Oil Rings for Norman T300 Wanted
Dan Graham14/02/2016 21:26:34
3 forum posts
Hi
My father in law is refurbishing a Norman T300 and needs 4 oil rings. He would be overjoyed if anyone could help him with this
Thanks
Dan
Phil Whitley15/02/2016 18:51:02
1533 forum posts
147 photos
Hi, do you mean oil seals or O rings, if you post some pics up, I am sure someone can help you. Also state where you are in the country, because there are many suppliers who have kept old stock and parts for many years, one such being Oliver Lodge and Co in Hull who had stock of an old leather oil seals for a 1950's compressor I rebuilt, but no use to you if you are in Plymouth!
Phil
Chris Evans 615/02/2016 20:23:44
2156 forum posts
Most bearing suppliers will stock both oil seals and "O" rings. I have size charts for "O" rings both the old BS series of numbers and the metric ones. Also info all on the net.
JasonB15/02/2016 20:41:19
I think the OP means oil rings as in piston rings to scrape the oil off the bore
Robert Dodds15/02/2016 21:29:07
324 forum posts
63 photos
If it is piston rings then you might do worse than talk to Thorntons
http://www.fwthornton.co.uk/
Bob D
p.s. Jason,
I thought they were meant to put a controlled amount of oil onto the bore rather than scrape it off
martin perman15/02/2016 21:31:25
2095 forum posts
75 photos
Google Cox and Turner, when you ring them they will require dimensions etc so that they can make them.
Martin P
Dan Graham17/02/2016 20:18:50
3 forum posts
Dear All
Many thanks for all your replies. I will get in touch with Thortons and Cox and Turner. BTW he is after oil rings not seals and I have the exact dimensions
best
Dan
