016 23:43:04 |
1294 forum posts 108 photos 1 articles | I presume that what is meant is a model aircraft motor. The usual type has a permanent magnet rotor and a three phase stator arrangement. If the rotor is powered they will generate three phase power which may be rectified and used to charge a battery or power a load. This makes them quite similar to the permanent magnet alternators that used to be common on motorcycles. The characteristics of a permanent magnet machine like this is that the voltage will rise with speed. The bikes used to get around this by connecting the rectified output to a battery, and by winding the machine with two sets of coils. The battery limited the voltage that could be reached so that the alternator was actually delivering its maximum current. The two windings were then arranged so that one provided enough current for the normal load, and the other provided enough for the lighting load. This was all a bit approximate and these simple arrangements had a tendency to cook their batteries. In the late sixties and seventies, electronics started to provide better solutions. Lucas used a zener diode and others used various forms of shunt regulator. This is the way I would go if I wanted to use one of these on a traction engine. The alternator has to be turned fast enough to generate a bit more than the voltage required, and the output is rectified with a three phase rectifier. Either a battery or a large capacitor is used to smooth the output, and a shunt regulator (eg the Lucas Zener) is used to dump any excess current. The model aircraft motors are usually outrunners, eg the rotating armature with the magnets is on the outside. For generator use it might be more convenient to find an inrunner of the desired size. These have the armature inside, more like a conventional motor. Of course for traction engine use it might be desirable to hide the whole thing inside a scale looking casing anyway. The beauty of these motors for this purpose is that there are no brushes to wear out. John |
Andrew Johnston | 09/10/2016 00:00:29 |
![]() 7061 forum posts 719 photos | Posted by John Olsen on 08/10/2016 23:43:04:
I presume that what is meant is a model aircraft motor. Correct, and in the original post on TT it is stated that the motor is an outrunner, and outputs three phase. That's why I thought it was odd that a half wave rectifier was used. It is also stated that the output voltage is proportional to speed. While I realise that a linear regulator is simple personally I'd use a switcher rather than throwing energy away. It'll probably be smaller than the heatsinks. I'd go for a buck or SEPIC converter, the latter coping with input voltages above and below the output voltage. There were no schematics or details in the original TT post, but the picture sure looks impressive with all the LEDs emitting. Andrew |
John Olsen | 09/10/2016 05:32:35 |
1294 forum posts 108 photos 1 articles | There is a reason why the motorcycles mostly used a simple shunt regulator. The alternator has to be designed so that it will start charging at some reasonably low rpm. Say 1 quarter of maximum rpm. That means that it will be able to produce 4 times the voltage at maximum, and if a series type of regulator is used, it must cope with that on the input, as must the rectifier. At least one bike I tinkered with was capable of around 80 volts open circuit. In the days of selenium rectifiers it was important not to open circuit the connection to the battery since this could destroy the rectifier. With a shunt regulator and a bridge rectifier nothing sees anything more than the battery voltage. So long as it is connected to the battery then the voltage cannot rise higher, and the alternator will act as a constant current source. OK, with a showmans engine running its lights, possibly with a working governor, the speed variations are not going to be so great, so a more sophisticated regulator could be used. It will have to be able to cope with variations in the input voltage, as will the rectifier and smoothing capacitor. All quite doable, especially in these days of supplies which will run OK off either 240V or 110 V without adjustment. But I would ask if the relative inefficiency of the regulator is going to matter, when the efficiency of the steam part of the cycle is not likely to exceed 2%. (Going by IMLEC results over the years.) John |
Martin Connelly | 09/10/2016 09:20:16 |
![]() 2549 forum posts 235 photos | You may be able to use the generator from a hand crank radio or torch (flash light) as the basis for a generator. Fit it into a package of your own design to look the part. Martin |
