Myford 280 regrind.
Russ B | 19/05/2016 13:07:19 |
635 forum posts 34 photos | This is a very, very open post/question, I welcome any comments, shared experiences, advice, warnings, anything, This is new ground for me and I'm not sure what to expect. I've received a quote to have my lathe bed reground (a Myford 280). The bed wear on the front vee is visible to the naked eye with a lip on top. I love the lathe, everything else is in fine fettle although I will be rechecking a few things when it comes to stripping it down to send the bed and saddle castings off. I don't know what to expect, will the spindle bolt back down nicely or will it need scraping in - would it benefit from scraping in anyway (I like scraping, but some things are just best left alone/to the professionals!) Overall, I'm really looking forward to it but I'm a bit unsure what to expect when it comes to bolting it all back together. |
Bazyle | 19/05/2016 13:32:40 |
![]() 6956 forum posts 229 photos | No experience but if the headstock mounts on the bed that has been ground down then it will be lower. The tailstock will be lower by the same amount assuming they ground the second set of ways the same. However it is likely the tailstock ways are less worn but the the tailstock base is worn so it would end up low. If possible get them to minimise the tailstock way grind so the tailstock base can be skimmed to make it match the headstock. If the saddle is ground and scraped to the bed without the turcite it will be a few thou lower but that doesn't matter. I see no point in the turcite which is intended to obviate the extra expense of grind and scrape, and to relevel the top of the topslide if worn assymetrically. That is only necessary if you use it as a boring table. |
Peter Krogh | 19/05/2016 15:07:48 |
![]() 228 forum posts 20 photos | I don't know the geometry of the Myford very well. That said I would suggest talking over the job with the rebuilder as he will have the necessary knowledge as to fitting the head stock and tail stock. Most lathes do require some fitting there to achieve best alignment. Pete
Russ B | 19/05/2016 15:10:43 |
635 forum posts 34 photos | Bazyle thanks, they have assured me they will be grinding the minimum possible off the bed. I did think about the tailstock and if needed, I will (attempt) to make a new base from scratch and hand scrape it to fit. (attempt being the key word here) I need to make a fixed steady so I will get a bit of practice in on something less important first. Below is a photo of the wear on the front of the vee, as you can see from the lip on top it's pretty significant thus I doubt just a few thou will do the job. The lip is so big I originally thought it was supposed to be there till I noticed the tailstock end has nothing! The quote has jumped from a little over £600, to a little under £900 (as he thought it was a different machine) Considering the only other Myfords all have flat way beds, the increase in price is very small when taking in to account the additional work required to grind the 4 vee faces on the bed and apply and grind turcite to an additional 4 faces on the saddle - he's going to be a busy boy! Still, I think I will then have a nice metric machine that will last me a lifetime with ample TLC and im only 29!!!
Peter, Edited By Russ B on 19/05/2016 15:15:47 |
Ajohnw | 19/05/2016 16:19:19 |
3631 forum posts 160 photos | I'm not familiar with this lathe but if the bed is reground the general dimensions should be maintained. Just moved down a touch is a another way of putting it so the rails become a touch thinner. It looks like the head and tailstock are located on the same V and flat so nothing will change in terms of how these fit. Both the V and the flats have to be ground to achieve this. The saddle is also probably located on the other V and flat so nothing changes there either. If the bed is worn the saddle is bound to be. Some slideway grinders have a sub table at the end. This carries the saddle and can be used to ensure that the V in it and the flat correctly match the bed. One thing I would mention to them is that you do want to be able to face near square to the original specification. That will be very very slightly concave. I've had to mention that when I have had a cross slide reground. It takes very careful setting up. I'm not sure how well this works out