Specifying/making a rack
Ian Parkin27/02/2016 13:43:01
1174 forum posts
303 photos
How do I specify this rack
its off a large Fobco drill press and i'd like it to be double the length
Its 3/4 " wide and 1/2" deep
is this likely to be off the shelf anywhere?
is anyone on here able to make me a length
even 12 inches or so i can join it then to existing
I have a vertical mill is there a end mill made to cut those teeth profiles?
Andrew Johnston27/02/2016 14:05:55
7061 forum posts
719 photos
You need to know the pressure angle and diametric pitch. Given that a rack has straight sided teeth, at the pressure angle, the PA is easy to measure. It is likely to be 14.5º or 20º. Assuming that the rack engages with a gear with integer diametric pitch the pitch of the rack will be irrational since pi is a factor going from diameter to circumference.
There may well be an appropriate rack available off the shelf. I doubt you'll find an endmill to create the rack directly. However, given that the teeth are straightsided, and if you're not worried about a radius at the bottom of the teeth, then you can cut the rack using an ordianry endmill or slot drill in three passes. One pass is full depth with the head vertical and the other two with the head set over at the pressure angle for each side.
Alternatively use a shaper or slotter with a ground HSS form tool.
The biggest issue will be keeping track of the irrational pitch of the teeth.
Brian Wood27/02/2016 14:10:35
2742 forum posts
39 photos
Hello Ian,
Better measurement will confirm it but at first sight it looks very close to 12 DP.
That has a theoretical tooth pitch of Pi divided by 12 which is 0.2618 inches [6.65 mm] Check it out accurately over say 10 pitch widths to be sure The matching gear dimensions will help also in confirmation; diameter in inches is T + 2 divided by DP, where T is the tooth count.
I imagine , if this is an old machine, the pressure angle will be 14.5 degrees---modern gears and racks are made to 20 degrees
I'm sure there will be suppliers if you Google for information, HPC gears in Chesterfield come to mind as a possible source www.hpc.co.uk
Edited By Brian Wood on 27/02/2016 14:13:39
Ian Parkin27/02/2016 15:42:39
1174 forum posts
303 photos
Thanks to Andrew and Brian
I'll try hpc on monday or have a go at making my own
Given that its purpose is to raise and lower the table on a drill press will a 20 pa work over a 14.5 pa
Ian
Brian Wood27/02/2016 16:15:52
2742 forum posts
39 photos
Hello Ian,
Indeed it will, that thought had just come to me over a cup of tea. The meshing will not be that critical and in any case it will be intermittent in nature and I imagine you lock the table to the column having moved it, in which case those little niceties don't matter at all,
Good luck with the search or better still the making it yourself
ega27/02/2016 16:38:00
2805 forum posts
219 photos
Ian Parkin:
If you do go in for a PA "mixed marriage" it might pay you to make the rack from something softer than the meshing gear - aluminium, say.
You could cut the long rack you want in your vertical mill using a shop-made D bit type cutter. Alternatively, you might be able to use the B&S type with the cutter on an arbor between centres on the lathe and the workpiece on the cross slide, re-indexing the work as necessary; Martin Cleeve made his racks this way.
Edited By ega on 27/02/2016 16:49:10
Edited By ega on 27/02/2016 16:50:01
Tim Stevens27/02/2016 16:45:50
1779 forum posts
If you really wanted a last resort bodge, cut your best version in light alloy, and 'rectify' the tooth shapes by pressing the steel rack into it in a bench vice.
But don't tell my grandad I said this ...
Cheers, Tim
John Reese27/02/2016 16:54:36
1071 forum posts
Remember that the table adjusting rack acts as a column. Doubling its length could put you at risk of buckling failure. Use of aluminum with an elastic modulus about 1/3 that of steel increases the likelihood of buckling.
ega27/02/2016 17:15:44
2805 forum posts
219 photos
John Reese:
Good point about the danger of buckling. I'm not familiar with the construction of the Fobco: if the rack is not supported at intervals (not clear from OP photos) the danger would be greater but if he is using two or more lengths they would presumably have to be fastened to the adjoining structure - column or whatever - which would reduce the danger.
Sam Longley 127/02/2016 18:10:36
965 forum posts
34 photos
Just checked my Sealey bench pillar drill. This has a rack for the table which is about 15 inches long although the rack part is 9 inches & same tooth pitch as yours. Other dims the same.
It is a loose fitting that is held in a ring at the base & another at the top. It rotates around the pillar as the table is moved from side to side
This would lead me to suggest that you look at a Sealey floor standing model rather than a bench one & you may be able to buy a long rack as a spare part. You may even find that Clarke do a similar thing
Simon Williams 327/02/2016 21:02:22
728 forum posts
90 photos
Sam's post raises another alarm bell. If the rack skates round the column as you move the table in the horizontal plane, then this creates a significant lateral bending moment on the rack. The friction of the lower end acts in one direction, and the force to move it is applied higher up, so the material from which therack is made has to resist the resultant bending force. I'd worry about an aluminium construction folding and dropping the table. The same is true but to a much lesser extent of extending the rack in steel.
Hopefully the rack is supported by the column, in which case the lateral bending moment isn't ann issue. But that presumably means that the table can't swivel on the column
Can we have some pic's of the OP machine please?
Rgds Simon
Edited By Simon Williams 3 on 27/02/2016 21:03:28
Neil Wyatt27/02/2016 21:06:58
19226 forum posts
749 photos
86 articles
Posted by Simon Williams 3 on 27/02/2016 21:02:22:
Or take the same approach as on my mill - extra counterbored screws at intervals along the rack. they don't need to be large - M3 should be fine and leave plenty of intact tooth either side.
Ian S C28/02/2016 09:18:28
7468 forum posts
230 photos
Ian, is your rack screwed to the column or held in a ring top and bottom? If the former, and you want to go longer, think of counter boring another hoe about half way for another screw.
Few years back a friend put a cylinder head on his Chinese floor standing drill press, unclamped the table and the rack collapsed, replaced at the great cost of NZ $3.50, it's great what you can make out of used chewing gum.
Ian S C
Ian Parkin29/02/2016 14:19:07
1174 forum posts
303 photos
The rack is carried at its bottom end on a large bearing that rotates around a locking collar
the rack then fits snuggly against the column untill it goes into the table casting collar its a good fit into this over about 4 inches
The rack i want to be about 18inches long I had apiece of stock the right size
Set it up in the mill but bottled out after the first cut with a 2mm end mill cutting in steps down to 6mm depth
This is going to take me ages to do !!! and cost a bit in broken cutters
Rang a local co to see if they could do it but they quoted of the top of his head £200 ish
I ordered a sealey rack off one of their floor standing pillar drills for £35 delivered
it may be easier to modify that !!!
