Victoria power output
john carruthers01/07/2015 18:43:54
617 forum posts
180 photos
Sorry if this has been asked before but what sort of power output would a Stuart Victoria (single) engine produce and at what pressue?
roy entwistle02/07/2015 11:59:03
1716 forum posts
If I remember 2x pressure x length of stroke x area of piston x rpm / 33000 = horse power
Thats from nearly 70 years ago
Roy
Ian S C02/07/2015 13:46:44
7468 forum posts
230 photos
John, you can work out the indicated HP using the formula P.L.A.N/33,000(see Roy's entry), and when you have built the engine you can measure the brake HP by measuring the torque in(for this size engine) inch oz, and RPM/ 1352 to give the power in Watts, or gram x cm x RPM x .00001026.
I only had to remember back 53 yrs, it's about the only formula I remember from my mechanics class. Still got my copy of "Engineering Science" Vol 1, by Brown & Bryant, mines a 1957 edition, but it dates back to a first ed 1937, and I don't think it was updated, still I don't suppose physics changes.
Ian S C
JasonB02/07/2015 14:00:02
Am I using the right figures as I get quite a high HP using Ians formula, My thoughts last night were about 0.15 to 0.2 actual HP using 100psi and 750rpm.
With the formula using 100psi, 2" travel, 0.78sq in, 750rpm
100x2x0.78x750 /33000
117000 / 33000
3.54HP
Seems there is a decimal one place out
Roy's with the extra 2x would give 7hp
Edited By JasonB on 02/07/2015 14:34:12
roy entwistle02/07/2015 15:16:46
1716 forum posts
The 2x is because its double acting
Roy
JasonB02/07/2015 15:23:06
Thanks Roy, I had a feeling that may be the reason though sitll seems to be a high result?
JasonB02/07/2015 15:36:09
ME Handbook to the rescue
L should be in feet not inches
So 2x100x0.167x0.78x750/33000
19539/33000
0.6HP
Though whether the relatively long stroke of the victoria compared with its bore would suit such high revs is debatable, and pressure could be a bit high so lets say
2x 75psi x0.167x 325/33000 = 0.25HP
Edited By JasonB on 02/07/2015 15:36:56
Nick_G02/07/2015 16:43:36
1808 forum posts
744 photos
Slightly related and perhaps off topic a tad. (depending upon the OP's reason for asking)
What sort of steam engine HP would be required to run this 30 amp alternator.? **LINK**
Nick
john carruthers02/07/2015 16:54:46
617 forum posts
180 photos
Thank you gentlemen, I found PLAN but not the constant and was wondering why the HP value was so high.
The little Flexispeed could run on a nominal 1/4 HP electric motor but I'd like to see it run on steam.
Also I'd like to build an engine that can do useful work so I'm looking around.
JasonB02/07/2015 17:27:10
Nick basic calculation is W = V x A so 420w or .56HP you would need to allow for losses etc.