when the underside of the saddle is being ground as well. My father had lots of machines reconditioned - big advantage as he put lots of that sort of work out. In order to minimise the amount of material removed from the bed he told them to stand the bed upside down on parallels directly under the feet and take their 0.030 off the feet. Then put the feet where the parallels where, clock up the bed and regrind it. He'd even mic up the bed so he could check how much had been removed. If more than he thought it should be - no payment. I don't think many just take that sort of amount off a bed now but packing under the saddle probable does help them with setting up. John - |
bricky | 19/05/2016 17:48:50 |
627 forum posts 72 photos | I have a Myford S7 mark 1,I had this reground at Myford 2005 and have never regretted it.It is so accurate I prefer it to the S7 large bore for the odd jobs that require precision.I would certainly have it done. Frank |
John McNamara | 20/05/2016 10:00:20 |
![]() 1377 forum posts 133 photos | Turcite? an alternative is Moglice **LINK** The turcite I know of is glued on in strips, it then has to be scraped down to fit. Moglice is an Epoxy composite that is spread on then you use the bed as a pattern. For one job it would probably be less expensive to buy Moglice. On my lathe the headstock is located by an extension of the actual ways, so there was no alignment problem there, it simply bolted back on..... Ok with a tiny bit of scraping. The saddle is a more interesting project. It must be set in exactly the same position as it was when the lathe was new and not worn, otherwise the driving rack and pinion, leadscrew, and control bar if the lathe has one will be out of line. |
Russ B | 20/05/2016 11:46:22 |
635 forum posts 34 photos | John, you deserve a medal for that explanation - It's like I was with you in the room! My bed ways extend end to end and the headstock simply sits on the vees and maybe it touches the flats but I haven't stripped it down yet. I have been leaving the stripping job till last in a (vain) attempt to ensure I can machine/scrape any templates/standards/jigs I need before I start - its almost like I actually believe things will go according to a plan!!! The process of machining the jacking plates and fitting them to the saddle sounds very very much like the easy part. This Moglice certainly opens doors and given my limited budget, and limited confidence in "as ground" fits - this is right up my street. I think the cross slide will need quite a bit of scraping in anyway. It is visibly worn. I think it would be unwise to take reference from the cross slide dove tails or the bearing vee's underneath.
Edited By Russ B on 20/05/2016 11:58:10 |
John McNamara | 20/05/2016 12:56:06 |
![]() 1377 forum posts 133 photos | Hi Russ The contractors you are in discussion with have indicated that they will use Turcite and grind it in. I guess the real question is how accurately will they align the saddle? setting it up against the spindle axis. Will they do it to the Lathes original specification? As an aside the head on my lathe also sits on the v's however the fitter who assembled the lathe when new had done a little scraping to tweak the fit against the v's I found it when I disassembled it. The as ground set up was not quite to spec. One would hope your contractor would do the same. Dr Schlesingers classic book I believe out of copyright he passed away over 50 years ago should be found here: **LINK** Edited By John McNamara on 20/05/2016 13:16:05 |
Russ B | 20/05/2016 14:02:39 |
635 forum posts 34 photos | John, Thank you I will look at the book very soon, as it's far more condensed than the texts I currently follow! I will also digest your post in full soon once I have time to get my concentrating cap on (real work keeps getting in the way of the fun stuff!) Many thanks, |
Hopper | 20/05/2016 14:20:12 |
![]() 7881 forum posts 397 photos | Have you contacted the Myford company about getting your regrind job done? They would be more familiar with the machine. I can't see the value in paying 900 squids to get the bed reground then turciting or moglicing the carriage, cross slide etc. Properly done metal to metal is going to give you the closest to "as new".
Hopper | 20/05/2016 14:35:57 |
![]() 7881 forum posts 397 photos | Posted by Russ B on 20/05/2016 11:46:22:...
