Member postings for Roger Quaintance
Here is a list of all the postings Roger Quaintance has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello from South West england
01/04/2022 19:40:49
welcome aboard, where be you to?
Thread: Damp shed: what’s the best way to add ventilation?
19/03/2022 15:53:24
Nature abhors a vacuum, if the air outside is damp it will be damp inside unless you have dry heating, and by that I mean not propane which only makes the damp problem worse. Dehumidifiers will collect the moisture from the air making space for the next lot to come in, in short without heating you are on a good hiding to nothing and forever fighting rust.
Thread: Anybody else remember Chuck the Muddle engineer?
13/03/2022 13:42:48
Whilst Terry Aspin will always be remembered for his books on foundrywork (both of them timeless classics) (Oops just found another one so three foundry books) and chuck the muddle engineer cartoons, most do not realise he was a prolific cartoonist drawing for many "Comics" of the day, it is a pity he never published Chuck the muddle engineer as a book of his own. Though Chuck did write building a locomotive from scratch, his third book.
Edited By Roger Quaintance on 13/03/2022 13:48:41
Thread: oh my goodness
04/03/2022 14:38:14
Posted by martin perman on 04/03/2022 07:40:54:
Grizzly, good to know there are other cack handed types out there smiley, I've started watching the video and am envying his abilities.
Martin P
I am a lefty as well ha ha, we seem to have A Rash of them. Watching people make something out of nothing puts us all to shame and makes us realise where the innovators are to be found, The end result is as accurate as possible within the restrictions of the lathe. The saddle components appeared to be bouncing around a bit
03/03/2022 12:45:50
They say necessity is the mother of invention, this chap shows what can be done with basic tools and a will to get there. Accuracy not in the realms we expect but it gets the job done it seems. One has to respect the ingenuity involved.
03/03/2022 12:14:55
no milling machine no problem.
https://www.youtube.com/watch?v=ZwOHX3pAYyg
Thread: Model Engineers Handbook
02/03/2022 10:42:22
Posted by Oldiron on 10/03/2021 20:48:09:
Posted by Peter Ellis 5 on 10/03/2021 16:46:01:
Posted by Bo'sun on 10/03/2021 15:25:51:
So who is Lyle Peterson (Tubal Cain)?
He is an American retired metalworking teacher. I think his later videos dropped the Tubal Cain name after complaints. Whilst the name is Biblical, Tom Walshaw used it for 50 years and although it was disrespectful of Tom, I don´t think he was aware of him.
mrpete still uses the monica Tubalcain ( no space between ) It is in every title of his video's.
regards
I feel like complaining every time I see it, ha ha
Thread: Gear hobbing
28/02/2022 18:14:29
Posted by bernard towers on 28/02/2022 15:52:19:
Roger, It’ll be interesting to see that it could spark a bit of interest as very little out there except cues and small mikron machines like mine ,best of luck..
I am sure there not only is a lot of interest but a lot of people who have experimented one way or another. The forces involved only limit the size of the gear or the profile I suppose though most people will need either 20dp or 16dp only the odd person will use 14dp for older machines. Mmm not meaning the person who uses 14dp is odd, ha ha. My problem will always be a non mathematical mind. Plus my workshop is such a mess photos will not be easy and I seldom work to a drawing these days its all in my head and developed as I go so one problem will follow another, ha ha. I will take a series of photos as I go and to hell with the mess and if it fails then maybe others can suggest how to rescue the project. Though basically I will not be spending a great deal of money on it, thats for sure.
As a make do and mend engineer my approach is a function rather than a pretty thing so I will not spend time on unimportant finishes. Whilst I am purportedly retired I do run a a campsite so my time is limited, most years to the winter months, going out now I could be some time, ha ha.
PS why is there not a facility to "like" a post as I hate to ignore other peoples input.
28/02/2022 15:46:22
I am sure many of you have tried gear hobbing one way or another, having seen the Jacobs (CES) machine and fighting old age crap memory etc I am going ahead to build one to fit on the lathe. What do I have, I have a number of inch and a quarter bore commercial hobs (including 16dp 14.5pa as used by both of my lathes). I have a couple of lathe top slides, a Boxford dividing head to fit the topslide (when mounted as a vertical slide) A large piece of angle plate, assorted 16dp gears from many different lathes. I have ordered a couple of UJ's around £11 the pair could not make them for that if I had the time. Lots of bits to make, an arbor to hold the hob and a drive gear to drive the blank, a suitable banjo to hold the required gearing, numerous connecting structures and a chance to make a vertical slide for the lathe. (the angle plate will swivel and also hold a tiny rotary table I made many moons ago, or one of the topslides. So lots of bits to make or cobble together. One day I will actually make something other than a machine to make something, ha ha
Thread: 1.5 in x 8TPI nose thread (BSF)
28/02/2022 11:40:25
cheers, it is on a dividing head (myford style) but for my use will probably use the 2 morse taper to hold an arbor
27/02/2022 20:39:35
thank you, yep I checked the angle so not unified
so next question anyone have a spare backplate gathering rust?
