sieg sc3 mini lathe precision ?
zuji miko27/06/2016 22:42:19
9 forum posts
hi !
i need to make some small parts but precise .
in 1'' length and 0.040'' diameter is one of peaces i will need to make.
i want to make small scale chopper V engine ,and scale u to 1:5 or every measure is divided by 5 ,so i will end up with bunch of small parts
i don't have late or mill yet,but thinking to buy sc3 and sieg X2-3 mill
but first problem is precision of these machines
will these machines be ok for these kind parts ?
thanks
John Haine28/06/2016 07:52:16
5563 forum posts
322 photos
To what tolerance do you need to work? The part you mention is 1mm diameter, and quite long for its diameter, and would be challenging for any lathe as it will bend as you cut it.
Neil Wyatt28/06/2016 08:41:51
19226 forum posts
749 photos
86 articles
When turning something like that to a high standard of accuracy, assuming the lathe is set up properly the result has more to do with the skill of the operator than quality of the machine.
As John says, it's the length:diameter ratio that matters here and the challenge is for the operator, the tool and the technique used - some form of custom travelling steady will help.
Finally, I assume this is a valve push rod (it can't be much else of a tiny V-twin. What about taking an alternative route and using precision ground 1mm silver steel?
Neil Lickfold28/06/2016 08:46:26
1025 forum posts
204 photos
The lathe won't be your issue. It will be making or buy the tooling to make what you want, like a roller box tool to make your pins and things like that.
Rainbows28/06/2016 09:29:51
658 forum posts
236 photos
Consider the tool that holds the bushing in this video to support the work right next to the tool
https://www.youtube.com/watch?v=IvERU6mpX88
Clive Hartland28/06/2016 12:21:33
2929 forum posts
41 photos
Regarding precision, that is up to your ability and selection of the right materiels for each application. Why turn something when it is available in another suitable form.
The mill, fit optical scales and work to .02 or even less.
here again28/06/2016 16:16:31
70 forum posts
Stewart Hart s travelling steady had a couple of pages in ME or MEW last year..I made some something similar for the same job..I bought a Chester small fixed steady too as its the only one I found with enough metal on the fingers to drill holes in and add rollers
john carruthers28/06/2016 18:00:55
617 forum posts
180 photos
Hi Zuji, I have an sc3 and can, when necessary, work to +- 0.01mm with a sharp tool. If a better fit is required then grind or file and paper it.
What will you be using to measure the parts? my calipers only claim 0.005mm (if they are to be believed) and my mic was good to 0.0005" but it's had a lot of use since then.
zuji miko28/06/2016 19:01:52
9 forum posts
thanks for answers .
now some more questions ..)
my plan i to use tool that take diamond shape inserts (hate grinding i worked on 4g cnc only so no manual work)
and material will be spring steel (from truck sheet spring)
so question is will i be ok for these kind measures if i go to smaller sc2 and x1 mill too ?
(don't have much space for tools ,plus i live in 4 store building and i'm on third so more weight on stares is huh too )
and second ,any suggestions for precise tools ,for mill and lathe ? for lathe ones that take diamond inserts
thanks again