...I think the cross slide will need quite a bit of scraping in anyway. It is visibly worn. I think it would be unwise to take reference from the cross slide dove tails or the bearing vee's underneath. ... A common way of doing it is to use the unworn side of the crosslide dovetail that is covered by the gib strip (the one where the gib screws are drilled and tapped through it) as first reference. The opposite side of the dovetail is scraped parallel to this using rollers and a mike to measure the distance, and a prismatic straight edge (you do have one of those ?) to get is flat, straight and to the correct angle. The mating fixed dovetail surface is then scraped to match this surface. Then the other side of the fixed dovetail is scraped parallel to this using roller and mike and prismatic straight edge. Then, the V ways in the bottom of the carriage have to be scraped to match the newly ground bed. It is here that the setting of the angle of the cross slide ways relative to the lathe's main axis is set. So you are scraping to mate the four surfaces of the V ways, and to sit the carriage level in the x axis, and to set the carriage level in the Y axis, and to set the cross slide to turn half to one though concave over the radius of the faceplate. Plus, it all has to be done without removing more metal than the halfnut adjustment can accommodate to maintain leadscrew alignment. No mean feat. Probably not the ideal place to learn to scrape. You might want to try making yourself a surface plate, couple of camel back straight edges and a prismatic straight edge first, just to get your scraping skills up to scratch. BTW, I have read that there is also a business out there run by two former fitters from the Myford works who do reconditioning work. Not sure who they are or their business name but I am sure others on here will know. They may be helpful to you? PS, these guys may be of help to you too. http://www.lathespares.co.uk/myford-machining-grinding-servicing Their prices for cross slide and saddle regrinding seem pretty reaonalbe, although their quotes are for ML7 etc and not your 280. Still, at that price it probably is not worth getting into the whole scraping thing. Edited By Hopper on 20/05/2016 14:44:28 Edited By Hopper on 20/05/2016 14:44:59 Edited By Hopper on 20/05/2016 14:56:34 |
Russ B | 20/05/2016 14:54:24 |
635 forum posts 34 photos | I have contacted them, the Myford 280 might as well have been made by aliens and beamed down from space because no information or history seems to exists -it's as if all things Myford 280 related was locked in a box and thrown in the ocean to make way for the smaller, simpler and cheaper to produce 254's which caught the markets attention. "up to scratch" |
Hopper | 20/05/2016 15:00:03 |
![]() 7881 forum posts 397 photos | Posted by Russ B on 20/05/2016 14:54:24:
I have contacted them, the Myford 280 might as well have been made by aliens and beamed down from space because no information or history seems to exists -it's as if all things Myford 280 related was locked in a box and thrown in the ocean to make way for the smaller, simpler and cheaper to produce 254's which caught the markets attention. "up to scratch" LOLz, Yes, sounds like my scraping altogether. See the PS I just added re lathespares.co.uk above. Unless they decline to touch the alien lathe too? If your contractor fellow can do the cross slide and saddle regrinding for similar prices maybe be you should trust him to do the job. (properly, not turciting about etc) Main catch would be that there is some means of moving the halfnuts etc upwards by the amount that is taken off the lathe bed and the saddle ways so the nut lines up with the leadscrew still. And even if the regrinder did mess up and not get the cross slide turning the needed half thou concave, a relatively small amount of scraping of the saddle V ways would fix that. Much easier than scraping the whole job. Edited By Hopper on 20/05/2016 15:05:20 |
Russ B | 20/05/2016 15:00:36 |
635 forum posts 34 photos | It must be noted that the bed is NOT a flat way bed and thus not like any other Myford ever produced. It could perhaps be more familiar in the hands of an experienced Harrison or Boxford fitter. |
Hopper | 20/05/2016 15:11:56 |
![]() 7881 forum posts 397 photos | Any machine tool fitter worth his salt should not have a problem with V ways. Other than Myford, they are pretty much an industry standard these days. Same with the regrinding. It is just a matter of using the same grinding machine but with different wheel set up. (Providing their grinder is not some stone-age relic ) Just costs more because you have a bit more set up time and fiddling about for the V ways. which probably has a lot to do with why Myford used flat ways in the first place. |
Russ B | 20/05/2016 15:33:54 |
635 forum posts 34 photos | I much prefer flat ways. The Myford 280's Vee shears are completely removable from the bed casting - I could convert it to precision ground flat ways and take care of the whole scrape job. I'd just need a new saddle (simple enough we're talking flat ways) and a precise adaptor for the headstock * tailstock - I might as well bump the centre height up to 150mm while I'm there! However I think I'd better not chop up a piece of nearly lost Myford heritage!
