How to choose a Chuck JT taper
13Sigs17/11/2015 12:01:09
23 forum posts
This is a follow up to a previous topic I have submitted.
I am about to buy a keyed 2mm -13mm chuck and mounting Arbor for the 2MT fitting on the tail stock on my small lathe a Proxxon PD400. The intended new chuck has a Jacobs Taper (JT) mount and the chuck is available in 6JT and 2JT. At the point of placing the order for chuck and arbor I had to state if the chuck was to be a 6JT or 2JT mount in order to supply the appropriate 2MT Arbor. In my limited experience I have no idea why or how a 6JT or 2JT Chuck Mount is what I need. I will be grateful if someone can take the time and trouble to point me in the right direction.
I have looked on the internet and got nowhere. I made enquiries at 3 quality outlets for engineering supplies and tooling, and was told the following;
1. The various sizes of JT mounts is to enable a buyer to use an existing arbor.
2. 6JT mount chucks have a boss and therefore stronger.
3. Some JT mount sizes allow the chuck to be interchanged with other specialist equipment.
Michael Gilligan17/11/2015 12:34:18
23121 forum posts
1360 photos
It's worth looking at the dimensions **LINK** , to inform your decision.
JT6 is pretty bulky for a modest size chuck.
Frances IoM17/11/2015 13:16:33
1395 forum posts
30 photos
does it have to be a JT - been very happy with the B16 2MT taper chucks from ArcEuro can fit both a 1.5mm to 13mm as also a 3-16mm chuck (convenient for larger drills - same chuck also fits a rolling tailstock adapter
Ian S C18/11/2015 08:13:40
7468 forum posts
230 photos
My Jacobs #34 chucks, 1/2", have a JT 6 taper, two of them with 2 MT, and the other with a 1/2" parallel, it fits in my wall drill that was designed to tale Blacksmith drills. I think one 16 mm chuck is also 6JT/2MT, and the other is 6JT/3MT.
Ian S C
