Materials
Angle iron
Roger Hulett10/09/2015 12:30:55
131 forum posts
9 photos
I need some small dimensioned (17mmx 17mm) thin (1mm - 2mm) angle iron. I can get Stainless,Galvanised ,Wood and Plastic. Why can't I get mild steel ???
JasonB10/09/2015 12:36:14
Not enough demand
How much do you need? I have milled it down from 3mm stuff in the past. The other option if you can live with a radius on the external edge is to take some thin wall 25x25 square box section tube and run a slitting saw down that.
Michael Topping10/09/2015 12:46:10
74 forum posts
5 photos
Agree with Jason, if there is little commercial demand it won't be available. 20 x 20 x 3 is the smallest angle iron I could find. You can get 16 x 16 x 3 bright drawn from most suppliers but I find it is never at a right angle and needs skimming in the mill to true it up.
Michael
Roger Hulett10/09/2015 12:57:35
131 forum posts
9 photos
How does galvanised start out ?
John Rudd10/09/2015 13:06:43
1479 forum posts
Cant you form your own from 1 mm flat steel strip and bend it?
Cant you use the galvanised offering?
Roger Hulett10/09/2015 13:18:04
131 forum posts
9 photos
I will probably use the galvanised. It is to be used to edge the running boards of a vintage motor cycle, so after forming,cutting and shaping to fit it will be painted and hopefully indistinguishable from the original. It would appear that in 1920 the size was a stock size. I was just curious why there is a demand for those dimensions in other materials but not in mild steel,which is a cheaper alternative. Protection for edges etc.
Ady110/09/2015 13:45:38
6137 forum posts
893 photos
B+Q usually have a few types, for fence posts etc
About 6 quid a meter depending on size
mick7010/09/2015 13:53:14
524 forum posts
38 photos
got 2m of 17x17 x1.8 sat on shelf here.
got radius on it, came from company that repairs coaches.
where are you?
clogs11/09/2015 18:05:40
630 forum posts
12 photos
Hi Roger, in the same position as u.....1930's Indian.....
Private Message me, perhaps we can swap notes.....
Clogs
Keith Long11/09/2015 18:29:46
883 forum posts
11 photos
Try here you will probably find in that size you get pressed or folded angle rather than hot rolled or bright drawn.
Boiler Bri11/09/2015 18:45:54
856 forum posts
212 photos
Cut some box section up!
Bri
