Mark P. | 02/09/2016 11:53:47 |
![]() 634 forum posts 9 photos | Morning all, can anyone point me in the direction of a supplier of flat spring steel? I'm looking for a piece about 600mm x 20mm x 2mm. I can find really thin stuff but none in the size I require. Thanks in advance. Mark P. |
Gordon W | 02/09/2016 11:58:41 |
2011 forum posts | I don't know what it is for, but I have cut bits out of an old wood saw. Use a thin cutting disc in an angle grinder. |
Mark P. | 02/09/2016 12:04:05 |
![]() 634 forum posts 9 photos | Thanks Gorden, never thought about that, I've got a few of those. Mark P. |
jaCK Hobson | 02/09/2016 13:24:36 |
383 forum posts 101 photos | It depends on the specific application but O1 (sometimes listed as ground flat stock or gauge plate) may well be perfectly suitable and you can get it all sorts of places in small amounts. 2mm would be quite a thick saw? I've got some CS70 if you can't find anything else. You usually have to buy that in very large quantities. |
Gordon W | 02/09/2016 14:20:33 |
2011 forum posts | Just for interest, just measured an old saw and it's 2.1 mm thick. This is (was) a proper saw, 2 handed crosscut. |
Mark P. | 02/09/2016 14:26:23 |
![]() 634 forum posts 9 photos | Well a saw it is then Gordon, thanks for the offer Jack. I've got a few old ones and they always turn up a boot fairs. Thanks Mark P. |
JasonB | 02/09/2016 14:27:54 |
![]() 25215 forum posts 3105 photos 1 articles | Reeves list 3/4" x 13swg (2.3mm) in 2ft lengths which is annealed for easy working. |
Mark C | 02/09/2016 14:34:32 |
707 forum posts 1 photos | You could probably find some in the edge of an old mattress - it will be very high quality spring steel as it has to take an edge bend after it was made. Mark |
jaCK Hobson | 02/09/2016 15:27:24 |
383 forum posts 101 photos | Posted by Gordon W on 02/09/2016 14:20:33:
Just for interest, just measured an old saw and it's 2.1 mm thick. This is (was) a proper saw, 2 handed crosscut. I guess I was thinking of the throw-away hardpoints. Circular saw blades are thick as well and should be good for springs. TCT blades may be a gamble. Beware some sources of second hand metal - it can have fatigue cracks that you can't see. Back of an old hand saw should be completely safe though. |
Mike | 02/09/2016 17:32:24 |
![]() 713 forum posts 6 photos | If you have a proper gunsmith in your area (rather than a gun salesman) ask him where he gets his steel for making v-springs. Also, just a thought, but could you use a steel ruler? |
roy entwistle | 02/09/2016 17:53:11 |
1716 forum posts | Mike How many rules are 2mm thick ? |
mark smith 20 | 02/09/2016 19:03:23 |
682 forum posts 337 photos | MK metals have 1" x 14g (2mm) x 1 metre . |
Mark P. | 02/09/2016 19:21:44 |
![]() 634 forum posts 9 photos | Thanks for the replies,MK Metals looks like a good bet cheaper than Reeves. Thanks again Mark P. |
Chris Gunn | 02/09/2016 20:25:39 |
459 forum posts 28 photos | Mark, I have some 16G, which equates to 1.5mm if that is any good to you. Chris Gunn
Mark P. | 02/09/2016 20:36:12 |
![]() 634 forum posts 9 photos | Thanks for the offer Chris, I will get some from MK Metals as they can supply 1/8"x3/4" which will do the job I need. Regards Mark P. |
Mark C | 02/09/2016 22:41:56 |
707 forum posts 1 photos | I was not kidding about mattress edge strip, I used to work at a spot that made the stuff and it was quite demanding to make. The other thing we made (among a lot of other products) was "bra stay wire" which is used for - support in women's under wired bra's. It may be useful to remember that they have wire in them as this is also very high quality material. The stay wire is often oval in shape and coated in plastic but also to be found in round edged flats. They are usually in the range of a couple of mm wide by a mm or so thick (with the plastic coating removed. Mark |
