Rainbows | 08/11/2015 14:18:00 |
658 forum posts 236 photos | I have a 3 jaw chuck by burnerd with an internal thread. Stamped "made speacially for Myford ML7" on the front. Problem is I can see there is swarf down in the scoll and with the jaws in it gums up about half way to fully closed. Model 30M However I can see no seams or gaps where the body dussaembles. There are 3 screws in the back but when I took them out I couldn't notice anything becoming loose.
Anyone know of a manual for these chucks? Edited By Rainbows on 08/11/2015 14:23:43 |
NJH | 08/11/2015 15:09:23 |
![]() 2314 forum posts 139 photos | If you can, try opening the jaws fully and removing them. Get a thin punch/ screwdriver etc and rotate the scroll whilst "digging" with your chosen implement! With luck you will be able to "wind" the crud to the outside of the scroll and remove it. It may be best to remove the chuck from the lathe and lay it on its back on the bench. Good luck - it worked for me! Norman PS A good squirt of WD 40 to start will not go amiss. Edited By NJH on 08/11/2015 15:12:22 |
KWIL | 08/11/2015 15:56:50 |
3681 forum posts 70 photos | It will separate but the parts are a very close fit. |
Rex Hanman | 08/11/2015 21:09:59 |
121 forum posts 3 photos | Posted by KWIL on 08/11/2015 15:56:50:
"It will separate but the parts are a very close fit."
Quite so, but if you do take it apart you will be amazed at how much cr*p has found its way inside! It's worth giving them a good clean out once in a while. Make a couple of small centre punch marks on each side of the joint line so that it goes back together the same way round, other than that there's nothing to fear about stripping it down.
See here for a description... https://misterlinnsworkshop.wordpress.com/2014/12/31/our-own-words-used-against-us/ A Myford direct mount chuck may have detail differences but the method is much the same.
Edited By Rex Hanman on 08/11/2015 21:12:12 Added link Edited By Rex Hanman on 08/11/2015 21:34:52 |
Ajohnw | 08/11/2015 23:32:58 |
3631 forum posts 160 photos | Posted by KWIL on 08/11/2015 15:56:50:
It will separate but the parts are a very close fit. So close that they may not come apart going on some of my chucks. What I usually do is remove the jaws and flick the bits out with a brush and rotate the scroll and flick some more etc. It's usually possible to get all of the bits out that way with the chuck on it's edge. That white stuff removed in the link is probably lithium grease. If it has been there from new it's probably best left in place or replaced. I've not needed to dismantle my grip trues but going on the link it looks to be relatively easy. John - |
Rainbows | 09/11/2015 00:00:57 |
658 forum posts 236 photos | I squinted with all my might and couldn't see or feel a film down the sides. I have a feeling the middle comes out the back to reveal it but I ended up cleaning the scroll from the outside. Jaws don't bind any more so mission accomplished for now. |
John McNamara | 09/11/2015 05:41:57 |
![]() 1377 forum posts 133 photos | Hi I remove the jaws and spray the scroll while rotating it through the slots with CRC, RP7 or whatever brand of penetrating oil I have to hand. Then while continuing to rotate the scroll I use a wet and dry shop vac with a flat nozzle that fits in the jaw slots to suck out the oil and muck that it has loosened, I usually repeat the process a couple of times. the process works well. the scroll will be clean. Penetrating Oil is not a good lubricant, (Lightly) oil the Scroll before reassembly with a light oil. not too much or it will attract swarf. Before reinserting the jaws check the scroll for any swarf that has semi welded itself to the scroll. (And the jaws too) Oh if you do disassemble a chuck if it is in good condition the scroll is an extremely good fit in the body. It must be removed without tilting or it will get stuck. If it does you will need to tap it with a brass drift through the slots to release it. You may damage the fit in the process if you raise any burrs. Take great care. Regards |
Douglas Johnston | 09/11/2015 10:04:48 |
![]() 814 forum posts 36 photos | When I swap the jaws in my 3 jaw chuck I flatten the end of a cotton bud and hold it in the spiral scroll while turning the chuck key. This removes swarf from the whole length of the scroll. I then use a tooth brush to clean each jaw in turn. I don't know what I would do without cotton buds and toothbrushes, but I have found some of the cheap cotton buds can be a bit flimsy so buy a decent brand. I also use chain saw oil on the jaws before refitting. Doug Edited By Douglas Johnston on 09/11/2015 10:05:56 |
