Advice for inverter drive
Mike Cooper 1 | 01/01/2016 21:35:56 |
5 forum posts 5 photos | Hello. I'm trying to spec the right inverter for my VM30 so I can run it from 230v. Can anyone help me by taking a picture of their motor data plate on their machine for me? I have searched all over my motor and inside the junction box and there is no data plate. I want to know if it's capable of dual voltage and what the power and rated current is. I found one image online of another machine showing a 1.1kW motor which was only rated for 415v and 3 amps. I.e not dual voltage. My motor looks original I was just suprised it had no data plate. Any advice appreciated! Thanks in advance Mike |
Ian Parkin | 01/01/2016 21:58:36 |
![]() 1174 forum posts 303 photos | Post a picture of the inside of your junction box and we can tell if its dual voltage if it has 6 wires its dual i only 3 its 415 only without diving in to find the star point Ian Edited By Ian Parkin on 01/01/2016 22:00:37 |
Mike Cooper 1 | 01/01/2016 22:27:13 |
5 forum posts 5 photos | Hello Ian. I don't know how to include a link in this text but I've put 5 photos in my first album. Hope you can see the motor one. Thanks Mike |
Andy Holdaway | 01/01/2016 22:33:05 |
![]() 167 forum posts 15 photos | Mike, The star point is on the bottom three terminals, so you can rewire it in delta and run it from a 240v single to 3 phase inverter. I have no idea what size it is, but I'm sure someone will be along soon with an answer! Andy |
JasonB | 02/01/2016 07:31:30 |
![]() 25215 forum posts 3105 photos 1 articles | Have a search for Nick-G's post about fitting a inverter to his VM-30 |
daveb | 02/01/2016 08:27:30 |
631 forum posts 14 photos | Have a look at the square recess in the middle of the motor end cap, the data plate lives there, they are normally painted over so somewhat difficult to see. |
Martin Connelly | 02/01/2016 09:59:19 |
![]() 2549 forum posts 235 photos | Get a vfd that is big enough to suit this motor and a larger motor as well. A 2kw vfd will drive anything smaller as well and you may want a larger motor in the future or to drive a different machine with the vfd. Martin |
Ian Parkin | 02/01/2016 10:47:19 |
![]() 1174 forum posts 303 photos | Mike Photos.... when you are writing a post click on the camera icon above the text entry box and select a photo from your album Hope i'm not teaching sucking eggs but to change to delta remove all screws ( 6) from the connections and move the links ( 3) to go up and down one link on each wire pair rather than across as in your photo replace all screws and input wires as you were and you now have a delta connected motor suitable for 240v use As to size of inverter unless you have access to a 415 v supply to measure current or a friend with a say 2kw inverter who would let you connect your motor to to measure current...all inverters will display current whilst running. I would say looking at your motor that its unlikely to be bigger than 1.5kw so buy a secondhand inverter as a start and connect and see what current it draws and set max curent to 20% higher. If you are anywhere near sheffield I can do this for you and make a switch control box whilst you wait
Ian
Nick_G | 02/01/2016 11:39:32 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 02/01/2016 07:31:30:
Have a search for Nick-G's post about fitting a inverter to his VM-30 . I don't think I made a specific post about the inverter fitting but it was mentioned a little bit in a video I made I recall. I also had the issue of a non dual voltage motor. The star termination points were buried deep inside the windings and not easily reached. I ended up purchasing a new dual voltage motor to fit to mine. I also fitted a larger VFD than required for the reasons mentioned above. I still have the original motor. Later I will take a photo of it's plate, the replacement motor and inverter and post them here for you.
Nick |
KWIL | 02/01/2016 12:18:09 |
3681 forum posts 70 photos | I used a 1.1KW Yasgawa inverter on mine, you could getaway with 0.75KW as it is a 1HP motor. I have used other brand inverters on my other machines so I am not "Brand" loyal. No problems and straight forward installation. |
Nick_G | 02/01/2016 15:13:13 |
![]() 1808 forum posts 744 photos | . Here are the images I said I would post. It seems though that the motorplate of the original is no longer readable. But here it is anyway:- But here is an image of the motor I replaced it with. This was a simple task and the pulley went straight on without modification or hassle. And this is the VFD I used obtained from Newton Tesla of Warrington. I also in my previous post mentioned a video. It does not give much detail other than me having the same problem as yourself. I also had to motor to pieces thinking the required winding ends would be available. But alas no they were not. Still worth checking yours though as a motor from a different batch or source may be different. But here is the video anyway. The bit about the motor starts at about 8:10 in. Edited By Nick_G on 02/01/2016 15:23:45 |
