Gudgeon pin steel
Ian MILLARD12/07/2015 16:45:58
18 forum posts
I am building a simplex loco, the drawing says i need 3% ni case hardening steel for the gudgeon pin in the crosshead, where can i get this from, or can i use bms and case harden this or can i use silver steel.
Thanks IAN
JasonB12/07/2015 16:51:11
Sounds like EN36, M-Machine do a limited range of sizes.
J
Bob Rodgerson12/07/2015 19:42:48
612 forum posts
174 photos
Hi Ian,
EN 36 seems a bit over the top to me. I can't recall what material I used when I built a Simplex many years ago but I would have thought that any mild steel that can be heat treated would be up to the job. Failing that you could use EN24 which has good wear properties.
Bob
Bob Brown 112/07/2015 20:24:35
1022 forum posts
127 photos
On my 2-8-0 Nigel Gresley the drawings states silver steel or case hardened steel for the pin, I'll probably opt for silver steel and harden and temper the pin.
Bob
duncan webster12/07/2015 22:15:14
5307 forum posts
83 photos
you can't make mild steel harder by heat treating it. You can case harden it, but not the leaded stuff. If it has threads on it you'd be better casing before cutting the threads, then hardening (case just increases the carbon content, let it cool very slowly). Other way is to copper plate the thread, then it won't case. If using silver steel, temper it well down, you don't want it snapping. I'd be surprised if mild steel wasn't good enough without hardening. It's very easy to replace if it eventually wears.
Neil Lickfold13/07/2015 20:32:43
1025 forum posts
204 photos
A2 tool steel makes for gudgeon pins, and can be flame air hardened and then tempered.
John Stevenson13/07/2015 22:20:04
5068 forum posts
Posted by duncan webster on 12/07/2015 22:15:14:
Surely case hardening is heat treating ??
julian atkins13/07/2015 23:21:27
1285 forum posts
353 photos
hi ian,
i think the spec for simplex gudgeon pins is overkill, and certainly not what martin evans would have done himself or what most miniature loco builders would do.
ordinary free turning BMS if a good finish is quite ok with bronze small end conn rod bearings. these bearings wear quite badly if lots of heavy use as heavily loaded compared to size, plus usually receive insufficient oil, as difficult to apply.
my own personal practice with the few walschaerts locos ive built is to case harden the gudeon pin after making with a nut on the thread. i use hard drawn phos bronze for the small end bearing (dont use gunmetal). ali bronze is a good alternative for the bearing material. make sure you add an oiling point in the top of the drop link and through the crosshead to the bearing.
cheers,
julian
duncan webster14/07/2015 10:55:52
5307 forum posts
83 photos
Case hardening changes the chemical composition of the surface of the steel, you then harden it by heat treating (ie dropping it in water from red hot). It's all a matter of definition
