Some information regarding a toolpost mounted accessory made for internal broaching.
Ed Duffner | 25/06/2015 01:10:38 |
863 forum posts 104 photos | Hi Everyone, I was asked if I could do a write up of a QCTP accessory I recently made to perform internal broaching. I would like to mention that I am relatively new to machining and mechanical engineering so please read the following in the context of a beginner trying to learn and adapt. I have seen examples on the internet of a design fitted to lathe tailstocks using a lever for drilling operations and it occurred to me that I might be able to adapt an unused boring bar tool holder to do the same. The holder came with a QCTP set, model 250-100 purchased from ARC. The tool-post was adapted to fit the lathe and is not a standard item. So I needed to think of a way to attach a lever to the boring bar holder without drilling any holes into it and have some kind of shaft passing through it with a way to secure a tool bit in the end. A brass sleeve was turned to 20mm OD x 93mm long to pass through the main body of the boring bar holder and drilled through, initially 10mm but was not quite concentric for some reason so I had to increase the ID a little using an imperial drill. I have no reamers or a boring bar long enough, so a drilled hole is the best I can achieve for the moment. The sleeve was made long enough so that a combined clamp and integral pivot link could be secured onto it. This clamp link provides the first part of three linkages used to hold a lever and the tool-bit shaft passing through the brass sleeve. The tool-bit shaft was then turned to a very close sliding fit to the sleeve and brought to final dimension by polishing with emery paper. All linkages were milled and drilled on my milling machine. The linkages use standard M6 cap-head screws as pivots and work ok for the time being. The handle shaft is one of the T-slot hold down bolts used on my milling machine. I want to try out some of the different lengths of these bolts before making a final piece from bar stock. Here are some photos of the broaching tool which still requires some clean up and a handle: I have also recently been introduced by forum member Murray "Muzzer" to the Autodesk Fusion 360 CAD/CAM software package (Free home user license!) and have been re-designing this tool whilst learning the package. I've used slightly different and standard dimensions in the CAD version and improved the pivots with Clevis type pivot pins. The software allows output of the CAD models to 2D drawings which I have completed for all the parts. I am more than happy to share these basic drawings and models with any forum members, but (here's a disclaimer) as a beginner there may be some shortcomings in the design/fit. Animation of the parts within Fusion 360 shows that the tool works with no unwanted collision between moving parts. I'm not sure about pivot clearance requirements so all bearing surfaces are planar i.e. no clearance gaps! Here's a picture of the design in Fusion 360:
A couple of chaps on the forum have mentioned the tool could be handy for cutting keyways and I think it could also be used to mark dials and possibly cut bevel gears. Thoughts about other changes: - A longer travel on the tool-shaft to allow room for a depth stop, but this might introduce unwanted deflection. - Change the tool-bit holder to a removable chuck of some type. If anyone would like the drawings or models please let me know. If it's ok with the forum moderators I can post a direct link in this thread to a multi-page PDF document containing all the drawings. I am not linked in any way to the companies mentioned above, except as a customer. Thanks, Edited By Ed Duffner on 25/06/2015 01:28:24 |
Michael Gilligan | 25/06/2015 06:27:21 |
![]() 23121 forum posts 1360 photos | Ed, That demonstrates rapid, and very effective, progress ... Well done, Sir !! MichaelG. |
OuBallie | 25/06/2015 06:39:13 |
![]() 1181 forum posts 669 photos | Ed, I LIKE it Put me on the list please. Got one of those holders and wondered how to put it to good use, so now you have put another 'sidetracked' item on my list as if I don't have enough, cheers Geoff - I should change my Moniker to 'Sidetracked' |
Ed Duffner | 25/06/2015 09:30:48 |
863 forum posts 104 photos | Thanks Michael and Geoff, wow you chaps are up early! Geoff, have sent you a PM with a link to the drawings.
Regards, |
Ady1 | 25/06/2015 09:49:23 |
![]() 6137 forum posts 893 photos | Impressive stuff and a nice read Thanks Michael and Geoff, wow you chaps are up early! Don't forget that some of our chaps are in far off lands, fighting for the empire |
Ajohnw | 25/06/2015 10:03:53 |
3631 forum posts 160 photos | The basic idea works well. I have one of the old Myhford ME designs that fastens to the bed, plate added to lift the centre height up to suite a Boxford. It doesn't take long to cut a key way. Mine works well but I really should make a tool holder where the bit slopes at 10 degrees to provide some back rake without weakening it. On the other hand that might make the holder bend if it's too much and the tool will dig in making it bend more etc. John - |
OuBallie | 26/06/2015 16:13:33 |
![]() 1181 forum posts 669 photos | Recd with thanks Ed. Geoff - Eyelids are heavy so zzzz here I come. |
Ed Duffner | 30/06/2015 13:19:04 |
863 forum posts 104 photos | Just thought I'd add the link to my novice drawings here for anyone wanting them. Hope it's ok with the forum staff. In the PDF left hand bar there's a layers selection which can cycle visibility of certain parts of the drawings.
One thing I'd like to point out is that I made the tool-shaft for use with 8mm OD tool-bits (broken taps reground for other uses) and this can obviously be altered to whatever, a screw-on or Jacobs type chuck. Ed.
Edited By Ed Duffner on 30/06/2015 13:20:54 |
Bob Jepp | 30/06/2015 18:03:38 |
42 forum posts | That's fantastic - thanks Ed. I've filed that info away until after holiday time - going to the USA and doing the 'touristy' thing as well as visiting the Nevada Northern Railway Museum in Ely and the 1880 Train from Keystone South Dakota ( near Mount Rushmore ). Bob |
Michael Gilligan | 30/06/2015 22:18:47 |
![]() 23121 forum posts 1360 photos | The drawings look entirely adequate, Ed ... many thanks for posting. MichaelG. |
