Jasons tips
Nick_G06/04/2016 19:45:00
1808 forum posts
744 photos
Jason suggested these tips to me recently for use on bronze.
I had roughed out most of the flywheel but waited for these to do the final couple of cuts.
They did the job in a most admirable way. smiley
So. ........... What else are they good for. ........ Talk to me, tell me.? smiley
Nick
Andrew Johnston06/04/2016 19:58:03
7061 forum posts
719 photos
It's difficult to tell but the video doesn't look like a CCGT insert, more like CCMT? I'd expect the insert to be highly polished and with a distinct rake angle for CCGT. May be it's just that the screen definition isn't adequate. I haven't tried CCGT on bronze, CCMT works fine for me. I use CCGT on aluminium alloys and plastics.
Nick_G06/04/2016 20:04:06
1808 forum posts
744 photos
Posted by Andrew Johnston on 06/04/2016 19:58:03:
Well it came out of that box that was sealed when I got it. question
Nick
Michael Gilligan06/04/2016 20:10:14
23121 forum posts
1360 photos
Posted by Nick_G on 06/04/2016 19:45:00:
By the looks of that finish, Nick ... you might try making a telescope mirror devil
... You just need a clever device to generate the parabolic tool-path !
JasonB06/04/2016 20:31:00
As Andrew says they do look a bit dull rather than the usual bright finish and not as high a rake at the tip, if you know anyone whao can take a half decent photo maybe they could take a close up of one of the tips. Though I have not used Sandvik ones.
I use them on brass, bronze and ali and sometimes on steel and stainless steel particularly long thin parts as the sharper edge does not push the work away from the tip
Nick_G06/04/2016 20:44:52
1808 forum posts
744 photos
Nick
JasonB06/04/2016 20:58:44
Definately don't look like the usual **GT tips, you also have a larger tip radius than I usually go for. Will take a pic of mine in the morning.
J
Andrew Johnston06/04/2016 21:32:40
7061 forum posts
719 photos
Here are examples of my inserts, CCMT on the left and CCGT on the right:
Both inserts are 09 size and 0.4mm nose radius. Manufacturer is Korloy. While details of the chip breaker will change, the basic form will remain the same across manufacturers. Two things to note for the insert on the right - it has a much sharper edge, and the rake angle is greater.
Nick_G06/04/2016 21:38:32
1808 forum posts
744 photos
I take your point Andrew.
Looks like an ebay vendor had me over.
Nick
steamdave06/04/2016 21:53:34
526 forum posts
45 photos
But they still did the job OK. That's a positive (as well as the rake).
The Emerald Isle
opochka06/04/2016 22:11:55
33 forum posts
5 photos
You could look through the Sandvik catalogue to find the best tips for your material........
http://www2.coromant.sandvik.com/coromant/pdf/Metalworking_Products_061/main_a_1.pdf
Emgee06/04/2016 22:27:53
2610 forum posts
312 photos
Ground finish (GT) H13A is the recommended grade for non ferrous materials, especially aluminium, H10A is also a suitable substitute.
Emgee
Ed Duffner07/04/2016 04:37:51
863 forum posts
104 photos
Posted by Michael Gilligan on 06/04/2016 20:10:14:
My lathe can do that if I forget to lock the saddle when taking a facing cut.
Nick have you tried those tips on brass at all?
Ed.
Edited By Ed Duffner on 07/04/2016 05:23:00
Raymond Anderson07/04/2016 08:02:05
785 forum posts
152 photos
Folks, All **GT inserts are not always polished as in Andrews pic, some are coated. I have some from Korloy and ARNO Werkzeuge that are coated [I will post a pic later when time permits ] Although whether coated or uncoated they all share the same high rake angle as shown in the right hand pic from Andrew. Nick_G ,yours certainly look to be CCMT. Because ** GT inserts are usually a bit more expensive than the standard **MT. the seller maybe tried [and maybe Succeeded ] in pulling a fast one. I dunno about that. Best to go through the Sandvik Coromant catalogue and find out. Although they look to be performing ok.
Raymond Anderson07/04/2016 09:42:55
785 forum posts
152 photos
Just been looking through the Sandvik Coromant catalogue and Nicks inserts are indeed CCGT So the Ebay seller had described them correctly.
Nick_G07/04/2016 09:48:56
1808 forum posts
744 photos
Posted by Raymond Anderson on 07/04/2016 09:42:55:
Thanks for that info Raymond.
The pack of 10 was sealed so someone would then have had to make a false label and reseal them. - Strange though that they differ so much from the normal ones.
If I get chance later I will try them on some brass and aluminium and report back here.
Cheers, Nick
Raymond Anderson07/04/2016 09:58:50
785 forum posts
152 photos
I have the Hard copy here, [all me cats are hard copies, as I hate reading too long off a screen ] and they are on page 11 of the Small part machining section. Would think the download cat would be the same.
Cheers.
Edited By Raymond Anderson on 07/04/2016 09:59:22
Michael Gilligan07/04/2016 10:17:12
23121 forum posts
1360 photos
Posted by Raymond Anderson on 07/04/2016 09:58:50:
Would like to think that ^^^ but can't tell
The PDF only covers the first few pages ... then on p9
If you want to view the next page please click HERE!
... but [at least on my iPad] the word HERE! is not hyperlinked. crying 2
Edit: ... so I went to this page, where they offer the catalogues 'online'
Automatically detected the type of device, and redirected me to the AppStore
Wonderful ... except that the App is for iOS 7.1 and later [and I'm still on 5.1.1]
Defeated by technolgy.  ... YES there's a lot to be said for paper.
Edited By Michael Gilligan on 07/04/2016 10:37:11
Raymond Anderson07/04/2016 10:29:53
785 forum posts
152 photos
Hi Michael, Just tried the e catalogue, and it does indeed differ from the hard copy. The tips are under Coroturn107 on page A292/293 /145 of the general turning section. Not easy to navigate to. Another reason I prefer hard copies.
Andrew Johnston07/04/2016 10:32:20
7061 forum posts
719 photos
Posted by Nick_G on 07/04/2016 09:48:56:
My expectation is that they will work fine on brass, but less so on aluminium, the two possible issues being BUE and chip breaking.