27/02/2022 19:34:56
anyone know what lathe that might be? am looking for a a chuck or maybe backplate or cast blank
Thread: Can you recommend a cure for fingerprints on plastic?
26/02/2022 19:22:43
amputate at the wrists? I'll get me coat. Ha ha
Thread: MEW Index updated to Issue 313 (March 2022)
26/02/2022 10:38:14
I have needed an index for ages, many thanks it must have taken ages
Thread: Backyard Foundry - oil burning furnace - moulding and casting a spider
25/02/2022 18:10:23
Posted by Luker on 25/02/2022 14:27:57:
Thanks Graham. Brass isn't one of my favourite metals to cast and I only need it for the ornamental fittings for my builds (which were quite numerous for the old loco's). I sometime battle with scrap here which is why I’ve had to develop certain replacement alloys and methods of refining fines etc. When I built the American loco I had very little bearing bronzes and ended up making most of the components from cast iron including the eccentrics and straps. It actually worked quite well in the end.
a thought comes to me, why not try mixing your own bronze, copper brass and some zinc, or maybe some Aluminium for ali-bronze it would solve the problem would it not, worth a try.
25/02/2022 17:55:37
Posted by David Caunt on 24/02/2022 22:13:27:
Roger divide by 6 then 48/6= 8 and 30/6=5
got it thanks
25/02/2022 17:53:16
Posted by Chris Crew on 24/02/2022 21:16:38:
If it may serve to provoke some ideas, could I suggest that you take a look at the Radford worm-wheel hobbing attachment for the Myford lathe. As its name suggests this device as built will not hob anything but worm-wheels but maybe coupled up with a rising and falling slide to carry the gear blank it may provide a suitable drive.
Edited By Chris Crew on 24/02/2022 21:17:08
I'll certainly have a look at that. In the mean time design changes already before I start building, instead of 40:1 worm drive I will make it possible to change the driven gear so it could be any ratio I have a gear for, that will give me a lot more scope. The mandrel (see spelt correctly, ha ha) will be made to take both one inch hobs and inch and a quarter. I have several of both and don't think it worth making two mandrels. Everything still in my head at present but will start sketching to find what I need to make
Thread: Smallpiece Cromwell Mk2 lathe
25/02/2022 17:45:29
Close Phil, I took time out to look at again today, and noticed the gear at the handle and shaft spins however the gear that transfers motion to another gear driving the leadscrew does not move, oops have to move it out from the wall to get at it, it has been like that since I bought it and was told then the lathe had not been used for 40 year, ha ha So am pretty confident that is the answer, Just have to mount the motor now and could have the basis of my gear hobber
It has only taken me 3 years to make a start on the machine, it kind of got buried as I have a Colchester for my main turning.
24/02/2022 21:26:40
Posted by bernard towers on 24/02/2022 16:24:02:
No definitely not but if it helps over the years I’ve had my hobber I have slowly worked out a change wheel chart based on available change wheels (converted the machine to 20dp Myford type which were cheap as chips then. As you say your fixed ratio is 40 to 1, mine is 16 to 1 so to cut a 10 tooth gear it’s 10 div 16 = 0.625 which I achieve by using a 48 and 30 tooth wheel setup. For some tooth counts compound trains are necessary but I shy away from them unless really necessary. Hope this is some help
ok I get that much for me that would be 10 divided by 40 it is the next part that I have problems with how do you get from .625 (5/8) to using a 48 and 30 tooth for that ratio. I tried using the log method in machinerys handbook but the gear numbers that it comes up with seldom include gears in the set 30, 35, 40, 45, etc and has all sorts of odd gears required and whilst that could be done with a stepper motor that is not a route I wish to go down I need to be able to work out compound gear trains. Once I have the basic ratio using gears that I have, even if three trains are needed at times how to break a ratio down into the various compound units.
24/02/2022 18:16:14
Posted by Martin Connelly on 24/02/2022 17:36:29:
Big difference between a mandrill and a mandrel devil
Martin C
oops well am monkeying around
