7/8whit eye bolt
clogs07/07/2016 16:19:38
630 forum posts
12 photos
Hi all, anyone with a 7/8whit eye/lift bolt, have one to sell ?
I need to move my Colchester Student lathe onto and off lorries a couple of times.....have tried flee-bay etc and even can't find HT studding.....
next couple off months will do........
many thanks Clogs
Keith Long07/07/2016 17:27:15
883 forum posts
11 photos
I don't have one but they are in the Cromwell tools catalogue.
Mark Simpson 108/07/2016 17:36:03
115 forum posts
30 photos
How strange, I was just looking for the same thing... for the same reason... Moving my Student
£6.48 from these guys.  (becomes £18.58 whenyou add the VAT and carriage)
http://www.absoluteindustrial.co.uk/lifting-gear-c1/eyebolts-eyenuts-bownuts-c38/imperial-collared-eyebolts-to-bs-4278-p193/s1229?utm_source=google&utm_medium=cpc&utm_term=imperial-collared-eyebolts-to-bs-4278-thread-size-inch-thread-size-inch-ice06&utm_campaign=product%2Blisting%2Bads&gclid=COHWs_Sl5M0CFY4y0wodCCkI9A
Edited By Mark Simpson 1 on 08/07/2016 17:37:48
duncan webster08/07/2016 17:59:13
5307 forum posts
83 photos
Find your local lifting gear man in yellow pages, they should be able to order one in without the exorbitant delivery charges. In my area I'd use Warrington Chain
peak408/07/2016 22:00:06
2207 forum posts
210 photos
Or try a local electric motor re-winders; They're sometimes known as dynamo eyebolts for a reason.
p.s. Which part of Crete are you heading for? I'm quite envious of being able to get Cretan Raki on tap; the honey one particularly.
Just going by your "About Me" bit on the forum, I'm assuming you will struggle to get BSW stuff in France.
This Ad on ebay is listing a couple, so you could ask if he'd split one off for you, but they're not expensive new.
If you have a friend in the UK to post it to you Speedy Hire do them for less than a tenner plus vat
Edited By peak4 on 08/07/2016 22:11:59
julian atkins09/07/2016 01:06:46
1285 forum posts
353 photos
A 3/4" whit eye bolt will safely lift 16 cwt, from my bell restoration project days.
Cheers,
Julian
clogs09/07/2016 06:57:11
630 forum posts
12 photos
cheers Cmany thanks, great ideas........
bit worried by Julian Atkins comment tho...only 16cwt ????? have seen extra long threaded version (able to cut to length) I think the lathe is getting on for a ton ?
Whit and the UN threads are available here.....Most tractor repair shops sell em......
Chania, Not keen on the Raki but the honey is oh so good......
how did they get on at the factory.......?
cheers Clogs........
Michael Gilligan09/07/2016 07:33:32
23121 forum posts
1360 photos
Posted by clogs on 09/07/2016 06:57:11:
Don't worry ... A decent quality [forged & collared] 7/8" Whit. Lifting Eye should have a Safe Working Load of 2 Tons [vertical lift].
Caveat : Inferior items are available devil
Useful reference **LINK**
David Jupp09/07/2016 07:36:59
978 forum posts
26 photos
Posted by peak4 on 08/07/2016 22:00:06:
A Dynamo eyebolt is a slightly different form of eyebolt and has a slightly lower safe working load at a given thread size (compared to collar eyebolt). Probably won't make much difference to most of us, but just thought I'd mention.
Martin Connelly09/07/2016 08:35:33
2549 forum posts
235 photos
Dynamo eyebolt are limited to axial loads only. Collared eyebolt must be derated for loads off axis. Guides are available online and should be read if you are not conversant with the derating factors.
The link is to one example of eyebolt safety instructions. One thing it seems to be missing is instructions to only tighten eyebolts hand tight. Overtightening pre-stresses the threads and adds to the lifting stress on the threads effectively reducing safe working load in any configuration.
Martin
peak409/07/2016 09:43:42
2207 forum posts
210 photos
David, and Martin, you are both quite correct of course; I'd assumed, perhaps wrongly, that since only one was required, that the load would be more or less axial.
I can remember when I was more involved with motorsports vehicle recovery; I wrote a piece about exactly this topic, as folks often used them for winch hook anchor points on their Landrovers, when using a snatch block on the load.
Edited By peak4 on 09/07/2016 09:43:56
Mark Simpson 113/08/2016 13:50:15
115 forum posts
30 photos
I've found a new 7/8" UNC one, for the princely sum on £13.40, fits into my student and has just lifted it onto rollers without a problem. It's rated at 2T
I'm selling my student on, for a bigger lathe, and it will be available when I've done that