mgnbuk | 20/05/2016 17:19:09 |
1394 forum posts 103 photos | The turcite I know of is glued on in strips, it then has to be scraped down to fit. Moglice is an Epoxy composite that is spread on then you use the bed as a pattern. For one job it would probably be less expensive to buy Moglice I have had the misfortune to come into contact with Moglice in the past, both on fresh installations on new build machines & during rebuilds. Compared to Turcite it is a most unfriendly material to work with, being very abrasive to scrape (the MTB I worked for who designed a vertical milling machine around injecting the stuff always ended up scraping it - mainly to match in the patched blow holes & bits that came away stuck to the release compound). The main problem with it is it's lack of long-term adhesion to the parent metal - I have come across this on mass produced machines (Deckel milling machine - possibly injected) & short run machines (Crawford Swift lathe - trowel applied), where it looked on first inspection to be in good condition, but a bit of tapping with a blunt instrument (file handle) showed large areas that were no longer bonded. Where it is attached properly you get a nice "ting" sound, like tapping directly onto the parent casting, where it is loose it gives a dull "thock" - the loosening appeared to start near the oil holes & radiated outwards as the oil got between the Moglice & the casting (something that doesn't seem to happen with Turcite). I have seen this stuff stripped off a casting with a wall paper stripper - which is probably why most MTBs use Turcite or a similar tape glued on & not Moglice. This not to say that Turcite (or simliar) tapes cannot come adrift but such occurrences were rare and, given that this is the predominant system, as a percentage of installations quite low. Whereas pretty well 100% of Moglice (or similar) installations I came into contact with had some kind of problem - either during installation or during refurbishment. This could be initial adherence, where the stuff would steadfastly refuse to stick to thoroughly degreased, rough planed surfaces, but would stick tenaciously to the carefully applied release agent on the ground way. Or coming loose in service, as described above. Or, on the one occasion I can recall where the Moglice was still servicable during a rebuild, the abrasive nature of the cured material caused a lot of problems - we ended up buying two boxes of Sandvik carbide scraper inserts (20 inserts). One pass over the face blunted the scraper edge, 4 edges per blade - we usually had one box of inserts away to be diamond lapped while the fitter worked through the other box, with a box going to & from the grinder every couple of days for nigh on a fortnight ! In hindsight it would probably have been cheaper to have stripped the Moglice off & replaced it with a tape system, where 1 scraper insert would have completed the job. IIRC the minium working thickness for Turcite is 0.5mm, so by the time the bed & saddle have been cleaned up, chances are that little extra will have to be machined off the saddle to get the Turcite in.. It is easy to machine and to scrape, works well with marginal lubrication (IIRC Moglice doesn't) wears well & is kind to the slides. It can also absorb debris to a limited extent (Moglice scores). Given a choice, I would choose Turcite, Guidecoat or Rulon (the latter two used by my previous employer) in preference to Moglice - TBH I would probably prefer metal to metal to Moglice ! As the Turcite strip can be bought in different widths & thicknesses, the cost is not likely to be major part of the overall quote. IIRC the glue could cost almost as much as the tape for smaller jobs when I had to order it, though a specialist would most likely have part-used tins to hand. (properly, not turciting about etc) Adding Turcite is an enhancement, not a "bodge" as implied here ! That it should return the apron mounting face to close to it's original position relative to the bed is making life a lot easier at rebuild time. I am a bit suprised that the contractor you have approached is not regrinding the cross slide & ways as well as the saddle & bed - the guys I used to use would have done. Ask him to grind the tops of the "vees" at the same time if he had not intended to to do so - somewhere to sit the level without having to use parallels off the flats & that will not wear in operation for subsequent checks. I doubt that your headstock will need much work, but you will need a test bar to check the alignment when you come to rebuild the machine. I would also strongly suggest buying or borrowing a precision level & not relying upon the much quoted "Rollie's Dad's Method" (whoever Rollie's Dad was). Not intending any antagonism towards John McN here - just that my industrial experience of Moglice & the like has been uniformally negative. Nigel B
SteveI | 20/05/2016 18:59:45 |
248 forum posts 22 photos | Russ, I am very much a beginner to machine rebuild. So take that in to consideration if you read my post further.
There has been a lot of interesting replies to this post. You have not indicated your level of experience with lathe rebuilding. Are you an accomplished rebuilder? Scraper? Perhaps the advice could better target your competency if you let us know.
If this is your first time and you do not intend to rebuild another machine then I would suggest to consider taking the professional up on their quote. If you are determined to rebuild it yourself then if you consider this lathe to be a “keeper” then I would respectfully suggest buying something else to practice on and make all the mistakes on. For example something with lots of cheap replacement castings in case you make a mess of it. Then you will stand a much better chance of doing a rebuild that brings the 280 back to factory tolerance or better. Furthermore especially given your age you want to rebuild it so it wears in before it wears out. Finally the tooling needed to do a good job unless you are very lucky or plan to “rebuild the tooling” (scrape in your surface plates, straight edges etc as part of the journey will not come cheap. If this is your only lathe then some useful tooling you can make that will make the job easier and better, but needs a lathe to make! Having said all that I have met people that have rebuilt machine tools (one of whom has done it professionally his whole life) and they all say if you can rebuild a lathe you can rebuild anything. I.e. it is not trivial to rebuild a lathe.
