Chinese mini mill/drill lubrication
Bodger Brian27/08/2016 16:37:52
187 forum posts
40 photos
i did wonder if I should post this in the 'beginners' section but here goes......
I have a Chinese mini mill/drill which I purchased many years ago and the manual is long lost, so I'm afraid I can't quote exact model names or numbers. After a long period languishing in a shed at the bottom of the garden, it has been relocated in my new workshop and I've stripped it down for cleaning.
My question is what, if anything, should the leads screws (is that the right term?) be lubricated with prior to reassembly - oil or grease? I would assume that the screws are steel and they run in nuts that appear to be of brass, bronze or similar metal. The small amount of crud that was visible on disassembly didn't give me much of a clue.
Thanks
Thor 🇳🇴27/08/2016 17:05:48
1766 forum posts
46 photos
Hi Brian,
 I have a Chinese made milling machine and I use oil on lead screws and ways (as adviced in the manual). There are a couple of gears in the head, I lubricate them with grease.
Thor
Edited By Thor on 27/08/2016 17:06:22
mark smith 2027/08/2016 17:08:57
682 forum posts
337 photos
Always use oil on lead screws and slideways as grease will attract anything that is falling off the cutter or floating in the air and turn it into valve grinding paste.
I would only use a good quality grease on bearings and not a lot of it otherwise they tend to overheat.
Edited By mark smith 20 on 27/08/2016 17:09:29
Bodger Brian27/08/2016 17:16:29
187 forum posts
40 photos
Thanks chaps.....
That confirms what I'd more or less decided. The reason for not using grease (as it attracts "nasties"  should have been obvious if I'd have thought about it more!
Edited By Bodger Brian on 27/08/2016 17:17:15
Edited By Bodger Brian on 27/08/2016 17:18:05
Edited By Bodger Brian on 27/08/2016 17:21:00
Bodger Brian27/08/2016 17:20:16
187 forum posts
40 photos
How do I get rid of the emoji? I think I read something recently that it's due to the combination of characters but I can't find the post.
Neil Wyatt27/08/2016 21:09:07
19226 forum posts
749 photos
86 articles
" and ) without a gap between them.
" vs " )
Clive Hartland27/08/2016 21:13:50
2929 forum posts
41 photos
On re-assembly use copperease and then after, use a good lube oil.
