Suitable Phosphor Bronze
For full size pump
Windy23/06/2016 08:52:07
910 forum posts
197 photos
Have been looking at various pumps for my full size flash steam project and considered using a commercial high pressure power washer pump which has ceramic pistons etc..
The steam car brigade use them as well but cost has put me off so will probably make a simple type similar to my model.
As with the model the pump cylinder would be a bronze cylinder pressed into an aluminium body.
Ram would be stainless but would like to use bronze tube for cylinder as it's such a waste of material machining from solid bar.
What grade of PB would be suitable if available in tube form it's also got to be tough and wear resistant.
The pump stroke is going about 2,000rpm maximum the model is a lot higher than that.
Michael Gilligan23/06/2016 09:12:48
23121 forum posts
1360 photos
I'm almost sure that I have one of those pumps tucked away somewhere [condition unknown!]
Even if it's clapped-out: It would presumably make a good starting point for a custom build.
If you are interested [priced at the value of the bronze, plus shipping] let me know.
Ajohnw23/06/2016 09:40:27
3631 forum posts
160 photos
I found this site useful for info on bronzes that are likely to be easy to get
As SAE660 seems to be widely used. It might be the one you could get in tube form. I've only seen bronzes that have a hole in the middle - the walls are a bit thick to be called tube. eg this site. They also stock other bronzes.
I believe they may handle mail orders.
Edited By Ajohnw on 23/06/2016 09:48:16
John Stevenson23/06/2016 09:55:03
5068 forum posts
If you want bronze, then give Leeds Bronze a ring.
They do mail order and delivery but £30 minimum charge which isn't bad as most bronze orders will be well over that
Ian S C23/06/2016 12:46:47
7468 forum posts
230 photos
I know I can get bronze as hollow bar here in NZ. Ian S C
Michael Gilligan24/06/2016 18:15:26
23121 forum posts
1360 photos
Posted by Michael Gilligan on 23/06/2016 09:12:48:
Paul,
Here is my pump ... is this the sort of thing you are looking for ?
As stated, the condition is unknown: but it does turn over nicely with finger-pressure applied to the pulley.
For scale: The wooden box is about 11" wide.
Total weight is about 18kg
Sorry ... Main picture file size seems to be too big ... I will re-size and post later
Edited By Michael Gilligan on 24/06/2016 18:28:51
Michael Gilligan24/06/2016 18:24:01
23121 forum posts
1360 photos
Windy24/06/2016 20:47:36
910 forum posts
197 photos
Thank you very much for the pictures and information I think the pressure might be not be high enough for my applications and weight is bit too high.
Looks like I will have to make my own maybe incorporate it in main body of the power plant to keep compact.
Thanks again for going to all the trouble finding it for me to consider if suitable..
Michael Gilligan24/06/2016 21:07:07
23121 forum posts
1360 photos
You're welcome, Paul
I will nail the lid back on its box.
