Stretcher Assembly, 5" Nigel Gresley 2-8-0 by Martin Evans
Michael Crawforth 1 | 16/08/2016 12:40:05 |
8 forum posts | The question is simple and i think i know the answer but just want to check up with you guys. The frames are riveted to the buffer and drag bars. How are the stretchers fixed ? I can only think they are bolted because the material thickness is quarter inch and there are no angle brackets to rivet through. That is my assumption anyway i hope you can guide me it the possible errors of my ways.
Michael
Neil Wyatt | 16/08/2016 13:01:42 |
![]() 19226 forum posts 749 photos 86 articles | Hi Michael, The question is simple but the answer depends on which loco you are building! Can you give us a clue Neil |
Michael Crawforth 1 | 16/08/2016 13:04:28 |
8 forum posts | 5" Nigel Gresley 2-8-0 by Martin Evans |
JasonB | 16/08/2016 13:08:57 |
![]() 25215 forum posts 3105 photos 1 articles | Yes stretchers most likely tapped to take screw/bolt fixings. You may also find that the angles on the buffers are only rivited to say the buffer but bolted through the frame which will allow for things to be taken apart at a later date if needed, not sure on that specific loco |
Michael Gilligan | 16/08/2016 13:26:30 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 16/08/2016 13:01:42:
Hi Michael, The question is simple but the answer depends on which loco you are building! Can you give us a clue Neil . Methinks the clue was in the subtitle. [or has that been added later ?] MichaelG. Edited By Michael Gilligan on 16/08/2016 13:28:12 |
Bob Brown 1 | 16/08/2016 13:27:44 |
![]() 1022 forum posts 127 photos | On my build of 5" Nigel Gresley 2-8-0 (still a long way to go) the stretchers are drilled and tapped and fixed with countersunk cap screws. How far into the build are you? |
Another JohnS | 16/08/2016 13:29:21 |
842 forum posts 56 photos | Hi Michael; I'm into 3-1/2" gauge, but should be the same. Yes, bolt the frames together, to angles on buffers, and directly into tapped holes in frame stretchers. One can braze/weld the frames together, but you need to be sure of your bracing when welding, and I don't think it saves much time, if any. On my latest 2 builds, I use metric cap screws onto the buffer "angles" rather than modellers bolts, as I think one can tighten them up more, and less likely to break. After painting, and tucked underneath running boards, behind steps etc, they are hard to see. If you don't like tapping into blind holes for the stretchers, one can drill holes (say, 6mm) across the plate, then drill in to the sides meeting these holes. That way, you can tap easily, and can see the tap coming through the drilled hole. I've not bothered, but the DB23 (3-1/2" gauge 2-6-2) plans from the Netherlands show this. |
Michael Crawforth 1 | 16/08/2016 13:30:46 |
8 forum posts | Looking at the drawings and actually loading the drawings into Autodesk Inventor 2016 so that i can make sure it all fits and works and that i am getting it right. I also means i can see it built before i start doing any actual engineering. However i started this model 28 years ago when at school and then sold it as i grew up How i regret that !! |
JasonB | 16/08/2016 13:32:05 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Michael Gilligan on 16/08/2016 13:26:30:
Methinks the clue was in the subtitle. [or has that been added later ?] Guilty as charged, but there is no way to leave any evidence |
Michael Crawforth 1 | 16/08/2016 13:50:13 |
8 forum posts | I can say that the original posting had it within when it was created |
Michael Gilligan | 16/08/2016 13:56:11 |
![]() 23121 forum posts 1360 photos | Thanks, Jason Neil's reputation is safe now MichaelG. |
Neil Wyatt | 16/08/2016 13:59:35 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Michael Gilligan on 16/08/2016 13:26:30:
Hi Michael, The question is simple but the answer depends on which loco you are building! Can you give us a clue Neil . Methinks the clue was in the subtitle. [or has that been added later ?] MichaelG. Edited By Michael Gilligan on 16/08/2016 13:28:12 Jason has been retconning ... ah, I see he has 'fessed up'. Neil |
julian atkins | 16/08/2016 23:09:19 |
![]() 1285 forum posts 353 photos | Hi Michael, You really need to get the full set of drawings and the construction series which was in in ME 1969-1970. I have the full set of MEs for this period if you have any queries. It is pretty obvious from the drawings how the frames are assembled to everything else, and the frames are NOT rivetted to the buffer beam angle or the drag box. Cheers, Julian |
JasonB | 17/08/2016 09:04:05 |
![]() 25215 forum posts 3105 photos 1 articles | Julian, I don't think it is obvious from the drawings how things are assembled, there are no holes shown in the ends of the stretchers, no holes shown in the angles where they fix to the frame. Although the frames show hole positions for angles and stretchers they don't give a size. I also don't think a beginner could tell how the buffer angles are fixed to the frames even with the text as "the usual ones" does not really give much away. Granted there is a clue about how the stretchers fit in the text. J |
Bob Brown 1 | 17/08/2016 10:01:39 |
![]() 1022 forum posts 127 photos | I have a full set of drawings and the construction series, the drawings are not that clear as to how the beams or stretchers are connected but the notes do mention the fixings for the beams. |
Kerrin Galvin | 17/08/2016 10:25:04 |
44 forum posts 9 photos | Hi Michael, I just happen to have a Nigel Gresley in the loco shed, aka my dads workshop. I didn't build it so off the top of my head can't answer your question but can go early next week to have a look and let you know. Maybe in the mean time somebody else will answer the question Cheers Kerrin
Bob Brown 1 | 17/08/2016 10:56:42 |
Edited By Bob Brown 1 on 17/08/2016 10:58:04 |
Michael Crawforth 1 | 18/08/2016 08:49:34 |
8 forum posts | Thanks very much to everyone and i am hoping to get going with it all very soon and even more so armed with the additional information. |
