Nick_G | 16/01/2016 13:04:52 |
![]() 1808 forum posts 744 photos | . I have to make the following part. I have done so without issue and made a little threaded mandrill to hold it. But I now have to (as per the drawing) drill 8 1/16th holes in the rascal around the outside of it's flange. I have a rotary table that I bought a few months ago and have fitted a spare chuck to it. At the same time I bought the rotary table I also ordered a set of indexing plates. So all should be good and what's his problem I hear you cry. The problem is I have no idea how to use the plates, which plate and number of holes and the maths involved. I do realise that the angle between each hole is 45 degs and I could simply use the graduations on the table. Especially in this case as it's non-critical. But I would like to know how to use the kit. Cheers, Nick Edited By Nick_G on 16/01/2016 13:07:54 |
Michael Gilligan | 16/01/2016 13:40:13 |
![]() 23121 forum posts 1360 photos | Nick, Although it relates to the little Sherline Rotary Table .... This is worth reading for background. ... Follwed by this [which is also not your RT] MichaelG.
Edited By Michael Gilligan on 16/01/2016 13:45:56 |
Robbo | 16/01/2016 13:45:43 |
1504 forum posts 142 photos | Not the same table, as yours looks like a 6", but might help - **LINK** |
Lambton | 16/01/2016 13:53:14 |
![]() 694 forum posts 2 photos | Nick, This is a very simple indexing job not really requiring the use of division plates. Just note the first hole position ( zero if you can arrange it) and then turn the table handle through 45 degrees for each successive hole, remembering the lock the table each time before drilling. Eric |
Michael Gilligan | 16/01/2016 13:57:56 |
![]() 23121 forum posts 1360 photos | Posted by Nick_G on 16/01/2016 13:04:52:
I do realise that the angle between each hole is 45 degs and I could simply use the graduations on the table. Especially in this case as it's non-critical. But I would like to know how to use the kit. Cheers, Nick . Eric, What you say is true ... But Nick did explain his motives ^^^ MichaelG. |
Vincent Cutajar | 16/01/2016 14:18:28 |
23 forum posts |
And this is the user manual which might help you. http://cdn0.grizzly.com/manuals/h7527_m.pdf Vince
Edited By Vincent Cutajar on 16/01/2016 14:26:09 |
Nick_G | 16/01/2016 14:30:29 |
![]() 1808 forum posts 744 photos | . Thanks guy's
Nick |
Harry Wilkes | 16/01/2016 15:24:38 |
![]() 1613 forum posts 72 photos | Thanks Vince H
Harold Hall 1 | 16/01/2016 16:29:31 |
418 forum posts 4 photos | If I may be allowed, once more, to publicise one of my books, you may find my book "Dividing" of help Nick. This covers amongst other things, the mathematics of using a dividing head/rotary table but also lists all the available divisions using the hole numbers in common division plates, and for wormwheel ratio's of 40:1 60:1 and 90:1 . For more details regarding the book, see http://www.myhobbystore.co.uk/search.asp?k=harold+Hall&x=23&y=2 here. It also includes simple methods of achieving low number divisions and more complex methods for higher numbers. Ady, if you remember, last time I mentioned my books, or was it a page on my website, you prompted me to add a link on it back to this forum, I have not forgotten. However, with there being at least 15 forums that I visit, and wanting to make a good job of the task it I am finding it difficult to find the time. I do though still intend to do it. Harold Edited By John Stevenson on 16/01/2016 16:32:11 |
Harold Hall 1 | 16/01/2016 18:18:11 |
418 forum posts 4 photos | John I accept your edit and feel a link to my website for details of the book plus a link to My Hobby Store for purchasing it would have been the correct way to go. However, in this case, to my surprise, and no doubt yours John, My Hobby Store do not list the book, actually only listing 2 of my books. If you are interested in the book Nick you will find it widely available on the Internet. Harold |
Howard Lewis | 22/01/2016 17:30:28 |
7227 forum posts 21 photos | Nick, Your Rotary Table looks like my Vertex HV6. The Handbook that comes with it contains a parts list, and brief instructions on how to use it for dividing, and a table, (Inside the back cover), giving the Plates to use and the number of turns and holes, for each set of divisions, upto 99. But not all division numbers are available (such as 28,51,52,53,59,61,64,67,68,71,73,76,77, 79,83,84,85,88,89,91,92,and 97) Mine has a 90:1 worm/wheel ratio, so for 8 equally spaced holes the table gives ' A' plate, 20 hole circle, (The outermost one in this case) 11 turns and 2 holes of the crank handle, between each drilled hole. If you have not got the "Operation and Service Manual" for the table, send me a PM, and I'll see what I can do to help. Are you UK based, if so, whereabouts? A recent tip was to make up two pegs to be a good fit in the holes, and short enough to be clear of the peg in the handle, as it rotates, to fit BEHIND the fingers, so that if you catch the fingers while turning the handle, they do not move to lose your starting position. As you need to move the fingers round, the pegs are moved to retain their position. (Obviously, make sure that the screw clamping the two fingers together is tight) I've just done this, and it is useful. Howard
mick | 23/01/2016 15:42:42 |
421 forum posts 49 photos | I had an interesting dividing head indexing problem the other day, I had to initially index 12 degrees from zero, then 16 degrees ,then 24 and repeat it nine times. I made a nine hole plate, which means every hole is one degree. I've used it several times since, its extremely useful for indexing any multiple number of whole degrees, can't imagine why I didn't make one years ago. |
Nick_G | 23/01/2016 16:40:40 |
![]() 1808 forum posts 744 photos | . Thanks for the information.
Nick |
Roger Quaintance | 27/01/2016 16:19:40 |
29 forum posts | Posted by mick on 23/01/2016 15:42:42:
I had an interesting dividing head indexing problem the other day, I had to initially index 12 degrees from zero, then 16 degrees ,then 24 and repeat it nine times. I made a nine hole plate, which means every hole is one degree. I've used it several times since, its extremely useful for indexing any multiple number of whole degrees, can't imagine why I didn't make one years ago Just bear in mind not all rotary tables and dividing heads have a 40-1 worm, some are 60-1
norman valentine | 27/01/2016 16:27:26 |
280 forum posts 40 photos | Dave Gingery has a very clear explanation of how to work it out in book number 6 of his series " Build Your Own Metal Working Shop From Scrap" "The Dividing Head & Deluxe Accessories".
mick | 27/01/2016 17:04:07 |
421 forum posts 49 photos | I've never come across a dividing head that isn't 40:1 What make is a 60:1 Certainly smaller rotary tables can differ, while the larger commercial ones, in my experience, are 40:1 |
norman valentine | 27/01/2016 19:08:11 |
280 forum posts 40 photos | Mine is 30:1, but then I did make it myself.
Andrew Johnston | 27/01/2016 20:04:28 |
![]() 7061 forum posts 719 photos | Just to be different my large (12" Andrew |
Enough! | 27/01/2016 21:40:08 |
1719 forum posts 1 photos | Posted by mick on 27/01/2016 17:04:07:
I've never come across a dividing head that isn't 40:1 What make is a 60:1 Myford |
Nick_G | 27/01/2016 22:45:04 |
![]() 1808 forum posts 744 photos | Posted by mick on 27/01/2016 17:04:07:
I've never come across a dividing head that isn't 40:1 What make is a 60:1 Certainly smaller rotary tables can differ, while the larger commercial ones, in my experience, are 40:1 . Here are a couple. **LINK** The HV6 being the one I have.
Nick |