JasonB | 09/10/2016 10:07:57 |
![]() 25215 forum posts 3105 photos 1 articles | |
Michael Gilligan | 09/10/2016 10:46:55 |
![]() 23121 forum posts 1360 photos | Looks very effective, Jason Just a thought ... is there anything wrong with the traditional bicycle dynamo for this application? MichaelG. |
peter ravenscroft | 09/10/2016 11:11:10 |
100 forum posts 3 photos | there is one described in the construction articles for the Darjeeling loco based on a hand wound torch i have built on and it works ok regards peter |
Andrew Johnston | 09/10/2016 11:33:29 |
![]() 7061 forum posts 719 photos | Posted by John Olsen on 09/10/2016 05:32:35:
OK, with a showmans engine running its lights, possibly with a working governor, the speed variations are not going to be so great, so a more sophisticated regulator could be used. It will have to be able to cope with variations in the input voltage, as will the rectifier and smoothing capacitor. Surely that's the whole point of a switcher, it can cope with a wide input voltage range without the high dissipation at higher input voltages. As a result of the push for 42V automotive electronics there are switching ICs available that will run from 5V to >50V input. The need to run on a governor for a switcher is irrelevant, as is the efficiency, or otherwise, of the steam engine. I've just re-read the original post on TT. At 250rpm the OP gets just enough voltage to run the 5V regulator. He is running the LEDs at 15mA, and I estimate there are about 60 LEDs, so around 0.9A. Given a 0.5V drop across the regulator, that's about 0.45W, quite manageable with one of the bigger IC packages. However, the OP states that at maximum speed the output is 15V, so now we have 9W of dissipation, which is going to need a heatsink. One of the original issues was finding a small enough generator to fit within the existing dummy generator casting set. So finding room for a heatsink might be a problem. The one and only time I've seen a power Zener diode shunt regulator was back in the late 1980s on an Indy car, but of course that was sitting in a 200mph breeze, so heatsinking was not a problem. Andrew |
Scrumpy | 09/10/2016 11:50:30 |
![]() 152 forum posts | Hi All many thanks for all your help with this topic I agree the photo looks very impressive, last evening at a steam up I was offered two Outrunner motors the details are . Motor (1) Shina Emax bl2815. 920 Kv Outrunner brushless motor max current 30 amps . Number (2) Turnigy D3548/4 brushless 1100Kv max load 50 A Max power 910 w Would either of these be of any good to me powering led bulbs at 20ma there would be 50 of them 3.5 forward voltage ? what ever that means and what rectified controls would be required these motors come free as the one that is lit up works out at 150 pounds and I need two could some one explain how to wire this up if either motor will do as I see three phase is involved any circuits or diagrams would be appreciated sorry for being so thick on this as I have had no dealings when it comes to this side of thinks The Showmans engines I have would run at 200/250 rpm governed driving the generator, would I wire the bulbs in parallel or series and would it be advisable to have two separate circuits many thanks in anticipation . I'm sure many people will be interested in this
Michael Gilligan | 09/10/2016 12:26:30 |
![]() 23121 forum posts 1360 photos | Posted by Andrew Johnston on 09/10/2016 11:33:29:
The one and only time I've seen a power Zener diode shunt regulator was back in the late 1980s on an Indy car, but of course that was sitting in a 200mph breeze, so heatsinking was not a problem. . Andrew, For info. ... Here's the Triumph motorcycle one: MichaelG. |
Neil Wyatt | 09/10/2016 12:46:03 |
![]() 19226 forum posts 749 photos 86 articles | If I was going to do this, I'd use an old-fashioned brushed motor as (1) it would give proper DC - it's a dynamo not an alternator Neil |
John Olsen | 09/10/2016 22:27:12 |
