Deltic007 | 24/01/2016 17:00:50 |
![]() 131 forum posts 12 photos | Hi anyone ever joined a SILICONE O ring what did you use?
Cheers |
Boiler Bri | 24/01/2016 18:51:54 |
![]() 856 forum posts 212 photos |
It can not be done. Try here - Eap international near Heywood in Lancashire. They keep many sizes. No connection. Brian Edited By Boiler Bri on 24/01/2016 18:52:27 |
Tractor man | 24/01/2016 19:16:17 |
426 forum posts 1 photos | There are kits for making standard rubber o rings using a rubber impregnated super glue but I don't think they're silicon . |
Neil Wyatt | 26/01/2016 16:44:01 |
![]() 19226 forum posts 749 photos 86 articles | I sent an enquiry to Dow Corning, this was their response: Dear Mr. Wyatt, Thank you for contacting Dow Corning. The only silicone adhesive that could develop adhesion to silicone rubber is our DOW CORNING® 732 MULTI-PURPOSE SEALANT. More information ontis product in the data sheets (below and attached): You can contacrt our channel partner for further support: Univar Specialty Consumables (UK) Tame Park, Vanguard Wilnecote, Tamworth Staffs. B77 5DY Curiously enough, I used to live very close to there! |
Ian P | 26/01/2016 17:35:42 |
![]() 2747 forum posts 123 photos | Posted by Deltic007 on 24/01/2016 17:00:50:
Cheers Are you wanting to make a custom size or trying to repair an existing ring? Silicone rubber can be joined and bonded to, but I have a feeling the 'adhesives' might be expensive or have limited shelf life and be uneconomic for one-off purposes. Ian P
david homer | 26/01/2016 17:54:15 |
43 forum posts | Loctite 603 which is a superglue, but you have to use theier primer 770 Used to use it a lot when I was working to join 12mm silicone o ring cord to seal doors on a vacuum lock.
David |
pgk pgk | 26/01/2016 18:11:00 |
2661 forum posts 294 photos | 3M make adhesives for medical silicone products with a special primer - again probably more expensive than buying a made special |
david homer | 26/01/2016 19:07:11 |
43 forum posts | If you look at this link, load the product catalogue pdf, then go to page 33 you will see over on the left what type of material, under that is silicone. David |
david homer | 26/01/2016 19:22:02 |
43 forum posts | Sorry in an earlier post I put Loctite 603, that should have been 406, sorry for the error. The adhesive is cheap enough but the primer is a bit more expensive, I do have some primer, where abouts are you. David |
