ROBERT BLACKSHAW | 01/06/2016 16:05:57 |
46 forum posts 13 photos | I broke my bandsaw blade on my CY90 new bandsaw cutting 80mm aluminium round. I am a bit confused with the size required it states 51 inch x 1/2 I have looked on line but it seems rather baffling different teeth per inch and sizes. The Warco bi metal are rather expensive at £28.00, any recommended retailer out there that wont cost a fortune. The old blade carbon broke on the weld, I have only used it a few times, again any advice on blade type will be appreciated |
Rik Shaw | 01/06/2016 16:22:54 |
![]() 1494 forum posts 403 photos | Just give Ian a ring and tell him make and model and he will sort you out. Tuff Saws Rik |
BC Prof | 01/06/2016 16:38:52 |
182 forum posts 1 photos | Another vote for Tuff Saws . My CY90 clone uses 51 1/4 " x 1/2" 14 TPI carbon blades . On the only occasion that a blade has broken on the weld Ian replaced it with no problems .
Brian C |
Brian Wood | 01/06/2016 18:12:51 |
2742 forum posts 39 photos | Robert, I would be inclined to use 10 tpi blades, they are less likely to clog on bar cuts. The 14 tpi blades are better suited to cutting tube and thin sections. The usual guide is to aim at keeping two teeth engaged in the cut with thin sections, coarse blades bridge over the wall thickness and are likely to snatch with unpredictable results. Regards Brian
Peter Tucker | 01/06/2016 18:46:58 |
185 forum posts | Hi Robert, You should take the blade back to where you bought it an have it repaired or replaced. For a new band you could look here (usual disclaimer). Hope this helps. Peter. |
Brian Wood | 01/06/2016 19:00:53 |
Ian S C | 02/06/2016 12:21:00 |
![]() 7468 forum posts 230 photos | Most outfits in NZ will rejoin bi metal blades broken at the weld free of charge, I had 3 of them break because of a problem the firm had been having with faulty tempering, they were sent to Auckland (the other end of the country, some would say another country). Ian S C |
ROBERT BLACKSHAW | 02/06/2016 12:29:01 |
46 forum posts 13 photos | Thanks for all replies. I phoned Warco about the broken blade and they said that they will send a replacement, but I will get a bi metal blade as a spare 10 tpi. Thanks again. |
John McNamara | 02/06/2016 14:16:12 |
![]() 1377 forum posts 133 photos | I order my blades from a Starrett supplier. Regards
