Member postings for zuji miko
Here is a list of all the postings zuji miko has made in our forums. Click on a thread name to jump to the thread.
Thread: Has anybody have harley/indian (from50's)like v-engine plans?
12/08/2016 21:43:35
no luck .i searched local fleemarket for hd like v-twin kind engine closest i can get is yamaha virgo busted engine
so no luck
Edited By zuji miko on 12/08/2016 22:31:28
06/08/2016 17:26:30
so only solution is to buy real engine and ,disassemble it ,and do measures
huh
06/08/2016 16:10:14
i downloaded one v-engine in autocad format from hotrods forum
description was "1:1 scale hd 59' v-engine " so i started to make one in 1:4 scale ,so i divided all measures by 4 ,and make one
but problem started with all small parts (my errors) ,and end up with engine housing been wrong size on autocad drawing
i give plans to guy to make housing ,his firm make smelted metal injection kind housings from alu to hi grade steel
and he tell me this wont work ,cause no space for rest parts in housing
by acad drawings
so i send msg to guy that post it and he send me link to grabcad site and ...
bad drawing
so anyone have drawings of some kind hd/indian kind chopper v-engine from 50's that are accurate
thanks
Thread: Rotary table
30/07/2016 11:20:52
one with tilting will be great too ,,,
30/07/2016 09:20:45
small that fit to sieg sx2 mill table ,i think 100mm will be ok but ??
29/07/2016 21:41:09
will ask here for advice ,
what is best small rotary table on cheap side ?
i watch on ebay and all around net but all of them are 150 + $Ł€
find some indian garbage for less but with post exp. it cost same
are they all in that 150+ price range (with chuck) ?
thanks
Edited By zuji miko on 29/07/2016 21:42:40
Thread: lathe ,and er32 collet ...
17/07/2016 16:50:25
which one is ok .for smaller peaces ?
http://chronos.ltd.uk/acatalog/ER32-Collet-Chucks---Collets-for-Lathe-Mounting.html
or one of these
http://www.rdgtools.co.uk/acatalog/ER32_SPRING_COLLET_CHUCK_SYSTEMS.html
2-20mm range ,but how to mount it .... they sell only collet chucks ..
Thread: sieg sc3 mini lathe precision ?
28/06/2016 19:01:52
thanks for answers .
now some more questions ..)
my plan i to use tool that take diamond shape inserts (hate grinding i worked on 4g cnc only so no manual work)
and material will be spring steel (from truck sheet spring)
so question is will i be ok for these kind measures if i go to smaller sc2 and x1 mill too ?
(don't have much space for tools ,plus i live in 4 store building and i'm on third so more weight on stares is huh too )
and second ,any suggestions for precise tools ,for mill and lathe ? for lathe ones that take diamond inserts
thanks again
27/06/2016 22:42:19
hi !
i need to make some small parts but precise .
in 1'' length and 0.040'' diameter is one of peaces i will need to make.
i want to make small scale chopper V engine ,and scale u to 1:5 or every measure is divided by 5 ,so i will end up with bunch of small parts
i don't have late or mill yet,but thinking to buy sc3 and sieg X2-3 mill
but first problem is precision of these machines
will these machines be ok for these kind parts ?
thanks