If you do decide to rebuild yourself you need to find your references and go from there. It is most likely every casting will have an original unworn machined area which was used in the original machining, grinding and/or scraping as a reference. Furthermore you can often find an area of the prismatic ways or a bearing surface that is unworn and then measure the amount of wear you have from that. In addition you can measure what you have taken off in the grinding or scraping. First job is to play detective and take notes. Don't grind or scrape anything until you know what you are dealing with. You can build a tool called a “kingway” (google it) to help you do that.
I am not sure some of the comments on turcite at the beginning are accurate. Regarding the use of turcite; you need the casting that is worn to be ground or scraped back square and you need to know how much has been taken off to use the most appropriate thickness of turcite (or adjust other dependent items to fit the new dimensions). You will need to fill with epoxy and then recut the oil channels for lubrication and scrape it. Turcite should not be used to obviate the need for grinding (to recover the geometry) or scraping (to recover the geometry and/or get the quality of bearing, it is going when glued to a geometrically square casting bearing surface to allow you to recover the original dimensions and have a "better" bearing. Turcite has low stick slip and can be much more easily scraped. It makes a nice smooth lathe into a super smooth delight. And when it wears out simply replace it knowing that the metal is still geometrically sound underneath it. Since you don't have a gap bed on this lathe type I would personally consider turcite if you are going to all this effort. I have an equivalent on the underside of the carriage on my new to me lathe that is almost finished rebuilt, in addition I plan to use it on the back of the knee and underside of the saddle of my bridgeport when I get to that stage in the rebuild. A metal on metal bearing may have been factory original but a modern design might have turcite from the factory. It is that good.
Finally if you do out source the job. Ask the rebuilder about their scraping and get pictures or see examples of their work. The bed should be ground as it is hardened. However what do they plan to do on the other castings bearing surfaces? I have spoken with a few UK based rebuilders and the norm seems to be to scrape but only to "break up" the ground bearing to provide some oil pockets. E.g. this would be running up and down with a half moon BIAX. On the size of machines we are talking about you get 0.0002" over the whole way. The half moon scraping they do is simply to break up the bearing surfaces after grinding to avoid stick slip and galling. On your size lathe this would take a short time for a rebuilder with a Half moon BIAX. My bridgeport ways from the factory were ground and given the half moon treatment. Much much cheaper. Do you know what the Myford factory approach was?
The old fashioned top quality scraping to 20, or 40 Points per inch 50% bearing is not often done. (When I have asked about it some places I get a funny look; others that are more knowledgeable state it would be too expensive, time consuming and no one will pay for it. So if you want it will cost a fortune or you have to DIY!) This results in a much better quality bearing which the experts say should last longer. If you want that ask the rebuilder to just grind all the ways and send it back to you for scraping or have deep pockets.
Regards, Steve |
Ajohnw | 20/05/2016 19:01:10 |
3631 forum posts 160 photos | I don't know if you were in the room with this John or another John. However
As far as I am aware the saddle side of the cross slide can be reground after the underside of the saddle has been done. It would also pay to have the actual cross slide done as well so that the angles match. It will also probably be worth while having the gib strip reground flat or fitting a new one.
The subtable carries the saddle upside down with the V's in it offset from the bed V's. Then when ones side of the bed V is ground the opposite mating side of the V in the saddle can be ground at the same time. This ensures that the angles match. It unusual to find lathes where the saddle rests on 2 V's. More often the rear V in the saddle that can be seen is clear of the bed and that side rests on the flat. I'm not saying it's never been done but getting V's to match up when there are 2 used like that is tricky to say the least - even a thou error would prevent them from mating correctly. Scraping - forget it. Get all of the parts ground correctly. They need to match the manufacturers V angle closely os that the headstock and tailstock fit correctly. On your bed wear just for interest the typical more recent lathe designs encourage that sort of thing because the guides on the saddle can't pass the head. Where they do the tool loads are applied more evenly along the guides rather than right at the end. John - |