1294 forum posts 108 photos 1 articles | Scrumpy, I presume you have a lathe available? You can try these motors out in the lathe, eg grip the shaft in the chuck and lash up something like a piece of wood to attach to the mounting plate to stop it rotating. Then you can try rotating it at various speeds to see what voltage you get. Hopefully you would know at least approximately what the speeds on a lathe are. You would need some sort of AC voltmeter. I suspect that they are going to need to go a bit faster than the 250 rpm you mention, but then if they are driven by a belt from the flywheel they can be geared up by quite a bit by using a small pulley at the alternator end. I have some small motors like this lying around, so I will take one out and have a play in the lathe The kV rating gives a guide to the rpm the motor will do at a given voltage, when driven by the usual ESC. It probably will give a rough approximation to the speed it needs to be driven at to generate a given voltage. A higher kV figure will mean that it generates a given voltage at a lower speed. (These are not kV as in kilovolts, they are rpm per volt.) The three phase rectifier is not a problem. it just means that there are six diodes instead of four. A simple way is to take two of the bridge rectifier units that are sold, and connect the two plus sides together, and the two minus sides also connect together. Then each motor lead goes to one of the AC in connections on one of the bridges Since there are four AC in connections, one of them goes unused. Perhaps Andrew can suggest a source for a suitable regulator and tell you how to wire it up. If you do need a heatsink at all, I would suggest the bottom of the water tank would be the coolest place on a traction engine, and out of sight too. Neil, the DC motor idea is fine, except they too tend to need regulation. Also brushes can be a bit of a pain, and they are often not very good on readily available small DC motors. John |
John Olsen | 09/10/2016 23:41:59 |
1294 forum posts 108 photos 1 articles | OK, I just dug out a Turnigy G60-500, which is a 500kV motor, and ran it up on my lathe. Unfortunately I don't have a working tachometer at the moment, but working from the pulley sizes it would be doing about 900rpm. It gave 1.2 Volts between phases. Your 1100kv motor could be expected to give about twice that at the same rpm. The higher the kv, the lower the rpm it is going to have to turn at to generate enough voltage. Your 1100 would be a better choice than my 500. Current will not be a limitation, I tried shorting mine into an ammeter and got 13 Amps. If I wanted to use my one for a generator I would be wanting to rewind it with many more turns of finer wire, to get a higher voltage at lower speed. (The same motor is as mine is available in other kv ratings and that is what the difference is, the lower kv have fewer turns.) This would of course reduce the maximum current, but that is obviously far more than is needed. Your 50 LEDs at 20mA is 1 Amp. John
John Olsen | 10/10/2016 08:07:29 |
1294 forum posts 108 photos 1 articles | Sorry, I am getting things upside down...you want a low kV motor, that will give the required voltage at a lower rpm. Still, worth trying the ones you have to see if they will do the job.
regards John |
duncan webster | 10/10/2016 13:15:14 |
5307 forum posts 83 photos | Looking at the motor spec sheet, the '500Kv' means 500 rpm per volt. This is when it is running as a motor, so as a generator it will want more speed. The rectifying diodes will drop 1.2v, so I'd expect somewhere around 1000 rpm before it showed any DC voltage, which agrees with John's measurements. It might be worth considering a 'joule thief', but I'll leave it to those more competent in electronics to provide a circuit. Alternatively, and this might be complete rubbish, how about using the LED's as the three phase rectifier. I know each individual LED will only be on for half time, but you can drive them a bit harder because of this, and persistence of vision means they will look a lot more than half brightness. |
Scrumpy | 10/10/2016 15:56:48 |
![]() 152 forum posts | Very many thanks to all who are giving me advice , have just run Shina motor it being a 920kv Outrunner in the lathe and I have the following results speed at 1000 rpm reading 1.7 v increased to 1500 rpm reading 2.1 v does this make sense to anyone I hope I have interpreted it all correct as this is all a black art to me if either of the motors will do for me there is plenty of room inside the housing to fit a regulator if this works I can fit a fan inside as well so heat should not be a problem , With running the engine at 250 rpm with the correct pulley size I would imagine the motor would be into 3000 rpm is this okay |
Muzzer | 10/10/2016 16:19:09 |
![]() 2904 forum posts 448 photos | Posted by duncan webster on 10/10/2016 13:15:14:
how about using the LED's as the three phase rectifier. No, they don't like it up 'em. Max reverse voltage is typically only a few volts and I suspect the reverse recovery time will be very long. |
