Taris Jewell | 28/08/2016 16:44:17 |
22 forum posts | So I bought a lathe yesterday and the guy disconnected the motor wiring from the Dewhurst drum switch. So i have no idea how it gose bake. The wires are all the same colour but i did trace them with a malt-meater the lathe is a Drummond but no idea on the motor make i can tell you that it has a1 a2 and z1 z2 and i did find a thread on wiring this up and i did that but it seems to only go clockwise in the reverse position on the switch even if i flib the z1 and z2 and the same with the a1 and a2 but the motor dose make a noise when i put it in forward but doesn't move it also seams to spark a lot. So I stopped so not to damage anything. The wiring coming from the plug is right but im now confused. Edited By JasonB on 28/08/2016 17:12:28 |
Les Jones 1 | 28/08/2016 19:16:30 |
2292 forum posts 159 photos | Hi Taris, Les,
peak4 | 23/01/2017 21:28:37 |
![]() 2207 forum posts 210 photos | A picture speaks a thousand words. I believe this link might assist. **LINK** I'd expect A1/2 to be the run windings and Z1/2 the start windings. Not ideal to use a Dewhurst as a start stop device though, better to add a no-volt release switch for that function and use the Dewhurst purely for reversing the motor. Just bear in mind that the chuck screws on, so you don't want it barreling off down the workshop when you reverse the spindle rotation. Head up to the top of his page to see how this chap smartened his switch up a bit. https://misterlinnsworkshop.wordpress.com/category/myford-ml7b/page/19/
Edited By peak4 on 23/01/2017 21:36:13 |
Phil Whitley | 24/01/2017 21:48:33 |
![]() 1533 forum posts 147 photos | Just to confim the Above, and add a bit, A1 and A2 are the run winding, Z1 and Z2 are the start winding, and to reverse the motor, you reverse the polarity of the start winding, or reverse Z! and Z2. This is what the Dewhirst switch does, but allow the lathe to come to a complete stop before changing direction, I also recomend fitting a NVR type starter, and again, beware of the chuck unscrewing, or fit a set screw so it can't!
Ady1 | 25/01/2017 00:26:01 |
![]() 6137 forum posts 893 photos | There's a bit on old motors here |
JohnF | 28/01/2017 11:00:09 |
![]() 1243 forum posts 202 photos | Taris look at your messages |
