Russ B | 25/08/2016 13:57:33 |
635 forum posts 34 photos | I have an ABAC twin cylinder 3HP compressor (3000rpm). When I fire it up from cold, it runs and gets up to 120-130 psi and then turns off with a pop and a hiss - all sounds good. Edited By Russ B on 25/08/2016 13:58:59 Edited By Russ B on 25/08/2016 13:59:55 |
Martin Connelly | 25/08/2016 14:06:41 |
![]() 2549 forum posts 235 photos | Are the fins on the top of the cylinder getting hot to touch? Sounds like a thermal problem rather than electrical. Heat soak may be causing loss of clearance somewhere in the compressor. Martin |
Trevorh | 25/08/2016 14:11:07 |
![]() 316 forum posts 89 photos | Probably the reed valves not sealing properly due to getting hot or there cracked they are at least quite easy to strip the heads off and check
Abac actually sell spare parts as well
Trevor
not done it yet | 25/08/2016 15:31:52 |
7517 forum posts 20 photos | Does the motor actually get to full speed on restart? If not it may be starting on load due to back leakage and then struggling because the start windings have not got it up to speed quickly enough?
Try starting from very low pressure, or zero, immediately after it gets to the stalling situation. That would determine if it is the compressor getting tight or the motor not delivering full torque. |
Les Jones 1 | 25/08/2016 17:25:30 |
2292 forum posts 159 photos | Hi Russ, Les. |
duncan webster | 25/08/2016 18:56:13 |
5307 forum posts 83 photos | I doubt it is an unloader valve problem as it is starting up and pumping from 50 psi to 90 psi. Anyway, the 'pop and hiss' mentioned in first post suggests it's got one. It's strange that it works from cold, but not second time. Is it still hot when it starts the second time, and so is getting hotter second time round? |
Les Jones 1 | 25/08/2016 20:08:43 |
2292 forum posts 159 photos | Hi Duncan, Les. |
I.M. OUTAHERE | 25/08/2016 21:00:32 |
1468 forum posts 3 photos | Try running it up to full pressure then turn it off at the power switch and dump the air in the tank and then turn it back on . If it runs ok you have a back pressure problem that is stalling the motor . If there is no change i would look at the motor capacitors or check if the pump is seizing . You didn't mention if it is single phase or 3 phase ? Ian. |
Russ B | 25/08/2016 23:48:06 |
635 forum posts 34 photos | thanks, I'll give this a try tomorrow and maybe borrow the FLIR camera from work over the weekend (hours of fun to be had with that thing - its quite literally a whole new perspective on EVERYTHING! |
not done it yet | 25/08/2016 23:57:02 |
7517 forum posts 20 photos | Don't try to complicate things. You do not need an infrared thermometer. Just check as I said earlier. A rev counter would be more appropriate. |
duncan webster | 26/08/2016 00:02:46 |
5307 forum posts 83 photos | Posted by Les Jones 1 on 25/08/2016 20:08:43:
Hi Duncan, Les. Not relevant. It starts OK at 50 psi, then gves up the ghost at 90 psi, when presumably it has been running for a while. How can this be down to the presence or not of an unloader valve? |
I.M. OUTAHERE | 26/08/2016 05:40:54 |
1468 forum posts 3 photos | I wonder if the check valve may be jamming shut at the end of the first cycle and binding up so it won't permit proper air flow ? Just a thought . P.s how old is it ? Ian |
Les Jones 1 | 26/08/2016 09:01:36 |
Swarf, Mostly! | 26/08/2016 10:29:11 |
753 forum posts 80 photos | Hi there, Russ, I hope that you find the solution to your problem soon, and that the fix is not costly. But I'd like to put in a plea that you come back and tell us all what the problem was and how you fixed it. It can be a touch frustrating when threads are inconclusive. Best regards, Swarf, Mostly! |
Dave Halford | 26/08/2016 20:12:06 |
2536 forum posts 24 photos | Firstly get a regulator and stop messing with the electrical stop start switch to vary the pressure they are meant to be set just under max pressure at the factory and then left alone. you have been cycling the motor twice as often than it should. These motors are not normally rated for constant running and can cook.
The check the fan is on the right way round some times they go on backwards and errrr suck!
Ed Duffner | 26/08/2016 22:36:05 |
863 forum posts 104 photos | Hi Russ, Does the compressor require oil or is it of the oil-less type? I'm wondering if it's starting to seize when it gets warm/hot? Ed. |
not done it yet | 27/08/2016 07:18:21 |
'Presence or not' or not working properly?
The very simple check/test of seeing if it works from zero pressure, immediately after showing signs of stalling, will indicate whether the motor is actually restarting correctly after a high pressure restart.
Very simple, easy to do and informative. The job needs analysing as to whether the problem is due to the motor not fully speeding or the compressor tightening up.
The motor is well oversized for the job. My 10cfm, @10 Bar, compressor has a 2HP motor, but only 1425rpm (so better starting characteristics)
Guessing is no good at all. Actual checking , to isolate the problem, is the first priority!.
Edited By not done it yet on 27/08/2016 07:21:05 |
Clive Foster | 27/08/2016 09:46:38 |
3630 forum posts 128 photos | Had similar problem with an Atlas Copco KE2 16 cu ft / min vee twin compressor when using enough air to require restarts at fairly frequent intervals, maybe 25 minutes or less. Turned out to be due to a partially blocked bleed down orifice on the controller leaving too much pressure in the outlet manifold so the capacitor start / capacitor run motor couldn't come properly up to speed before the backpressure got too high. Effectively motor ended up running at reduced power. Was told by a motor guru that cap start / cap run motors can settle at a reduced speed / reduced power run point if they aren't given time to get right up to speed before coming under full load. Don't understand motors well enought to know if this really is the case of if its an old guru's tale to sidestep pesky questions but it certainly fits with what I've seen in other cases where capacitor start / capacitor run motors have struggled. Especially the economy range types. In similar circumstances an ordinary capacitor rum motor will keep dropping back into, or never get out of, start mode but a capacitor start capacitor / run motor has a bit more low down punch. When sorted the Atals Copco outlet manifold bled down to atmospheric in about 3 minutes. Its volume was around 1/4 cu ft so I imagine providing a similar ratio of bled down volume to compressor output would endure that the motor will always come properly up to speed. Clive
Speedy Builder5 | 27/08/2016 10:21:55 |
2878 forum posts 248 photos | Dave H, Fan on backwards ? Apart from a mounting issue, there wouldn't be any difference would there? A Left Hand fan is a LH fan whichever way around (same for a Rh fan). Or have I blundered again. |
Russ B | 27/08/2016 10:31:10 |
Just a quick update as I'm replying from my phone. This morning from clock cold, with 50psi in the tank (it was 90 last night?) it struggled around 100psi and cut out. And then refuse to restart. I could spin the compressor with a single finger by its fan and could hear the reed valves popping so it was compressing. I removed (very carefully) one of the pipes between the cylinders (there are no check valaves between the 2) and restarted it, and nothing, the motor was just making angry grunting sounds while the fan wobbled as it attempted to move. Feeling brave I gave the fan a good spin with a stick to get it moving and see if it was stuck, but it didn't, and it wasn't. It feels very much like a motor issue. It only has one 40uF cap on top, I've no idea how to test it but I think I saw a capacitor testing machine at work (I've no idea what to do with it but I'll ask). I'll check the cap and then pull the motor apart if needed. The motor is part of the crankcase so I can't just change it. I'm hoping it's not also the crank but I've a feeling it almost certainly is - looks like a complete strip will be needed to look inside it.
